Question about Sharp EL-2630P Calculator
Sharp EL-1801V Want Print. Has an E
My calculate just stopped printing. It come on and has the correct time and date and will add in the ON mode.When I switch it to Print and E comes up and will not do anything. All I can find in the manual is E means an overflow or other error detected. I've cut it on and off - nothing. Pleas help if you can
5 Suggested Answers
SOURCE: EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Posted on Dec 04, 2008
SOURCE: Time/Date
To set the date Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key once and the date will be diplayed, key in the info as follows: 1/1/08 would be keyed in as "1" "." "1" "." "2008", the display1.gif will show 1.1-2008 then press the clock/calendar key, the correct date will show up.
To set the time Step by step as follows: Set the lever to "RATE SET", Press the clock/calendar key twice and the time will be diplayed, key in the info as follows: 12:00pm would be keyed in as "12". "00", the display will show 12.00 then press the clock/calendar key, the correct date will show up. For 12:00am key in "0",".","00" as it expects to see 24hr time.
Posted on Mar 12, 2008
  • 10865 Answers
SOURCE: I have a sharp calculator EL-1801V...that I need
hello. here you go. here is the entire owner manual for your use.
http://www.sharpusa.com/files/cal_man_EL1801V.pdf
Posted on Jun 25, 2009
christyrse
  • 45 Answers
SOURCE: How do I change the date on a Sharp EL-1801V
Below is the step by step directions on how to update the date/time/tax rate. To set the date, time or tax rate, set the "Grand Total/Rate Setting Mode Selector (GT . RATE SET) to "RATE SET" position.
For Date:
1) Enter in the order of month, day and year, with the decimal point in between each set of numbers. Month 1-12, Day 1-31, Year: 2000 - 2999 (4-digits) or 00-99 (2-digits).
Example 04.10.2010
2) After the year, press the button with the clock/calendar symbol to complete the entry. When this button is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored.
For Time:
1) Enter in the order of hour, minutes with a decimal in between the hour and minutes, then press the button with the clock/calendar symbol to complete the entry. (No seconds value is entered) When this button is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hours must be represented with 0-23 (24-hour system for the hour entry), Minute: 0-59.
FYI, This calculator uses CR-2032 lithium battery.
Enjoy!
Posted on Apr 10, 2010
How do i set the date?
Program the Date & Time and Print Method using the 3 buttons: Mode, Select, Setting:
Date & Time: Press the Mode button. The Hour will start blinking. Press the Setting button
until the correct hour is displayed. Press Select to set the hour shown.
The Minutes will blink. Press Setting until the correct minutes are displayed. Press Select
to set the minutes shown.
The Seconds will blink. To set the seconds at 00, press the Setting button. Press Select.
The Year will blink. Press the Setting button until the desired year is shown. Press Select
to set the year shown.
The Month will blink. Press Setting until the correct month is shown. Press Select to set
the month shown.
The Day blinks. Press Setting until the correct day is shown. Press Select to set the day
shown.
Print Method: Press the Mode button until P5 (Program Mode 5 for Print Format) is displayed.
Press Setting to choose one of the following Print Methods.
The TC100 has two settings for print activation: Manual or Automatic
1 = Automatic (default setting) - The TC100 automatically prints when the time
card is inserted.
2 = Manual - After inserting the time card, press the Print Button to activate
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this Help : - )
Dec 11, 2011 | The Times ROYAL TC100 TimeMaster Time...
How to change the date
the month shown.
shown.
card is inserted.
printing.
Dec 20, 2010 | The Times ROYAL TC100 TimeMaster Time...
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
Setting date and time, I put in correct date but doesn't stick ,
Start by pressing down on the clock/calendar button for about 3 seconds. Then press the equal ( = ) sign to input the correct date. Same process for setting the time. then press the ce/c button to clear the data on the screen. When u want to print the date, press the calendar button. this will automatically print it. then press the ce/c button again so u can start calculating.
Apr 08, 2010 | Canon MP-11DX Calculator
Will not print date 11-19 sample
the month shown.
shown.
card is inserted.
printing.
Press Select to confirm the Print Method chosen. Press Mode to return to normal operational. hope this work for you best regards happy holidays : - )
Nov 19, 2009 | The Times ROYAL TC100 TimeMaster Time...
How do I print a date format with sharp el 1801PIII?
To print the current date press once the Clock/Calendar key and then press once the Non Add/ Subtotal key (# key)
To print out any other date (or codes and other numbers that are not part of a calculation) just type it and then press the Non Add/ Subtotal key (# key). The date/number will be printed preceded by the # sign.
You may also want to download the SHARP EPL-1801PIII Operation Manual
Jun 04, 2009 | Sharp EL-1801P Calculator
Date & time
See the instructions under "NON-ADD / SUBTOTAL KEY" in the third column of the first page of this manual: http://files.sharpusa.com/Downloads/ForHome/HomeOffice/Calculators/Manuals/cal_man_EL1801V.pdf
Aug 11, 2008 | Sharp EL-1801P Calculator
I have the same problem I can not change date and time
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
NOTE: If unsuccessful attempts to set the date and time have been made,
please first confirm that the piece of paper/plastic in the battery
compartment on the bottom of the unit has been removed. Then reset the
unit by inserting the tip of a ball point pen into the "RESET" hole on
the bottom of the calculator. The calculator should be on and in the
"Print" mode so that you can hear the calculator reset.
Aug 09, 2008 | Canon MP-25DV Calculator
Helps with time - - - - what about date - that doesn't seem to work
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
Jun 25, 2008 | Office Equipment & Supplies
Cannot set the date on my Canon P23-DH V calcualtor
ok, have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved. do the same for time.
Nov 30, 2007 | Canon P23-DH Calculator
Sharp EL-2630P Calculator Logo
547 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
