Question about Dishwashers
Maytag dishwasher model #PDB3600AWX prongs rust & disintegrate
I have twice replaced the complete racks and the problem continues to happen. I have tried calling the manufacturer but because there is no recall on product and I am no longer under warranty (although problem originally started when product was still under warranty-they replaced racks once but warranted those racks from date of replacement). Please let me know what I can do to prevent, stop or get a replacement as I am expecting a baby soon and worry about the rust getting on the baby bottles.
Sincerely,
Kathy Sheets
  • Anonymous Mar 02, 2009
    I have a similar model Maytag PBD2430AWX.
    The top and lower racks have rusted terribly. The lower rack is worse and entire tines/inches of steel have broken off. I've checked into replacement racks at various retailers and they are fairly expensive (~$118-140 + shipping). At partselect.com, 133.10 w/shipping for the upper rack only. I'd hate to buy parts I know will fail quickly for that price. Are there alternative parts for Maytags made entirelyof plastic and not coated steel?
  • Anonymous Apr 20, 2009
    I too have the same issue, plus the pump has now failed... !
    Scholar:
  • 39 Answers
Getting a replacement set is not hard www.partselect.com has the part. If you don't want to spend the money you might try scraping the rust off of the prongs and then use a high temperature rated epoxy product to dab a new covering over the exposed steel. That might last for awhile. I'm guesssing. I think it needs to be a covering that can stand high temperature with a rating of at least 200 degrees or better and a chemical and humidity resistance rating. An electrical conductivity rating and thermal conductivity rating are not required. Its a patch but it might work Ok. I don't think the rust will get on your bottles but the prongs will weaken and break after awhile so if you can stop the rusting that will help you get more life out of the racks.
Posted on Jan 14, 2009
I've cleaned off the rusted areas and just put shrink tubing over the rusted prongs. Shrank down tubing and all is well and waiting for next fix.
Posted on May 28, 2013
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Dishwasher replacement part
Instead of replacing it you might try re-coating the rack with Plasti-dip. Available at some hardware stores.
Nov 15, 2009 | Dishwashers
Nearly every time is disintegrating and crumbling off with rust
ur goin to have to make the choice but usually when the rackes are getting rusty its had a good long life and prolly should get a new dishwasher
Oct 31, 2009 | Frigidaire FDB658RA Built-in Dishwasher
Maytag Quiet Series 300 smells broken door latch and lower rack
I have had the same problem and there is a simple fix.
The problem in my case was the floating water sensor was stuck and gummed up with grease.
On the bottom of the dishwasher, in the front right corner there is a round doughnut-looking thing. This is the water level sensor. It is open on the bottom, and grease collects there.
When this happens, the air pocket is too small, and the float won't float. then the dishwasher overflows. To clean it: just reach under with your finger, and scoop out the grease.
Sometimes, after doing this, the float then gets stuck in the "up" position. When this happens, the dishwasher completely drains, and the heater element for the dishwasher is exposed, and food cooks onto it, and that is where the smell is coming from.
Sep 05, 2009 | Maytag 24 in. MDB5651A Built-in Dishwasher
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Feb 05, 2009 | Maytag 24 in. PDC3600A Built-in Dishwasher
Our Maytag dishwasher, mod MDB9150AWS, has abad lower rack due to rust and prongs coming loose. Maytag sent me a replacement BUT without the center spray tower. It looks like trouble to remove the old...
Yes, I resolved the problem after thoroughly studying the assembly. It was relatively simple; all I had to do was turn the spray tower 90 degrees and it came free of the rack.
Thanks for the web site, nonetheless.
Aug 27, 2008 | Dishwashers
Rollers on racks continue to break, Maytag fix is buy entire new assembly like part number 99003585 wihich is 32.95 each time
I found an engineer who has made stainless steel axels for the rack...www.fifengr.com/maytag/....a cost of $40...but well worth the one time solution....
Aug 22, 2008 | Dishwashers
Rusty racks
Check your warranty to see if it covers your racks. Some models have a longer warranty against rack rusting if you have Duraguard racks. If they are Dura guard racks and still under warranty, Maytag will replace them at no charge.
Nov 02, 2007 | Maytag MDB7100AWB Dishwasher
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
853 people viewed this question
Top Dishwashers Experts
