Question about Sony XR-C7350X Cassette Player
I have an old 96 s10 and it had an older sony xplod in it and it was stolen out of my dash. There is a wire harness with a total of 14-pins. But its split into 3 parts, two have four and one has 6 and i cant find a wiring diagram anywhere for this harness
  • 15,935 Answers
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Front Front Speakers 4" x 6" Dash Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 6 1/2" Front Doors Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
Posted on Jan 14, 2009
Wiring diagram Sony xplod cdx-gt33w for 96 saturn sl2 what wire can I use for a remote the harness kn car has no ground so antenna is ground and I have to blue wires left
So you have 2 blue wires left? Are you wiring an amp? If so i would try either or....one is probably amp turn on and one is power antenna
Jun 11, 2016 | Sony Car Audio & Video
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
I HAVE A 12 PIN CONSOLE WIRING HARNESS UNDER DASH TO HOOK UP ALL THE GUAGES COLORS ARE AS FOLOWED PIN 12 BLUE 1DK BR 10TAN 9 BABY BL 8BL WITH WHITE STRIP 7 PINK 1LT BR 2 GREEN 3GREY HOW WOOD I HOOK THEM UP...
mcdevito75 here, I would simply compare the pins on the new dash with the old dash. Or compare the new wireing harness with the old, compare the wires at the connector itself, compare both connectors the new harness and old.
Jul 16, 2010 | Mattel Hot Wheels Color Shifters Car '67...
I have a 1995 Pontiac Grand am and it had and old *** cassette player now i"m trying to update it with the sony CDX-GT24W and the wiring colors are totally off. My repair manual tells me what the wires in...
yellow is constant and the red is the acc, black of corse is brown
the matching colored wires grey purple.....
all corraspond to each other
goto sony.com and find the support page find any cd players manual and it should have the exact wiring guide for the sony harness , all of them are the same, they only change with brand i.e pioneer, aiwa, jvc.....
Jul 16, 2010 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Replace stolen radio thief cut wires in dash need color codes for speakers and power sources for a 1990 honda civic
I have had the same make model and year car that had different color wires, and it seems weird like they ran out of wire making the car but give this a try. Use a voltage meter to check for power to be safe.
http://www.the12volt.com/installbay/stereodetail/1044.html Good Luck
Mar 24, 2010 | Sony Xplod XM-1652Z Car Audio Amplifier
I am trying to wire a sony xplod deck to my 2001 altima and need to know which wires connect to each other and steps of doing that.
Hello charlieramir,
The wiring color code for the 2001 Altima can be found here. Your Sony deck should have come with a wiring harness and an installation sheet (or a page in the user manual) that shows the color and function of each wire. You simply match up the functions of each wire on the harness with the appropriate wire on your vehicle.
A simpler and more professional installation is achieved by using a vehicle-specific wiring harness that plug into your Altima's wiring. Such a wiring harness allows you to make all of the connections while seated at the dining room table or other well-lighted location instead of the limited space area behind the dash. The Scosche NN03B/NN03 seems to be the correct harness for your Altima.
Hope this helps.
Jul 02, 2009 | Sony Car Audio & Video
Wiring color meaning
did you buy a factory radio connector to connect the old harness to the new radio wiring if not you can get one at wall mart for 20 dollars and it will be color coded
Mar 08, 2009 | Sony XPLOD CDX-GT200 CD Player
Stolen faceplate
the GT-200 is the cheapest of the sony line. A new radio can be obtained for under $50. A faceplate direct from sony would be approximately the same amount. Check eBay or Craigslist for a used one.
Dec 21, 2008 | Sony XPLOD CDX-GT200 CD Player
Car amps
important is to hav correct wires and groud cable...
Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony XR-C7350X Cassette Player Logo
64 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
