Question about Linksys Wireless-G WRT54GS Router (e125894)
My cell phone won't connect to my router with out help.
I need to up date router (WRT54G-TM) for my T-Mobile phone is this the right place to do that? Or do I need another web sight.
    Genius:
  • 1,269 Answers
You need to download the firmware from linksys.com/download then save on your computer.
To update the firmware, here's the step
1. Open Internet Explorer, type http://192.168.0.1
2. It will prompt your for username and password. Type admin on both.
3. When you get to the router's Setup Page, go to Administration, then click the sub-tab Firmware Upgrade.
4. Browse for the firmware that you downloaded and hit Upgrade button.
5. When its done, power cycle the router. Just unplug it for 10 sec and replug it.
It should be updated now.
Posted on Jan 20, 2009
Can't get access limits to work
there is no internet connectivity
check your router ip adress
check the computer ip adress is same range of router ip
if not,, please assign same range of router ip manually
please letme know this helpful
Jan 07, 2011 | Linksys WRT54G-TM Wireless Router
I'm trying to set up Wii with a wrtu54g-tm router. will it work? So far no luck. do I need a key?
Yes it will work, and yes you need to know your key (WEP) After you connect you have to download "opera" so you can browse the internet though.
Your network should appear on your TV screen and it will display your network name (SSID). Select your network and click connect. When asked, type in your network key. Your Wii will then connect.
Apr 20, 2010 | Linksys WRT54G-TM Wireless Router
I can connect the internet on my wii with this
**I m not able to find a snapshot of the router interface. But i ll tell you what all to do there
1) Disable the router's inbuilt firewall
2) Enable DMZ for your Wii's IP address; assign this same IP address on your Wii manually
3) Change the bandwidth of wireless to 20/40MHz
This will surely work
Jan 17, 2010 | Linksys WRT54G-TM Wireless Router
No print sharing. Existing but lder Belkin router has no problems, but WRT54g-TM will not print share. Have a Netgear switch box as well, can I integrate the two or even all three to solve print share...
If you are using a belkin router, wrt54g-tm and netgear switch box. Basically they won share the printing. you need a wireless print server..try the linksys WPS54GU2
Jul 28, 2009 | Linksys WRT54G-TM Wireless Router
I have a WRT54G-TM with a flashing green power light
factory reset the router and update the firmware on the device prior to configuring it for anything else. Once updated and able to login consistantly, you should be ok.
Latest fw code is:
01/09/2008
Ver.5.00.38
and can be located here:
http://www.linksysbycisco.com/US/en/support/WRT54G-TM/download
Jul 18, 2009 | D-Link AirPlus DI-524 Wireless Router
I hav a linksys router wrt54g my computer and laptop work fine but my cell phone doesnt unless i remove security from my router
Some older mobile phones don't recognise some of the newer security settings (WPA2, for example).
It might be worth trying a different type of encryption (WPA/PSK or WEP) to see if these work better - obviously this would mean having to reconfigure the wireless connections on the computer and laptop.
Hope this helps.
Jan 21, 2009 | Linksys Wireless-G WRT54GS Router...
Necessaty of sim card
If you will just use the router for internet via wireless there is no need for you to have a sim card. The sim card is use for the telephone feature on the router, you will be charge based from the providers rates.
Dec 23, 2008 | Linksys WRT54G-TM Wireless Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Router model WRT54GS . I cannot install the router. I cannot configure it. A message appears saying . You need to download and install w1-f1
Tell me operating system and your hardware revision like :
1.1 WRT54G
1.2 WRT54GS
1.3 WRT54GL
1.4 WRTSL54GS
1.5 WRT54GX
1.6 WRT54GP2
1.7 WRT54GX2
1.8 WRT54GX4
1.9 WRT51AB
1.10 WRT55AG
1.11 WTR54GS
1.12 WRT54G2
1.13 WRT54GC
1.14 WRT54G3G Mobile Broadband router
1.15 WRT54G-TM
If you don't know no problem but it helps me to solve it more quick ly. Contact me again
Thanks
Mar 28, 2008 | Computers & Internet
Linksys Wireless-G WRT54GS Router (e125894) Logo
43 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
