Question about Apple (6612068) Sound Card
No sound from headphone plug
How do I know if I have a sound card
    Genius:
  • Apple Master
  • 1,102 Answers
You have a sound card if your able to plug in your speakers or headphones in , thats your card.
what problem are you having
Posted on Jan 14, 2009
Headphone jack does not work
The headphone jack on the computer connects to the sound card, a hardware device that controls audio input and output on the PC. The card contains a digital-to-analog converter that converts analog audio into digital signals and visa-versa. The performance of the headphone jack, therefore, depends on how well the sound card functions; if the card doesn't work, then the headphones connected to the PC won't output sound. Reconfiguring the audio settings will often fix problems with audio output on the headphone jack, but if the former fails to resolve the issue, replacing the sound card in its entirety is sometimes the only means of repair.
Click "Start." Enter "sound" into the search box. Select "Sound" from beneath Control Panel. Double-click "Headphones." If no "Headphones" option is available, double-click "Speakers." Click "Properties" on the General tab. Check the Device Status field for errors. Look up the message on Microsoft Support for more assistance, if applicable. Close the window if the Device Status field reads "This Device Is Working Properly." Go to the "Levels" tab. Click the speaker button to unmute the volume if the icon contains a red circle-backslash symbol. Drag the top slider to the right to increase the headphone volume. Go to the "Enhancements" tab. Check "Disable all Sound Effects." Go to Applications, and then clear "Allow Applications to Take Exclusive Control of This Device." Click "OK" to close Headphones Properties or Speakers Properties. Test the audio. If the headphones fail to output sound, unplug the headphones from the computer. Reconnect the headphones to the PC. Headphone jacks are color-coded lime green on most PCs. Look for the headphones symbol if the jacks are not color-coded. Plug the headphones into the line-out port on the back of the computer if the headphone jack on the front of the PC fails to work, or visa-versa. Test the headphones. If headphones still won't emit sound, the sound card most likely requires replacement. b> Replacing the Sound Card b> Shut down the computer. Remove the power cord from the back of the PC. Disconnect the keyboard, mouse, monitor and all other peripheral devices. Loosen the screws found on the back of the case, then slide the cover panel off of the case. Touch the chassis to protect the hardware from electrostatic discharge, or ESD. Set the computer on its side. Locate the sound card found on the opposite of the audio jacks and loosen the screw that secures the card to the computer. If no expansion card is located opposite the jacks, the computer uses an integrated sound card which can't be removed. Remove the new audio card from its protective packaging. Line up the card with an available expansion slot on the motherboard, then push the card down into the slot to install the new audio jacks. Screw the card to the computer case. Reassemble the computer. Turn on the PC. Boot in to Windows and insert the CD that came with the new expansion card. Follow the onscreen instructions to install the sound card software to the computer. Plug the headphones into the new line-out jack. Hope this helps.
Jan 21, 2013 | Acer Aspire Computers & Internet
I cant hear nothings on my computer theirs no sound it says theirs is no speakers or headphones plugged in and wel they are plugged in (compaq presario SR5202HM) windows 7 ultimate 32 bit.
are you using a sound Card the presario SR5202HM has this sound setup
Sound/Audio Integrated Realtek ALC888 Audio
  • Audio CODEC: Realtek ALC888
  • High Definition 6 channel audio
make sure that this sound driver is up to date
here is the plugs
4 - Audio: Line In (light blue) 5 - Audio: Line Out (lime) 6 - Audio: Microphone (pink) make sure you have the headphones plugged into the Lime colored plug
if this doesn't work i have some more idea's let me know.
Jan 23, 2011 | Compaq Audio card Sound Card
I have got 2CH speakers idont know where to plug in to the CPU
There are usually 3 audio connectors on a sound card. For Line in, headphone/line out and microphone. The connectors maybe connected to the motherboard or there is a separate sound card.
These connectors are 2.5mm audio sockets - connect the speakers to the headphone/line out (usually green).
If you are not sure which connector to plug the speakers in, just start a audio CD and plug the speaker plug into each socket connector until you get music from the speakers. You will not damage anything if you plug the speakers in the wrong audio socket.
Oct 24, 2009 | Acer X193W LCD Monitor
What is the sound card input on an hp2207?
The Jack which you found nearby the HDMi is a Input jack. you can get a output from your Computer's Audio out to to this input jack the speakers integrated with the moniter make sound. here there is no chance to plug your headphone. if you want you can plug your headphone in the front jack of your computer
Aug 25, 2009 | HP w2207 Monitor
Realtek Sound device problem
i dont have a volumecontrol
Jun 02, 2009 | Computers & Internet
Headphones will not work but speakers will.
Plug the headphones directly into the speaker port on the sound card, check for a mute button on the headphones. try another set of headphones to double check wether the first set is working.
regards..
Apr 05, 2009 | Dell Dimension 4600C PC Desktop
Headphones partiallly work
1. you headphone is a problem(broken)
try to plug it on another computer or television, if the same then get new one.
if it work well with other computer then
2.open volume panel.
double click on the volume icon on the taskbar
there will be headphone icon, if not select option, check all the box, maximize all volume, remember the upper volume control(horzontal) must be in the middle.
or.
if you using realtek, open by double click the icon, and select headphone.
just sharing =)
Jan 06, 2009 | Compaq Creative Sound Blaster PCI 128...
Sound card for emachines w3653
go to your sound card preffersants and change it to your set up .
Nov 19, 2008 | E-Machines eMachines Desktop PC
Audio from speakers when headphones plugged in...
i got the same probem and i am trying to find the solution. it could be that your sound system is different and the right driver is not installed. do you know what is the exact model of the sound card installed as per the laptop specs?
victor
Oct 08, 2008 | Compaq Computers & Internet
Sound card problem in Compaq Presario CQ50-106AU
hi,
It might be bec of driver problem, if you have windows xp then istall driver for it then it vl be solve
thank you,
Aug 26, 2008 | Compaq Audio card Sound Card
Apple (6612068) Sound Card Logo
89 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
