Question about Jenn-Air Cooktops
Solid element cooking top slow in heating up
Jenn Air 2 burner cook top part 105-8 works but takes longer to heat up and we must turn up dial to a higher setting to achieve the same results.
Since this top is no longer available, are there any replacement parts I should be looking at to fix this or is it time to replace with a new cooking top?
    President:
  • 1,214 Answers
It sounds like you have lost 1 leg of 220V power to the unit. Chances are, one of the elements shorted to ground, then blew itself open.
Find the breaker or fuse box, and reset/replace breakers/fuse. If it blows again, you'll have to locate which element is bad, or where the short is.
I can help more once I know if there was a breaker trip, or fuse was blown. I will also need to know if it is one element, or all the elements., that exhibit the same problem. I can instruct you on identifying the bad element as well, and replacement elements are available.
Posted on Jan 14, 2009
I have a 4 burner Jenn-Air JED8430ADB electric radiant heat stove that has recently stopped working. It has been installed for many years (came with the house) and worked fine until now. When I turn one...
The cook top is connected to 220 volts. In the house wiring there are two legs each 115 volts. Usually they connect with a red wire, black wire and the third a neutral. It is likely that at the connection to the unit or at the electrical box a connection has failed or the 220 volt circuit breaker has failed on one leg. A qualified electrician needs to do the repair!
project1-nbbnxwvnfadegsi2zsme4jri-2-2.jpg Hope this helps?
May 04, 2017 | Jenn-Air JED8430 Electric Cooktop
Jenn Air ElectrCook top One of the cook top heater is not working
well it can only be a few things on a cooktop... u either have a bad element or a bad switch.......usually on most to replace either u must lift top up and out and remove the screws all the way round to open unit up...hope this helps let me know how it goes
Feb 26, 2010 | Cooktops
Constant heat not produced on Jenn Air Schott Ceran stove top
It's a piece of ****, replace it the first chance you get.
Dec 26, 2009 | Jenn-Air JED8230 Electric Cooktop
All cook top burners spark when any is turned on
OK, the best action is to call for service, if the unit was just installed, and purchased. This unit should be covered at this time, by the manufactures warranty, or store 30 day warranty. This repair should be free. The culprit will be a faulty spark ignition switch, and module. Testing is required. Once this switch, or(module), is replaced, the unit will operate correctly.
Nov 04, 2009 | Jenn-Air JGC8430 Gas Cooktop
Jenn-Air surface cooking elements look rusty and ugly
they make a special cleaner - polish just for the "solid" type burners. it looks like shoe polish and will make the burners look like new again. not sure where you can find it online but go to your local appliance parts houseand they will know what it is your needing.
Dec 27, 2008 | Jenn-Air JED8230 Electric Cooktop
Both burners turn on when only one is needed
I just had the same problem- when I replaced the whole cartridge.
I repalced the infinite switch- do the one that gets the hottest- or do both.
It is easy to do- just write down the wiring diagram - make sure all power is off- cost of new switch was about $37.00
This solved the problem- however make sure to check the sizng on the new switch shaft as my old knob would not fit properly on the shaft of the new switch.
good luck
Jun 20, 2008 | Jenn-Air JED8230 Electric Cooktop
Cooktops Logo
269 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
