Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore he3 washing machine door glass
Need to replace the front glass (screen) how do i open the door, i removed the screws but can't get door to come off to remove broken screen did not want to pry open wiothout proper procedure
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Kenmore washer HE3 broken door latch. How do you replace
Unplug unit then You can open the door, then remove the spring loaded clamp that secures the door boot (rubber) to the front panel, carefully pull the door boot away just where the door latch is (no reason to completely remove) remove the 3 screws securing the door latch to the front panel..Then reach behind the panel and pull the latch towards the opening the give just enough wiring to do so undo the 3 wiring connectors to the latch assy. then pull out the rest of the way Reverse the procedure to reinstall
Dec 29, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do i open the front panel of my Kenmore Elite HE3 washer to replace the interface board?
To access the front panel, or to take it off persey, you would have to remove the top of the unit, this isnt hard as it is fasted by a few screws in the back and you slide the panel back and then you will have access to the front panel mounting screws and remove those to remove the front panel.
DrakeTech
Feb 24, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Our he3 washer just clicks when you hit the start button and the door doesn't lock after several clicks the screen flashes and the machine just beeps . Ive changed the door lock once and it's doing it...
its a bad contact at the ccu(main control board located at the top of the unit). just remove top panel by unscrewing the 3 screws in back of top panel. the ccu is located in back right in the center of unit. replace the ccu. what happens is the contacts from the ccu are welded inside, so they must of broken off by vibrations of time. replacing the door lock will not help. replace the ccu and you should be good to go.
Apr 06, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 Washer door will not open
chris unplug unit.take off bottem paneland reach up in door latch area.their is a tab you can pull to open locked door.is the washed draining.you may need to clean pump if not.God bless,tom
Dec 30, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore he3 series washer keeps filling with water when not in use
Remove the 3 screws at the back of the machine that hold the top on. pull back on the top and lift the top off. Remove the hose from the inlet valve and remove the screw that holds the inlet valve.
Aug 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 WasherManual?
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
Apr 13, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 lock
Have you tried pushing the door lock/unlock button? I think it may be called the "rinse & spin", and under that it says door lock/unlock.
Sep 20, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
243 people viewed this question
Sal De
fordexpert
Robert Rankin
