Question about Pioneer SD-P50A5-K 50" Rear Projection Television
I have a pioneer p5073-k iy comes on then goes off this was for a few months now it want come on
    Scholar:
  • 56 Answers
Greetings!
Most of the intermittent problems in these were caused by instermittent solder connections. Now that it won't come on at all, you may be experiencing a different problem. These were famous for having the regulator for the convergence controller go bad. When they failed they would knock out the 4 amp fuse on the secondary power supply line. The best part is that they, too, would be intermittent, which is to say that you would replace that fuse and the set would be fine. Sometimes for 2 days, other time for two weeks, then the fuse would open again and you ended up replacing the regulators.
With either problem it is not something that I recommend you attempt unless you are an experienced repair tech. These are very easy to create more problems than what you started out with. The up side of all of this is that you have a very high quality RPTV that had a very nice picture for its time. Depending on the fairness of your local TV tech it would be worth repairing: it would be worth at least his diagnostic fee to confirm the problems.
Rob
Posted on Jan 14, 2009
Air bag light showing at the dashboard. It's intermittent happening. The air bag light dissapeared for a month then iy\t's back again. It usually appears for a couple of days. What could be causing t
The airbag light on the dashboard comes for few reasons, either there is a bad connection or connection came loose but than the light would stay on at all times, if it comes periodically than I would look up to the owner's manual and also find the airbag check label inside the car as it might be faulty or in need of replacement. The danger is that if it is faulty it can blow up by itself or in case of accident (hope none happens) it will malfunction.
Oct 18, 2011 | 2001 Pontiac Montana
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Mar 20, 2011 | Ctm HS-2800 Power Wheelchair
I have a pioneer sd-p5073. Every now and then the picture will become blurry for a split second and then come back to normal with whatever imput I am using coming up in the top right corner. This happens...
Ur convergence is dying.Must replaced convergence ICS and all it resistors.Know how to solders?Buy a convergence kit at Tv Repair world.com,Tvrepairkits.com
Jan 12, 2010 | Televison & Video
Pioneer sd-p5073-k am in the process of replaceing the converinage chips. and cant seem to find any pico fuses anywhere on the converange board or main board there are several regular fuses on the main...
Make sure to check all the fuses with an ohm meter. Pioneer also have terrible solder joints. I used to "sweep solder" the whole convergence board. Down on the power supply you should find the pico fuses. They are pretty small in compairison to the glass fuses.
Oct 14, 2009 | Televison & Video
Laser disc player produces b&w only lately? pioneer cld-d504
Ooops, in my efforts to find laser disc INFO I ended up in a completely irrelevant category; because there no longer exists a Laser Disc category. So I shall abandon the laser disc player as technologically obsolete (there goes still another species of dinosaur off to the fossil beds) and give up on seeing those movies in color.
Nov 08, 2008 | Pioneer Computers & Internet
Pioneer SD-p5073-K Shuts off
it is the power supply board an know problem with pioneer. If you have any soldering experience you can remove the powersupply board and resolder the tracks and as many parts as you can. I had the same problem and not the power supply works great. You will soon have other problems like pic and sound going intermittant where you have to hit the tv to get it back on. more solder problems on video main board. best of luck
Aug 22, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
OEL Display not working
try pacparts.com for the other ribbon cable that goes to the OEL display
Jul 13, 2008 | Pioneer Premier DEH-P960MP CD Player
Blue lines on the screen
Remove Convergence / power supply circuit board...replace
convergence IC's with first quality ....either Philips,Toshiba or
best choice = upgrade to Hitachi = CZ 01341....let me know
if you have ? 's............T.
Feb 12, 2008 | Televison & Video
Head unit
If the display goes out then it is possible the flex cable is broken. Return it to Rockford for repairs.
Jun 19, 2007 | Rockford Fosgate RAV DVD1 Car DVD Player
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
67 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
