Question about Grohe Plumbing
Grohe Ladylux slow to turn off
I purchased a Grohe Ladylux about 2 years ago and LOVE it. Except, after having been away a year, I returned home and noticed the faucet is slow to turn off. The house was lived in during the year, so it shouldn't be a lack of use issue.
Basically the faucet turns on normally, but when you turn it off it was to trickle off like a hose. Once it stops running it does not continue to drip. Is there a valve or something inside I need to replace, for the price of a Grohe, I wouldn't have expected this to happen so quickly!?
Your Grohe Ladylux should be under warranty. Call the company at 630-582-7711. Their customer service was great when they replaced my quick coupling after it broke.
Good luck
Posted on Feb 24, 2009
  • twumps Feb 14, 2011
    I had the same problem - turned out to be some scale bits in the nozzle. Just take apart and clean the nozzle and this may fix the problem.
I want rotate my Grohe ladylux kitchen faucet. The handle is on the left and I want to rotate to the right side. How do I do it? Thank you John
You will presumably be pushing the faucet handle away from you instead of pulling it forward? If you don't like it, you can always put it back.
Turn off the water.
Release the water in the faucet. If you have a faucet in a room on a floor below, open that to drain the water.
From underneath the unit, back off the nut that is gripping the worktop. Slacken off the hot and cold supply pipes. I am hoping you have braided flexible hoses, or you can't do this job very easily.
Spin the faucet 180'.
Retighten the hold and cold supply pipes.
Retighten the holding nut.
Turn on the water and open the faucet.
Check for leaks.
There is an installation video here.
https://www.youtube.com/watch?v=sQgi0CMAxYM
and some further information and diagrams here.
Removing Grohe LadyLux Caf 33 755 Faucet Handle
Jan 02, 2016 | Grohe Plumbing
I have Grohe Ladylux and the flow will arbitrarily switch from stream to spray on its own.
Mine would stick in the spray setting. I soaked the whole head in vinegar to clean it and the problem went away.
Oct 05, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
How do I set the spring tension on a ladylux kitchen faucet with pullout spray
Personally, I didn't think it was supposed to. I assumed the spring was a form of stress relief for the hose as it nears the pass-through.
Sep 12, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
I have a grohe ladylux that is almost 3 years old. the water pressure is low. When i unscrewed the head water flows well, but when the head is back on it rens slowly. I,ve cleaned the screen by unscrewing...
On this particular faucet you may not be able to reach the part that might be giving you issues in the spray head. However, to take the head apart, on the spray face you will turn it counter clockwise, the aerator will come out at that point and you should be able to see down into the tube to see if there are any obstructions. Also if you are using the little Grohe water filter that goes into the handle before attaching the hose, it is possible that that is clogged especially after 3 years. You should be able to remove that altogether, or contact Grohe for a replacement. If once you have removed all of these and have found no removable obstructions, then the only other thing to do is contact Grohe for a replacement spray head which I believe they are still available. Hope that helps.
Aug 18, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
I have a Grohe Ladylux Plux kitchen faucet that was installed 5 years ago, and it is now loose. There isn't a way to tighten from underneath and the installation directions called for using a tool to...
you can pull the faucet arm off, the part right on top of the base , if my memory serves me correct you can tighten it with a creset wrench and the neck will pop right back on after
Aug 04, 2009 | Grohe Plumbing
Grohe ladylux plus is leaking
I believe there is a cartrige that has some washers in the unit. There may be some debris caught in there since it was a little loose. I would turn the water off and disassymble the unit and replace any obvious washers and clean everthing up. Replace it all and try it again. If it still leaks, contact Grohe for more trouble shooting. Faucets have fantastic warranties and companies usually will send replacement parts free of charge at times. Hope this helps.
Apr 06, 2009 | Grohe Model 28 206 OOO: Ladylux Plus...
Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Dec 10, 2008 | Grohe Plumbing
Plumbing Logo
710 people viewed this question
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
