How can i partition my computer without corrupting any file installed in Window Vista 2007? Dave
    President:
  • 623 Answers
You will have to use third party software to accomplish that task.
There are several options out there, but in the end it comes down to the question how much you are willing to pay for it.
Two excellent options are
1. Partition Magic (from Symantec). Cost about 70$
2. gparted (sourceforge). GPL = free.
I personally prefer gparted, because I'm not using these programs too often to justify the expense.
At any rate: this is something you want to be careful about and it is ALWAYS possible, that the installation on your harddrive goes south and you have to reinstall your operating system.
So:
  1. Make a backup of all important files. (If you want to be really careful, use a program like "Acronis True Image" to create a copy of your existing harddrive. You can download a 15-day trial here.)
  2. Get a keyfinder program (here) and save your installation keys.
  3. Check your backup again!
  • Your Documents?
  • Your emails?
  • Pictures?
  • Music?
  • Anything else you have stored on your harddrive?
Although I never had a problem, you want to be prepared.
Read the documentation and manual page before you start.
If you can, do this with a friend or have at least another computer nearby for internet access, in case you need to find information.
In the end, I always find it satisfying and I hope so will you.
Enjoy!
Posted on Jan 14, 2009
  • 59 Answers
To resize a partition with Windows Vista, follow these steps: Be sure to back up any valuable information, because there is a slight chance that data can be lost when dealing with partitions.
1) Click on the Start menu
2) Right click on Computer and click on Manage
3) You may get a User Account Control dialog here; just click Continue
4) In the left pane, open up the Storage category and click on Disk Management
5) Here, you will find your partitions for your disks. Right click on the partition you’d like to modify.
6) Click on Extend Volume or Shrink Volume to extend or shrink the selected partition.
  • Johnny Tucker
    Johnny Tucker Jan 14, 2009
    8. Now right click on the free space and click on New Simple Volume.
    9. Select size amount Click on Next
    10. assign drive letter Click on Next
    11. Select format this volume Click on Next
    12. Click on Finish
Tip
Install Windows 7 or Windows Vista on a Pc Without DVD Media
For user who doesn’t want to waste a DVD disc to burn the ISO to physical media, and does not have WinPE (Windows PE) startup disc, here’s a workaround method to install Windows Vista and Windows 7 into physical computer’s hard disk drive or partition (volume) directly with ISO without writing or burning to disc. The without-disc installation method is useful especially during beta and RC period of new operating system in the making, where the new build and new versionis launching and publishing every now and then. This tutorial guide assumes that the new Windows 7 or Windows Vista will be installed and replaced the original existing operating system currently installed. The instructions can be modified slightly (mainly on hard disk partition used) to fit into need of readers who want to have a dual-boot, multi-boot, or simply just to upgrade install to new OS.
1. Install a virtual CD/DVD drive on existing Windows operating system.
2. Mount the Windows Vista or Windows 7 installation DVD ISO image using the virtual drive.
3. Copy all files inside the virtual CD/DVD drive mounted with the ISO into any folder on any partition or hard disk drive not going to be used to install the Windows OS. For example, copy into E:\Windows7.
4. Copy the bootmgr and boot folders nested inside the copied folder (i.e. \Windows7) to root directory of system boot drive, typically C:\.
Note: For Windows Vista, users may need to use this step: Copy the bootmgr folder from E:\Windows7 to C:\ root directory, copy E:\Windows7\boot\boot.sdi file to same folder in C:\boot folder, and then copy bootsect.exe from the E:\Windows7\boot\ folder to C:\ drive.
Note: boot folder in system boot drive is hidden system folder.
5. Create a new folder named sources under the C:\ root folder.
6. Copy the boot.win file inside \Windows7\sources folder to the source folder created in the system boot drive, normally C:\.
7. Open a command prompt as administrator.
8. Run the following command (change the C to your drive path letter if applicable):
C:\boot\bootsect.exe /nt60 C:
For Windows Vista users who copied bootsect.exe to C:\ root folder, use the following command instead:
C:\bootsect.exe /nt60 C:
A successful message is the command completes successfully.
9. Change the name or label of the boot system partition local disk to BDCP or any name you prefer that easier to remember and type (in DOS command promot, use label command).
10. Restart the computer.
11. After booting up, the system will start the corresponding Windows installation process. Select the applicable language to install, time and currency format (regional settings locale) and keyboard or input method in the installation wizard dialog.
12. On the next screen, user will be presented with option to Install Windows. DO NOT press on Install Windows button, instead, click on Repair My Computer link on the bottom left corner.
13. In the Windows Recovery Environment (WinRE) System Recovery Options dialog window, click on Command Prompt to open a DOS Prompt window.
14. Run the format command to format the primary hard disk or partition to clean state:
format c: /q
Note: /q switch, which perform quick format can be omitted to full format. And if existing hard disk partition is of FAT32 filesystem format, use format c: /q /fs:ntfs to convert the file system to NTFS while formatting. Before formatting begins, the command may prompt for hard disk drive or partition label name, if so, enter accordingly (i.e. BDCP).
15. After format completed, start the Windows Vista or Windows 7 installation process again by manually running the setup.exe located in the copied. Note that the setup.exe is not the one located on boot system drive which copied at later step, as the boot drive has been formatted. For example:
E:\Windows7\sources\setup.exe
16. Continue with installation procedures by following on-screen instructions as per normal practice.
on May 19, 2010 | Computers & Internet
Fix BIOS on Dell Inspiron 531 Vista Home Basic 32-bit
The BIOS may require flashing when an update is available or when replacing the system board.
  1. Turn on the computer.
  2. Locate the BIOS update file for your computer at the Dell Support website at support.dell.com.
  3. Click Download Now to download the file.
  4. If the Export Compliance Disclaimer window appears, click Yes, I Accept this Agreement.
The File Download window appears.
  1. Click Save this program to disk, and then click OK.
The Save In window appears.
  1. Click the down arrow to view the Save In menu, select Desktop, and then click Save.
The file downloads to your desktop.
  1. Click Close when the Download Complete window appears.
The file icon appears on your desktop and is titled the same as the downloaded BIOS update file.
  1. Double-click the file icon on the desktop and follow the on-screen instructions.
Aug 14, 2012 | Dell Inspiron 531s Desktop Computer
My desktop has vista basic which i have deleted earlier and installed xp pirated now i want to reinstall original vista home basic dvd
simple way is to boot the system with VISTA DVD in the drive, and follow the instructions.
before doing any change, backup your files..
Jan 17, 2010 | Dell Inspiron 530s (DDCWFA2_1) PC Desktop
I can backup files from my laptop to the Store and Save Drive, but I cannot copy them back from the drive to the laptop. My laptop runs Vista Home Edition and was recently repaired which meant wiping the...
Themain contexts where hard drive data recovery software is found useful include:
1. Missingfile or directory
2. Formattedhard drive
3. Deletedfile or directory
4. Unbootablehard drive
5. Inaccessiblehard drive
6. Recoveryof deleted files and folders on FAT and NTFS hard drive or partitions
7. Datarecovery on damaged FAT and NTFS partitions
8. Damagedor corrupted partition table
Dec 16, 2009 | Office Equipment & Supplies
How to Install windows XP in SONY VAIO Vista
Is it ok if your files get lost forever?  If it is then what you have to do is when it says if you want to partition a hard drive space, you delete the biggest parition (which wipes any and all vista and files of the computer.)  Then it will ask you which partition you want use.  Use the one you just deleted, whhich is the biggest one.  It will ask you to format it and stuff, just go with it.  Then you will have XP instead of Vista!  (Warning: I warned you above that this way will wipe of vista and any other files-documents-photos-everything off your comptuer)
Apr 20, 2009 | Sony VAIO VGN-FS640W Notebook
Unrecognized partition
You need to unlocked that one
Use partion magic software to partition your drive.You can dowload it for free.
Apr 09, 2009 | Computers & Internet
Cant find Infopath/inflr.cab file in location...
What is the source of installation do you use to install Office (CD or Download source)?
If you are installing using the disc create a new folder on the computer, copy the entire contents of the disk to a new folder on the desktop and then run the installation from the setup file in the folder and check if it works fine.
If it is a download source file, try extracting the download file using the steps mentioned below and then try to install and check if you are able to install Office.
Click Start, Search programs and files, Drag and drop the .exe file to the Run window and type '/extract' without quotes
Now try to install Office by double clicking on setup.exe
Refer the link below to know how to extract .exe files:
Nov 09, 2017 | Microsoft Office Professional 2007 Full...
Restoring WIndow Vista
No, windows backup will only restore your data, for example My documents, Desktop, User settings, and Outlook data.
To restore the system you will need a windows install disk, or if your computer has a restore partition(like many dell, packard bell etc.), you can use the restore windows utility from partition.
Regards
Jun 06, 2008 | Computers & Internet
ACER Laptop with Vista OS
My problems is Microsoft works. I thought when I bought this computer from Best Buy that it wasn't trial one. It keeps telling me to put the # in. I can't seem to find the # they one. I have used without the #. But it dosen't let me do everything with out it.
Apr 30, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
