Everytime I connect my Samsung Pebble MP3 player, it doesn't show any music files. And it only shows about 2MB of memory left. When I try adding music files, it only allows me to add 3 or 4 files. When I try to play the music on the MP3 player, it beeps in the way it should when there isn't any music on it.
  • roleykrazy13 Jan 14, 2009
    I have a Mac =]
    Lol. and yes, the Pebble DOES work with the Mac.
    Anyway, when I plug it in, the removable file appears on the desktop.
    I always added the music the same way and it always worked.
    Suddenly when I erased all the music files it had, so I can replace them with new files, they never appeared and then the available space said "2MB"
  • 26 Answers
Hmm pretty weird try plugging it up to your computer then right click start and click explore then look for a letter that represents your mp3 like say removeable disc :H and if its your mp3 player drag your music into there.
Posted on Jan 14, 2009
If we add songs to mp 3 player it won`t show songs when it on
MP3 players can only play music files that have been converted to mp3 file format. For instructions on converting music file, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Nov 08, 2010 | Sony NW-E405 MP3 Player
USB Port Not Recognized
Here Two Reason for USB Port Not Recognized:
1. Check you USB cable properly connected to the you computer, If cable break or not connected properly, It will show your cable not recognized.
2. If again these problem shows. go to,
My Computer - right click - Properties - Hardware - Device Manager - and Unistall you USB drivers - then again scan new hardware.
Jan 29, 2010 | Emerson BAR900 MP3 Player
Lost all my music and i want it back :(
Try this method to see if the music is still on your player.
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible.
If you want to delete any music/files/pictures then do the following:
Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete"
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
Dec 04, 2009 | Apple iPod classic MP3 Player
DOWNLOADED MUSIC ON THE PLAYER BUT WHEN I TURNED IT ON IT SAID NO FILE AND SHOW NO MUSIC. ITS THE SAMSUNG YP-U2 mp3 player....any solutions please
Try to locate your files this way, it will show if there is any music/files on you MP3 player...
Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible if there is any on your MP3 player.
If you want to delete the songs or files you will do the following:
Good Luck,
I hope this helps
Nov 19, 2009 | Samsung YP-U2X Digital Media Player
Cant play the music
Add music to I9
Connect your i9 to your PC via the USB cable.
On the phone select "Mass Storage Device".
On the PC you will see 2 new drives appear.
One will be the SD card. The other is the Phones internal memory.
Now just simply copy your MP3 files to the Memory card folder "My Music".
Do not use the phones internal memory as it just is not big enough.
The Audio player will only play music from a folder called "My Music" or "MP3"
depending on which firmware version you have on your i9. If one doesn't work try naming it the other!
Also make sure you are selecting the right storage area in the Audio player options, either the phone
or the memory card, because there can be identical music folders on both, and if you don't choose the
correct storage location, your music files still won't show in the Audio player!
Make sure the audio file is in a format the i9 can play. Known music file types are mp3, wav, amr, m4a, & mp4.
DO NOT place music in sub folders within either of the My Music or MP3 main folders, the Audio player
will not find them unless the music files are directly within the proper My Music or MP3 folders!
Every time you add new music to your i9 you will need to refresh the List in order for the audio
player to see all the newly added songs. To do this open the player. Tap "List" at the bottom of
the screen. Tap "Options". Tap "Refresh list". You can also go into the audio player settings &
turn ON the "List auto gen." option. If the option is ON, then after you add new music, the new
music should be added to the entire list of music already showing. If you have problems with the
music list showing up empty, or new music you have just added not showing up in the current list
of songs, then try turning OFF the List auto gen option and refresh the list manually again by using
the Refresh list option as described earlier. Manually refreshing the music list must be done every
time you add new music files to the phone if the List auto gen option is OFF.
You get to the List auto gen option by two ways with the Audio player open and onscreen
for most i9 firmware (some firmware might not have it, or may be in another area);
1.) Tap the little wrench icon to the far right on the black option panel,
then scroll down to the List auto gen. option!
2.) Tap the List option at the bottom of the screen, tap the Options button
screen, tap the Settings button, scroll down to List auto gen.
Apr 15, 2009 | Dual Electronics CECT P168 Cellular Phone
My sansa e260 shows full memory in its screen
Connect Sansa to computer
Double-click "My Computer" icon
Double-click Sansa icon (shows up as "Removable Drive" on some computers)
Select Tools --> Folder Options --> View --> check "Show Hidden Files and Folders"
Double-click Music folder
You should see your music files - you can delete at will.
Or:
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Mar 17, 2009 | SanDisk Sansa e260 MP3 Player
Player memory is showing as full but can't find any files
I'd say, either (on the sync tab) right mouse click it and choose the refresh option. If that dosn't work; try to used Winamp instead.
Aug 04, 2008 | Sony Walkman NWZ-S616F MP3 Player
IRock 860
I have an 860 I'm trying it now. Actually I was on trying to find the original software which seems to be nowhere. Saw your question and thought I'd try ITunes.
Jul 07, 2008 | FID Irock 830 128 MB MP3 Player
"No File" troubleshoot
you didnt safely disconnect your mp3 player so you corrupted your mp3 files you need to reformat and start over with your music and do update before adding music to mp3 player
May 01, 2008 | Samsung YP-K3 MP3 Player
Adding Music To My Sansa e250
I never use Windows Media to add music to my sansa... If you want all music to show up click on my computer and then click on the icon for your sansa. there may be a folder that says music but if not it is a hidden folder. if this is so you must go to tools, then folder options, and then the tab that says view. under this will be an option that says hidden files and folders and click show hiden fles and folders and OK. this should allow you to see the music folder. from here on you can just copy and paste all files.
Feb 10, 2008 | SanDisk Sansa E280 MP3 Player
124 people viewed this question
 Grubhead
Grubhead
