Question about Dryers
Wont blow hot air
I have a estate dryer and it wont blow hot air and also it was running all nite long Dryer keep on running without hot air
  • cdpaul2003 Jan 14, 2009
    You were right. I found the element broke, Where is is available for $30? Please advise, what will happen if I tie the broken part tgether and reuse it?
    Problem Solver:
  • 6 Answers
Heating element failure 30 bucks and an hour of labor
Posted on Jan 14, 2009
  • moparman910 Jan 15, 2009
    it may be more or less than 30.00 should be able to find one by going in phone bookunder appliance repair and parts and find one locally
No heat blows cold air, what is problem?
Check circuit breaker box Turn your dryer breaker off and then back on (reset) . If this doesn't help, does the dryer light go on
when opening the dryer door? Could be the High temp cut out
safety device because it's getting too hot.
Mar 16, 2015 | Estate Dryers
Drier is running hot, smells like my clothes are burning, and it keeps blowing the fuse in the main panel.
Most probably a venting problem and probably caused the heating element to ground out in its casing. Easiest way to verify is turn your timer to 30min and if dryer starts heating without pushing the start button you got a bad element caused by bad venting most of the time.
Apr 16, 2013 | Estate TEDX640JQ Electric Dryer
The dryer runs but will not blow hot air
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
Feb 04, 2011 | Whirlpool LEQ8000JQ Electric Dryer
The dryer hose fills with water, the lint trap never catches anything and the roof of the dryer gets hot but the clothes wont get dry. Any ideas? Thx
It sounds like you have no fan blowing. OR the vent is completely blocked so no air flow.
You could check fan by disconnecting the vent hose in back, and turn dryer on. Is is blowing a good volume of air? If so then you need to look at the vent. Any critter build a home in there? etc..
If there is no significant air blowing from the vent, you'll need to figure out why the fan is not blowing.
It's possible the fan is turning but is choked up and unable to move the air.
Perhaps the fan is bad, or there is a capacitor gone bad,.
That's as far as I can go from here.
Others may assist you further..
Dec 04, 2010 | Estate TEDS840JQ Electric Dryer
Estate TGDS680EQ3 gas dryer blows cold
The timer is stripped inside and needs to be replaced. The cogged teeth are made of plastic and a tooth or two has broken off keeping the timer from moving while running
Jul 16, 2010 | Estate TGDS680EQ Dryer
Our dryer does not blow hot air? The cloths do not
more than likely the heating element has gone out. if your clothes have no heat then the element is the most likely cause. you can get one for anywhere between $30 - $50. you'll need to know model and serial #'s. usually easy to replace.
Jul 30, 2009 | Estate Dryers
Dryer doesn't stay hot
Probably 95% of the time this is from the gas valve coils. The part # for a kit with both coils is 279834. You can try unhooking the vent from the back of the dryer to eliminate the venting as a problem. If it runs ok without the vent hooked up that is the problem. If it still won't keep heating thru the cycle replace the valve coils.
Jun 16, 2009 | Estate TGDS840JQ Gas Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Blows fuse for heat after about 30 minutes
yes , occassionally though it will run for full cycle ....but not very often
Sep 06, 2008 | Kenmore 73952 Gas Dryer
Wont blow hot air
check that you have 240 volts to the dryer terminal block
if so check the element and the element thermastats
May 07, 2008 | Estate EED4300SQ Dryer
Dryers Logo
246 people viewed this question
Top Dryers Experts
