Question about Symbol LS 2208 Barcode Scanner - P/N LS2208-7AZU0300SR Handheld Barcode Scanner
Programming LS 2208 Scanner
I have used the LS 22208 Symbols Barcode scanner to read VIN numbers from automobiles. I lost the programming guide to do that. Can you help
5 Suggested Answers
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
  • 25 Answers
SOURCE: Symbol LS 4278 Barcode Scanner - 3 Clicks
Does it beep each time you pull the trigger while the beem is on the barcode?
Posted on Jan 23, 2008
SOURCE: symbol ls 2106 handheld scanners
I cannot get it going on the pc with windows xp pro
Posted on Sep 14, 2008
SOURCE: How can enable Barcode Scanner ??
You have to use a program which will activate the scanner.
You can use DataWedge, which will send the scanner input to whatever has focus: https://docs.symbol.com/KanisaPlatform/Publishing/968/KB100417_f.html
Posted on Oct 07, 2008
Have an online manual for LS4004 I000. How do I get the scanner to transmit an enter key after scanning a barcode?
try reprogrammimg, it should default after it scans an item to enter whaT WAS SCANNED
Jan 31, 2013 | Computers & Internet
SPACE problem. Hello i have Symbol LS 2208. I need remove space/gap from this code 09/ 5864 I tried to create rule for this (remove all spaces) but it wasn´t work - the scanner scaned no data. I use...
Hello, if all your barcodes have the same structure, it will an easy task. You would need to scan following barcodes from ADF chapter in the Product Reference Guide located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Create New Rule Send Characters Up To Space Character in Alfanumeric Section Skip Ahead 1 Send All That Remains Save Rule
This will by all scanned barcodes send all characters up to the space character, skip the space and send the rest of data.
Oct 22, 2010 | Symbol LS 2208 Barcode Scanner - P/N...
Symbol 4000i scanner will not scan barcodes that are single digit
Hello Jane Diaz,
the scanner has several barcode types enabled by default. Other type or lengths must be activated with an programming barcode from the Programm Reference Guide for LS4000.
Please check which kind of barcode are you using. Download the Program Reference Guide from support.symbol.com Scan the barcodes from the chapter Symbologies
Oct 13, 2010 | Symbol LS 4000i Handheld
Scan a single digit character
i have problem with when i goint to scan after 5 or 10 minutes after it disable, and then we go to connect and disconnect to work
Nov 25, 2009 | Symbol LS 2208 Barcode Scanner
Hello! I have a problem with scanning bar codes by ls2208 scanner. This device uses rs232 serial port, and when I try to read some bar code, the scanner is reading, but there is no number in notepad. How...
The scanner is sending the data to the serial port. You need an application to pull that data in off of the COM port. You can test using HyperTerminal. The scanner defaults to 9600 baud, 8 data bits, 1 stop bit, no parity and no hardware or software handshaking. Point HyperTerminal to the correct COM port (most likely COM1) and set it to the settings I just listed. When you scan you should see the data show up in the window.
If you want the data to go into Notepad or any other program expecting keyboard strokes I would recommend the Motorola (formerly Symbol) USB cable CBA-U01-S07ZAR or the CBA-K01-S07PAR keyboard wedge cable.
Jul 13, 2009 | Symbol LS 2208 Barcode Scanner - P/N...
Transfer info from the digital weight scaleto quickbooks
You would need to add an criteria or the rule, like barcode length or type. Than is the the scanner able to understand which barcode should be handled by the specific rule.
Dec 03, 2008 | Symbol LS2208 Handheld
Set up for Symbol LS5000
Hello Fenandez,
there is no driver needed. Just select the programming barcode for the interface (RS232, Synapse,Wand) you want to use on your host device. You would need just the Reference Guide with the barcodes.
Aug 19, 2008 | Symbol LS 5000 Barcode Scanner
How can I restore factry default?
open your programming manual,or setup manual and read the codes return to factory
Jan 31, 2008 | Symbol LS2208 Handheld
Symbol LS 2208 Barcode Scanner - P/N LS2208-7AZU0300SR Handheld Barcode Scanner Logo
328 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
