Question about Konica Minolta DiALTA CF910 Copier
SADF Mode problem
My machine is stuck in the SADF Mode and is not responding to turning off in order to reset. How do I turn this mode off?
  • Konica Minolta Master
  • 6,825 Answers
SADF Single-sheet auto document feeder. It is used to feed single document on the right hand side of the doc-feeder.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 29, 2010
There is a door for auto feeding documents to be copied, I found it was a little ajar. I closed it, and voila, everything worked again. SADF = aemi automatic document feed. This isn't the same as manual paper feed.
cheers, troy
Posted on Feb 02, 2010
  • 4 Answers
Try turning off the machine, pushing and holding the utility key and turning it on, don't take your finger off the key. You should see a blank screen with one touch button on it saying Trouble Reset. Press it, if the machine doesn't reset itself turn it off and one again.
Posted on Aug 26, 2007
Irola tablet stuck in airplane mode.can't turn off airplane mode
You have to do a hard reset its not seing your sim card ask me how if you don't know how
Jan 29, 2016 | Cell Phones
I got an Error code (E000001-0101) for the Canon iRC4580 series. how do i fix it? need urgent answer
  1. you have to access service mode by pressing these buttons in order.
  2. additional functions
  3. 2 & 8 at the same time
  4. additional functions again (press reset and try again if screen doesn't change)
  5. screen changes to service mode
  6. press copier/function/clear/error then ok in the lower right corner
  7. turn machine off and on. If the fuser assembly is still good it will reset, if not it will need to be replaced (by a tech)
  8. DO NOT ATTEMPT TO DO ANYTHING ELSE IN SERVICE MODE!!! YOU CAN COMPLETELY DISABLE YOUR MACHINE!!!
Feb 18, 2015 | Canon Office Equipment & Supplies
My meile machine is stuck in the descaling mode
When you start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
May 23, 2014 | Miele CVA4070 Coffee Maker
Hayward H250FDN blue temperature control will not respond (MODE and RED up button are OK)
up and down button at same time with either mode or enter at same time for seven seconds that should unlock
May 16, 2014 | Hayward H250FDN Low NOx Natural Gas Pool...
Stuck in the C6400 Error and cannot get out of it, nor print anything. My printer is a KYOCERA KM-1820. Any assistance would be appreciated.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 31, 2011 | Kyocera Copystar CS-1820 Black and White...
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
Cannot print received faxes
I am going to send you several things. Check all of these,
There will be directions on Secure fax, it should be disabled, Delay fax , disable, how to print out a secure fax from memory. You want ECM mode to be ON, and please TURN OFF junk fax. Here are the steps, it will be in several posts.
First secure fax. I doubt you have a password.
Know what, I just thought of this. In order, press "menu #1934. You will enter the tech diagnostic mode. Press your machine status button , scroll to maintenace and perform a memory reset. In tech mode it will default items that the uses reset will not.
  1. Press the [Menu / Exit] button on the Control Panel. 'System Data' will be displayed on the Display Screen.
  2. Press the [Down] arrow button until 'System Setup' is selected, and then press the [Enter] button.
  3. Press the [Down] arrow button until 'Secure Receive' is selected.
  4. Press the [Right] arrow button to select [ON] or [OFF], and then press the [Enter] button.
  5. If 'OFF' is selected, skip to step 7. If 'ON' is selected, 'EnterPasscode' will be displayed. Enter the 4-digit passcode using thenumeric keypad, and then press the [Enter] button. 'Confirm Passcode'will be displayed.
  6. Enter the 4-digit passcode again, and then press the [Enter] button.
    NOTE: If the passcode is unknown, contact your System Administrator.
  7. Press the [Stop] button to return to the Standby mode.
Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
Stuck in Test Mode
try to flash phone with latest version from rep . centre
Jul 31, 2008 | Nokia 6233 Cellular Phone
Miele cva4070 coffee system
The above solution will not work when the machine is stuck on the cleaning cycle. You can plug and unplug it all you like but it will still come back and be stuck on "Cleaning" when you turn it on. I called Miele service and was guided through the steps to access program mode in order to cancel the mode. This is how you do it:
First turn it off using the switch inside the machine (top left with door open)
Note, the four following steps have to be completed within 10 seconds:1 Press the Clear button and hold2 Then press the On/Off button3 Release both buttons at the same time4 Press the clear button 5 times in a row
This gets you into Programming Mode (may take a second or two to pop up if you complete the above in less than 10 seconds
Keep pressing the "More" button (bottom right) until you get to the last page where it will give you the option of reseting the three cleaning modes. Just push the right one ("Cleaning" for e.g.)
That will do it but if you have an underlying fault that interferes with Cleaning then the same problem will happen again when the unit needs cleaning. You should get a service call to address this.
Jul 04, 2008 | Miele CVA4070 Coffee Maker
Konica Minolta DiALTA CF910 Copier Logo
321 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
