Question about Konica Minolta PagePro 1350W Laser Printer
Printer makes streaks down the side of the paper when printing
I called a local repair shop - the printer needs new components.
Thank you for the follow up.
Posted on Jan 19, 2009
How do i stop my printer from leaving ink streaks down the right side of my pages?
I was going to suggest removing the fuser and looking at the rollers, but on this printer it's a major operation.
Instead let's run the half test. Put paper in the manual feed tray(tray 1). Print to the printer. When the sheet of paper gets pulled about 3/4 of the way in, open the top cover. Pull out the toner cartridge. Look down at the paper. Does it have a streak down the right side? If yes, replace the toner, if no, have the fuser replaced.
Oct 21, 2010 | HP LaserJet P2015dn Printer
Black ink streak on left side of paper on hp 1012, just put in new toner
Run a half test.
Send a print job to printer. When the paper gets 3/4 of the way into the printer, open the cover. Pull out the toner cartridge, look down at the sheet inside the printer. Does it have the streak on the left side? If yes...your toner cartridge is bad. If no...replace the fuser.
Oct 21, 2010 | HP LaserJet 1012 Printer
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
Light streak down 1 side
turn printer on/off, unplug, plug in, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck.
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above.
hope this helps and good luck
Apr 28, 2010 | Brother HL 1240 Printer
I'm getting a streak of ink down the paper
change a toner.
when you have the toner out. clean the heater element (glass). make sure the printer is off and the heater element is cool before you do this.
May 14, 2009 | Dell 3100cn Laser Printer
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
My Olympus P400 Printer comes out with streak on the left side
If a hard reset of printer electronics does not restore proper operation there may be an inherent defect in the unit causing this.
Sep 05, 2017 | Office Equipment & Supplies
Lines down both the left side of the printouts.
good day,
this usually occurs when you print large volume of copies of documents that goes beyond the printable area of the paper, some powders stick in the roller of your printer hence making the gray streak.
you can check if the rollers have accumulated some powder, if so, have the rollers cleaned.
i hope this will help.
Oct 14, 2008 | HP LaserJet 4L Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
Konica Minolta PagePro 1350W Laser Printer Logo
82 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
