Question about Video Cameras
No Power and Camcoder Tape Stuck Inside
Lost all ability to power up Mini DV Camcorder, and I need to remove the tape currently in unit so that I can have it serviced or trashed for parts.
  • Robert Harrison
    Robert Harrison Jan 15, 2009
    My post didn't take the Brand & Model which is Panasonic PV-GS320. I'm need to have it serviced and the tape has some racy stuff that needs to stay with me, or be erasedor I'm dead meat. lol
    Brigadier General:
  • 8,619 Answers
Hi!
Please provide me with brand and model no. Maybe it is not finalized or it got shut off during finalizing.
Posted on Jan 14, 2009
  • Rylee Smith
    Rylee Smith Jan 14, 2009
    It may have got stuck due to loose labels or has tangled itself with the roller. Try FW REW again and again to detangle it. And while doing so if you can gear a diffrent sound then that means the tape is tangled.
  • Rylee Smith
    If you hear a diffrent sound then try to open the tape compartment by force or by unscrewing the compartment
  • 10,594 Answers
I need to know model and brand to provide you correct info.
Here I would suggest to remove and attached battery and try to eject tape. Not ejected yet then apart camera and disconnect / unplug loading motor connections from main board and apply 4 or 4.5 volt DC at motor terminals and rotation of motor leads to unloading of tape mechanism and eject.
    Scholar:
  • 160 Answers
You will require the power to rtemove else it can get damaged .still you can try opening it manually by removing the screws and locks from the from unit where the tape is inserted.
  • chapli Jan 14, 2009
    To remove tape, insert proper tool under cassette door and carefully spread brass or plastic slotted door brackets just enough to release it from two opposing pins on the cassette holder. Hinge door away from camcorder and remove it completely at the pivot point. Break away plastic knockout covering loading motor and apply no more than 3 volts to unload tape from mechanism. Please note that a factory bulletin shows that IC6006, a 5v regulator #XC62AP4502MR, may cause intermittent or no power symptoms on this and mini dv camcoder models.
Picture during playback is badly distorted
There could be several reasons for badly distorted pictures. considering the age of the unit as DV camcoder which I am guessing would be quite a bit. Most likely the heads have worn out and need replacement. I am assuming you have this problem with newly recorded tapes being played on a TV directly from the camcorder. For this you may also need to check if you are using new tapes and whether the recording mode is PAL or NTSC as per the TV format.
Alternate test would be to play back a previously recorded tape back from the camcorder. That way at least you can establish if the problem is the read head or the write head or the tape itself.
Aug 16, 2014 | Canon Elura 100 Mini DV Digital Camcorder
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
Tape transport stuck in open position. Will not take tape into unit.
It could be possible that the tape is in the wrong way or that the tape is the wrong size those are both reasons that it may not be closing
May 25, 2009 | Canon ZR70MC Mini DV Digital Camcorder
Canon ZR-800 Mini DV Camcorder tape stuck
The way I can get a tape unjammed on my Sony camera is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined.
Feb 23, 2009 | JVC GR-DV800U Camcorder
Can not remove tape
I have the same problem...anyone out there?
Aug 14, 2008 | JVC GR-D370 Mini DV Digital Camcorder
Removed mini dv tape, reinstalled mini dv tape... cassette wont close, all power lost!
internal power supply fault, unit needs to be checked by a panasonic technician.
Jun 13, 2008 | Panasonic Palmcorder PV-DV53 Mini DV...
Removing dv cassettes manually
open the unit and look for a small motor that ejects the tape through a series of mechanical gears, slides and hinges. Now turn this motor by hand.
Jun 06, 2007 | JVC GR-D270 Mini DV Digital Camcorder
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
