Question about Gateway MT6707 Notebook PC
LCD went dark
I have a gateway laptop model MT6707. The monitor was working then started going dark, then would come back on. Now it doesn't come on at all no. Any suggestions?
  • 3 more comments
  • soltisjos819 Jan 14, 2009
    It's 2 yrs old....and no...no display at all now...I can hook it up to external monitor
    I checked everything already, and your not going to believe this, but it just came back on. So maybe not the LCD display? Now it just went out.
  • gmf56 Jan 23, 2009
    gateway mt6707, screen is very dark. everything seems to work when connected to external monitor.
    Any suggestions other than a new screen?
  • billmidd Feb 05, 2009
    Same problem here. The laptop will power on and LEDS light but the screen remains dark. I plugged in an external monitor and then both the external monitor and laptop LCD worked. I unplugged the external monitor and it would power up and down and everything worked fine. After a while the screen went dark again and won't come on.
  • DEKR
    DEKR May 11, 2010
    How old is and and are you saying you see no screen display at all
    Genius:
  • Gateway Master
  • 1,102 Answers
Hook it up to another monitor then control panel then display see i8f something was changed in there
otherwise your screen may have gone but it's only two years old
what were you doing when you lost your screen
Posted on Jan 14, 2009
Gateway mt6707 no sounds
Check the Mute button, make sure it is not selected.
If it still does not work then install the latest audio driver.
You can download the audio and device drivers for your model Gatewaylaptop from this WEB site. Make sure you select your model laptop and thecorrect Windows drivers. Click on this link to download the drivers: -
http://driver-pro.com/related/english/hardware-drivers/?a=12221&gclid=COmm19XHtpwCFSMSagodPRuwnQ&hit=1
Mar 14, 2012 | Gateway MT6707 Notebook PC
My laptop screen went very dark, I can barely make out whats on the screen but I know its working. What can I do to fix this situation on my gateway p-6860fx pc notebook?
Hi josue fernan...
You need to see if your laptop lcd screen is faulty and/or the lcd inverer is faulty.
1....Test the lcd screen:
Hook your laptop to an outside monitor and then start your laptop normally...if the picture on the external monitor is good, then your lcd screen is bad.
2....Backlight Faulty: If the monitor is still as dark like your lcd screen on the laptop then it could be the backlight that is faulty.
Please take time to rate me thumbs up
LCD Backlight and Screen Replacements:
http://www.laptopsman.info/0-Gateway-lcd-1.html
LCD Screen replacement:
http://www.screentekinc.com/Gateway_P-6860FX--17-inch--1440x900-wxgaplus-laptop-lcd-screen.shtml
Sep 11, 2011 | Gateway P-6860FX Notebook
MT6707 Widescreen Notebook PC (1014360R) PC Notebook: I WANT TO RESTORE A USED GATEWAY MT6707 BACK TO FA...
You can restore the computer back to factory default,to do so, follow the below steps:
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
If the above mentioned steps are not working then you need an RCD to do so. Contact the Gateway support.
May 06, 2010 | Gateway MT6707 Notebook PC
My Gateway mt6707 laptop gets dark when I unplug it. Do I need to get a more powerful battery?
Hi
Thank you for your query
No this doesnt have anything to do with your battery.
As you can appreicate the your screen needs alot of power so when plugged in there is a continuous source of power so its very bright, however as your battery has only a limited charge, the screen will go dark to conserve
There are 2 ways of changing this
1) Press the fn key + the key with a sun symbol on there this is usually the up arrow key or the right arrow key, but will will vary from manufacturer to manufacturer
2) Click Start> Control Panel>Power options
Inside here you will be able to set what type of power profile you want running on Plug and battery
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again - shauqatm@yahoo.co.uk
Feb 23, 2010 | Gateway MT6707 Notebook PC
Gateway Notebook ML6721 going back and forth between battery & AC
the socket where the cord plugs into the back of the laptop gets wattered out and does not make a good connection when it gets this way. I suggest that not move it so much it kinda defeats the purpose of a laptop. though
Jun 22, 2009 | Gateway ML6721 Notebook
Additional ram on Gateway MT6707
Feom the Gateway site: 2048 MB 533 MHz DDR2 SDRAM (2 × 1024)
Total slots: 2 DDR2 slots | Available slots: 0 DDR2 slots
Maximum memory: 2 GB
Hope this helps.
Dec 23, 2008 | Gateway MT6707 Notebook PC
Hello my mt6707 notebook
Your back light went out if you can see a faint display on the screen... Is there a post beep?
If not I suggest:
Unplug and remove battery
Take RAM out
Let it sit for 15-20 minutes
Try again.
If this doesn't work try different RAM
Dec 11, 2008 | Gateway Computers & Internet
Monitor screen ia blank
open it and see if you can find a blow capacitor on the logical lcd board...it´s very common to happen in this kind of model...
Good Luck!
Dec 04, 2008 | Gateway FPD2275W LCD Monitor
Gateway 320S monitor is dark... external monitor works fine
Yes your back light has failed inside the lcd. That can be replaced.
Oct 28, 2008 | Gateway M305CRV Notebook
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Gateway MT6707 Notebook PC Logo
168 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
