COLOUR PROBLEMS couple years combi.recently got stripes of colour blue/green/red rainbowed across screen.bottom third of picture okay normal colour.unplugged sky and still see it on tv
  • 56 Answers
This sounds like a degaussing (named after 19th century scientist Carl Friedrich Gauss) problem. This usually occurs one of several ways:
1. The TV fell down and went "boom".
2. Junior held a magnet up to the screen when you weren't looking.
3. There is a large, unshielded speaker near the set.
4. The TV was rotated in relation to the North/South magnetic poles of the Earth while it was running (yes, really).
All televisions have a degaussing coil built into them which is activated momentarily every time you turn on your TV. This typically will cure all minor anomolies over the course of a few days. However for a severe one like you have, it will probably require a trip to your friendly repair shop. I, personally, do not charge anyone to perform this service because it takes, literally, 5-10 seconds to degauss a TV. I simply ask them to remember me next time they go to buy a new TV or need service work. I can't say that your technician will do the same.
In the case of the first instance of the TV falling down and going "boom". If it fell with enough force to warp the shadow mask built into the picture tube, then all of the above information means nothing. The set will require a picture tube replacement to cure the problem.
Hope this helps,
Posted on Jan 14, 2009
When using component cables(red, green, blue )
The series of the cable should go green red blue into the back. if you put the green in the red and the red into the green it give the TV a red base to go off of for the picture so everything is red. The reason the green cable won't is because it transmits a black and white picture which allows it a nice base to add the green and red to.
Feb 24, 2010 | Samsung HP-R5072 50 in. Plasma HDTV
Sony Trinitron sets are of CRT [Caothde Ray Tube] types. The common fault seen in these type of TVs are any one colour predominant on screen wih sound OK. Either red, blue or green colour with some thin horizontal lines at about an inch apart will be seen on the entire screen. This is totally a display card problem, which can be seen pluged onto the picutre tube neck. There are three electron guns for every picture tube, which emits red, blue, and green beams, which in turn illuminates the phosphor on the screen to get that colour. If no emission from all guns, results in a blank screen, ie black screen without any disply at all. The three colour beams together produces proper coloured picture what we see on screen. These three gun's terminals are brought out by pins of the picture tube outside to which video signals are given in appropriate proportion to produce a TV picture. Normally, all these three pins are biased with a voltage of about 170 to160VDC+ve. Take one colour gun, as an example and and let me describe the problem.
Let it be a green gun. These guns are called cathodes of the picture tube. If it gets a voltage with respect to its grid, it will emit electrons according to the voltage applied to it. This is a negative process, that is, as the voltage at this pin drops, its emisson incresses and vice versa. If the emission increase, the colour with respect to that gun also will increase and gets predominant at the screen. So when we see a green predominant screen, there will be less voltage at the green cathode with resepect to the other two. If red colour is predominant, the voltage at red cathode will be less than the other two. If blue colour is predominat, the voltage at the blue cathode will be less than the other two.
We must find out the reason for this fault first. Assume that your Tv has a red predominant screen with some thin lines across it, at about one inch apart of the entire screen, it is clear that the the red cathode voltage is very lower than the other two. the main reason for this fault, normally seen in most of the Sony Trinitron, are loose soldering points either to the picture tube base socket or the resistor connected between the red drive transistor's collector point. Resoldering the most of these points on the base card by applying a little more solder will rectify this probelm. Other possibility is shorted video output transistor of that cathode. A direct short [collector to emitter] of these transistors will drop volatge to very low at that respective cathode of the picture tube, and that colour will be pridominant along with lines. Replacing the transistor will solve the problem. In some cases, the resistor connected to that transistor may have blown out. If so, it should alo be replaced. Whatever the case may be, voltage at the respective cathode that emits colour will be very low with respect to the other two. Find out the reason and rectify it. You can compare the voltages of the other two cathodes with respect to the faulty colur cathode. Cathode pins will be marked on the base card, and can be identified. It is best to pull out the base card from the picture tube neck and place it somewhere a safe place without shorting it with other parts of the TV. You can measure the voltages of these points very easly, without fearing the damge to the picture tube. After all are found Ok, replug the base card and switch on the TV. The set will be alright. In rare cases, chroma IC also can be a reason for this fault. if it is faulty, after a short period after switch on the TV, the IC will overheat and shutdown the entire system.
on Mar 21, 2011 | Televison & Video
I have a bush colour tv and there is a blue,green,red colour wash right across the picture so people''s faces look half blue,green red....sort of as if there is a rainbow across the screen.. i do not have...
It sounds like your TV may need degausing.
Is your TV situated near to any loudspeakers or other devices with large magnets inside them? Or has anyone been near your TV screen with a magnet???
You need to try to get the screen demagnetised (degaussed). Many TV engineers have a degausing coil that could do this. It only takes around 20 seconds at most.
Some TV's like Mitsubishi have a DG button on the remote, that does this function without the need to call out an engineer! It only needs one press of the button every few years!
Nov 17, 2009 | Televison & Video
Plasma tv problems
Thanks for the photos, it looks like an internal adjustment is required to the ramp generator which controls the sequence for the screen to refresh itself from a previous image to a new image. This is a precise setting & also a software update may be necessary to cure the problem. These settings are on the Y-Sutain board & need to be accurate.If this procedure does not cure the problem then the screen will need replacing. As it will out of warranty, it would be best to contact a local repair centre & ask for an estimate to try & set these adjustments for you.
Sep 23, 2009 | Televison & Video
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Colour problems
check for open resistor R302 on the CRT board. 150 ohm 1/8 watt SMT resistor, located at the base of Q305
Feb 11, 2008 | Televison & Video
Connecting old DVD player to LCD
Just respect the colors. Green output from the dvd to green input tv, Red output from the dvd to red input tv and the same with blue. All 3 cables (green , red, blue) are for the picture, so you got to plug another 2 for the sound.
Dec 25, 2007 | Sony BRAVIA KDL-40S2400 40 in. LCD HDTV
Pulsing screen
Are you getting this on all video outputs from the DVD? the yellow analog out + the red/blue/green + the S video? Did you try connecting a different source? a digital cable TV tuner, or another DVD player? sometimes DVD players get screwed on some outputs, while the rest stay fine. I have a DVD that has an analog video out that shows an only black and white picture, while the red/blue/green works fine. Good luck
Apr 21, 2006 | Yamaha DVXS60 System
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
