Question about Sony LIP-4WM for MZ-NH1 Personal MiniDisc Player
Cannot charge battery on MZ-NH1
I cannot charge the battery. At first the charging light would come on and everything ok. Then connection to the cradle became intermittent...the unit would start to charge as it was placed on the cradle but when fully connected to cradle and clicked in charging would stop. Now it won't charge at all. Is there any other charger that will work with LIP4WM battery.
Many thanks...Ian
  • Ceres Rising
    Ceres Rising Jun 10, 2015
    I had the same issue with my MZM10 battery charging. I bought the replacement from Ebay and it still wont charge. My solution was to take a razor and cut the excess green layer at the back end of the battery. I then charged the player using a mini usb connector to my laptop. Seems to be working.
    I hope this answers your concerns.
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
Metz 76-56 battery charger keeps flashing red light
One of your cells is defective.
It maybe brand new, but we don't know how long it's been in the box.
You will need a DVM to troubleshoot the battery.
atdlee@netzero.com
Oct 04, 2012 | Metz NiMH Battery 76-56 for 76 MZ-5...
Cannot charge MZ RH910 through usb
Possible that there is fault within , can be a faulty battery, corrupt memory or a hung up processor. Try and reset if not the player has errors. It must switch on with the power connected if the battery is low.
Nov 10, 2011 | Sony MZ-RH910 Personal MiniDisc Player
Need instructions for mimni disc player MZ-NH1
You can download and print the instruction manual in PDF format by clicking this link:
http://www.docs.sony.com/release/MZNH1.pdf
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
Jan 02, 2011 | Sony Walkman MZ-NH1 Personal MiniDisc...
My MD player does not operate? No display coming on the screen. Power is connected ok
Unfortunately if it's getting power but not responding there is little that you can realistically do. When you state "Power is connected ok" I presume that this means you have already tried using the gumstick rechargeable battery (which doesn't last forever, BTW), and also the charging stand. If you have tried both of these, then it's clearly not an obvious fault such as a broken power input socket. You can also try connecting the optional external dry battery case, but this was an optional item with the N-710 and rarely purchased by users, or you can try disconnecting the ac adaptor from the charging stand and connecting it directly via the socket on the player marked DC IN 3v.
The fault is likely a really simple one but the MZ-N710 and almost all other portable MD players were never designed to be repaired and consequently are really difficult to dismantle without causing more damage. When I used to sell these products I was told by the Sony servicing centre that for all but the most minor issues warranty claims were dealt with by destroying the returned unit and sending the customer a complete replacement.
Spare parts were not commonplace when the units were a current model, and now they're as common as freshly laid dodo eggs. Your only realistic fix is to replace the unit.
This may sound negative, but it's not: because MD is now an obsolete format there are millions of perfectly good units lying unused by those who have upgraded. Except for the later and far rarer HiMD models and also flagship regular units like the MZ-N910, almost everything else is near worthless so folks tend not to bother with selling them. As a result it's quite easy to pick up MD equipment for free via your local FreeCycle and Freegle groups; apart from my own MZ-N910 (still in regular use and has a far superior sound quality to any iPod) every piece of MD gear I own was obtained for free, usually with loads of minidiscs as well. Don't be too choosy about what you may be offered as most of the Sony NET MD players (any MZ-N model) can be easily hacked to give them most of the features of the flagship MZ-N910.
If you do end up recycling your MZ-N710, then keep all of the accessories as they can be used on other players which you might acquire.
I hope that my answer has been of use even if you cannot fix your player. Please take a moment to rate my answer.
Oct 02, 2010 | Sony Net MD Walkman MZ-N710
Need a new charger for a sony minidisc recorder MD WALKMAN MZ-NH1
Required charger for MZ-NH1minidisc recorder part number is 147839311 AC-ES608K and it is available in Sony Accessories Store for $48.
Jul 04, 2010 | Sony Walkman MZ-NH1 Personal MiniDisc...
Battery for sony net md walkman mz n710
You have to charge it with high voltage, external power unit to get the fine result of charge or buy a new battery
Apr 02, 2010 | Sony Net MD Walkman MZ-N710
Sony Walkman HDD
check your pcs drm settings, as well as sonicstages, if like ripping on media player, it's default is to copyright everything with digital rights, turn this option off.
Jun 26, 2009 | Sony Walkman MZ-NH1 Personal MiniDisc...
Mz-n10 just died...after new battery install
Well, this is a bit late, but if you still have the N10, you must charge the internal battery enough for the external battery to work. You can run the internal battery dead enough that it won't recognize the external battery in this model.
Make sure, of course, that the battery switch is on, and that you have the correct charger.
Nov 05, 2007 | Sony NetMD Walkman MZ-N10 Player/Recorder
1,146 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
