Washer Problem My washing machine is not spinning the clothes at the end of the cycle. The motor is going and "sounds" normal, except the drum is not spinning when it is supposed to. Is it the "timer"? or is there a more specific part name I can go look for?
  • 15,935 Answers
Could be the motor controller failed - a loose belt, or a lid switch.
Further testing is necessary without guessing.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Hi, I have an Amana front load washer NFW7200TW that will go through entire cycle but won't spin- cycle ends and clothes are very wet. Unlike the other posts I read, mine shows no error code nor does the...
I have a similar problem with a Kenmore top loader washing machine.It turned out a problem with the main shaft of the drum; it wears out and caused drag on it. at one point i installed a washer or spacer between the shaft and drum it worked for a while and the problem came back again. it is a mechanical problem and it is present with other brands that share the same drum and shaft.
Finally I end up buying a different brand this time a LG .
Mar 08, 2015 | Amana Washing Machines
The machine doesnt spin with clothes in it
Could be a blocked filter, or worn brushes in the motor.
To check filter, remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum
Remove and clean filter inside trhe hose.
Remove hose onto pump, and check for obstruction or blockage here.
To check the carbons remove motor from washer, and the carbons are located at the oppsite end to the motor pulley.
Hope this helps.
Dec 16, 2009 | Hotpoint Washing Machines
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Wash.machine won't spin
Door lock switch # 131763245 if everything else is working fine this should fix the problem. It shorts out between the motor control board and the door lock from emptying the cycle and spinning. Try running your machine on drain/spin and see if it drains and tosses clothes and then stops with no spin. If that happens then it is your door lock.switch. Easy to replace by yourself and costs $65.00
Mar 13, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washer spin problem
Ok so your having problems with the washer spin problem. Well there mightbe a sound that it is making like a jumpoing sound. Well when you here that open it and you might notice that all the clothes are on one side. That means that you put too much clothes in the washer, and it can't handle it. So open it and take out some clothes and restart it. I hope i helped you problem's. Thank you for taking your time to read my article.
Feb 12, 2007 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
