Question about Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000
Broken casting wont hold flot bowel
Where can i buy a carb for a 12 hp proforce genorator?
Who makes the engine?
    Problem Solver:
  • 6 Answers
From the dealer about $20 to $50
Posted on Jan 19, 2009
Have two yard master mowers neither one will start need company phone number for manufacturer warrenty.
Just an experiment.
Take the spark plug out and put a little shot of gas in the spark plug hole and replace the plug and wire. Try to start it and if it fires up then stalls when the shot of gas is used up then you know its a dirty carb. If there is a bowel on the bottom of the carb remove it and clean it out real good and clean the jets that are in the bolt that holds the bowel on. Replace the bowel and jet screw making sure the gasket is on properly and try to start it. I had a lot of engines that had a dirt problem.
Oct 07, 2014 | Garden
Hard to start half to crank 25 to30 times it is discouraging help
few things to check first i would check my compression with a compression guage most small engines wont start easily if it doesnt have atleast 100 psi anything less makes them very hard to start this will also identify if you have leaking valves stuck valves or piston ring problems ect. next check to see if you have a spark. sometimes the spark plug is the culprit but you can check to see if you have a spark sever ways one is to disconnect the spark plug wire and in sert a phillips screw driver in the clip that holds the tip of the sparkplug and hold the well insulated handle and hold the shaft of the screwdriver near the block or head of the engine and pull the starter you should see and or hear a healthy spark. another way is to get a timing light and a 12 volt battery to power the timing light and connect the battery negative to the block of the engine tested clip the sensor lead on the spark plug wire while its still connected to the spark plug and it should flash when you pull the starter rope. or you can get a spark tester a good one has a neon light in it and a ground clip hold the spark tester to the sparkplug wire and it should flash as you crank the engine. if you have compression and spark next check your carb. assuming it has fresh good gasoline with no water in the gas your carb may be gunked up, clogged with trash or stuck float. remove carb and dissasemble starting with the bowl make sure its clean in there and the float and float valve isnt sticking then get a torch tip cleaner and ron the fine cleaning wires in ever orifice you can find. pull the main jet clean the tiny holes in it and spray carb cleaner in the carb body and parts. if it has adjustable jets pull them and clean. use compressed air to clean it out also. do not pull the welch plugs just yet if you do you will have to get a repair kit and takes some skill and patience to replace. reassemble carb carefully make note of were all the parts and pieces come from and replaces them. before removing adjustable jets count how many turns it takes to screw them in and only lightly seat them so when you pull them out you may return them to were they were originally adjusted. there are tiny holes near the butterfly throttle plate in the throat of the carb make sure they are clean and clear. if it is really gunked up there is carb dip but do not soak longer than recommended on the can as it will dissolve brass and ruin your carb. if you still cannot get it to run or run right. you can buy a new carb on ebay recheck valves or just bring the darn thing to a professional. good luck!
Nov 15, 2012 | Coleman Powermate Proforce 2500 Generator
Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Jun 30, 2012 | Omega Rear Drive Wheel Snapper Mowers
Float bowl drain plug stripped, had to buy a new carb. new carb came and new float bowl didn't have the threaded part that what may be the ignition module to screw into. So I took the old float bowl off...
When you replace the carbs on these motors it can take a bit of time for them to start and run. If there is a primer bulb pump it up and keep pumping, this is basicly force feeding the carb until it has the vacumn to get the regular supply of fuel coming in.
Mar 25, 2010 | Coleman Powermate Proforce 6,000 Watt 12...
I have a proforce 2500 watt generator and it cuts out is this caused by low oil? if I change oil how much does it get?
Low oil doesn't usually make engines cut out. Clean the air filter, change the plug and wire. If this doesn't help then I think you're looking at a carb. problem. Probably just clogged jets & ports. It's very common on small engine carbs. It shouldn't take more than 2 quarts of oil. Probably not even one.
Nov 30, 2009 | Coleman Powermate Proforce 6,000 Watt 12...
Spark Plug location for Powermate Proforce Generator #PM0102500?
Hi
Try to see where is the had of the engine.
best regards savumihai71
Dec 22, 2008 | Coleman Powermate Proforce 6,000 Watt 12...
Coleman Powermate Proforce 6,000 Watt 12 Hp Portable Generator #PM0106000 Logo
101 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
