Question about Fuji Pictrography 4500 Thermal Printer
Error J771 We checked out as much as we could see and it still tells us there is a jam. Please Help
  • 1 more comment
  • todd500 Feb 04, 2009
    The error was J771. We did figure out the problem after awhile of trial and error. It turns out the the tension of the on the belt of the waste intake cartridge was loose. After we fixed that we havn't had a problem or that error message since. Thank you for your response.
  • arnaud monfort
    arnaud monfort May 11, 2010
    J 771, are you sure of the number?
  • arnaud monfort
    do you mean J-791 (residual paper is present or the magazine as not been rest)? J771 doesn't seem to be a "correct" error
I had this error, the refuse bin had a jumble of donor in it. Removing the refuse solved the problem.
Posted on Jul 10, 2009
MY Di2510f is jamming and throwing the code C004E can anyone tell me If I replace the fan will it continue to jam or will it stop the jamming?
Replacing the fan will only help you with that error code c004e. The jamming will be an entirely separate issue. Where is the machine jamming? Fuser area? Cassettes? Document Feeder? Please clarify.
Jul 26, 2012 | Minolta DiALTA DI2510F All-In-One Laser...
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
Xerox 7300 paper jam A 10 error code jam telling me to open top tray and I've looked at the machine inside out and cannot find any scraps of paper or any location where there is any traces of paper being...
There is most likely a small piece of paper in the rollers take out Tonor and any parts that will come out with out having to use any tools. then spray with a can of air in all the rollers.
Chris Thrash
B52Computers
Jan 10, 2011 | Xerox Phaser 7300DN Laser Printer
I have an error that indicates paper jam, open-- imagistics 2500
Check the paper trays sensor,and describe detailated the your problem and please tell me the fax machine models for more help and information.
Sep 17, 2009 | Office Equipment & Supplies
Service error 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
My printer keeps telling me the ppr is jammed
There is a sensor flag either stuck or sticking and it is causing it to give a false jam error
Feb 10, 2009 | Canon PIXMA iP1300 Printer
Code 200 Paper Jam Error
Hi Mike,
This error can be caused by many reasons, some of them are:
Caused by Paper Stuck Under the Second Transfer Roll
Sporadic or Intermittent 200 Paper Jams
"200 Paper Jam" Resulting from a Possibly Damaged Tray
"200 paper jam" When Attempting to Print from Tray 2
To troubleshoot this problem, please click the links with their respective causes.
Please rate it fixya if it was helpful.
Thank you
Dec 19, 2008 | Lexmark C750 Laser Printer
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Docucolor 12 error code HELP
9-357.
Black toner problem.Probably You have low toner sensor defect.
But try first to vacuum and clean black toner dispenser.You must vacuum whole path wich is used to transport black toner to developer unit.Then if printing B/W print only, you must print 10 full color sheets every 100 copies.
Sep 13, 2007 | Xerox DocuColor 12 Color Copier
Fuji Pictrography 4500 Thermal Printer Logo
216 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
