Question about Gateway MT3705 Notebook
Gateway MT3705 laptop will not boot
I pulled the HD, ran chkdsk and the Hitachi diagnostics, HD appears clean.  I then inserted another 2.5" HD and same thing happened.  The HD light will flicker for a few seconds, then just die.  Could this be the MB problem then?  Based on other hits on your website, this issue came up a couple times.  Your thoughts?
I have in my toshiba setlite pc bios paswerd so how i can remove it sir thanks
Posted on Jan 14, 2009
My laptop keeps locking up. What can I do
Boot in "safe Mode" using the proper function key for your Gateway... usually F6. Just old it down when booting up until the safe boot screen appears. Select "Safe Boot with Networking". At "Start" type "cmd" ... a new screen will appear, type in "chkdsk/f" without the quotation marks and wait until your PC fixes itself, be patient. Reboot and it should be fine!
Jul 10, 2014 | Gateway Computers & Internet
Vista will not boot
Shutdown and then take your hard drive out, connect it to another PC with a USB adapter/cable, and use that other PC's anti-virus (e.g., McAffee) and anti-malware (e.g., malwarebyte) to scan and clean your hardrive. Make sure your hard drive does not overheat during the scan/cleaning process. After cleaning, re-insert hard drive in your laptop and boot.
Mar 23, 2014 | Gateway MT3705 Notebook
Gateway mt3705 forgot password
You can remove or change the Window\'s User or administrator\'s password and privileges. You need access to a computer with Internet access to download the Hiren\'s Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren\'s CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN\'S BOOTCD :- http://www.hirensbootcd.net/
Mar 13, 2013 | Gateway Computers & Internet
I forgot my gateway laptop password and can only get on guest. how do get in with out using a disk or usb?
restart the pc and then as soon as the black screen appears keep pressing f8 till the boot menu comes up, choose safe mode. when windows loads up in safe mode Login as Administrator then click start > control panel > users click on your account > click remove password. Restart pc and log in to your account
Feb 28, 2011 | Gateway MT3705 Notebook
Gateway MT3705 Not booting up
Try taking out the hard drive and see if the pc will boot to the BIOS, if not....pull the memory from the pc or try a stick at a time and see if you can at least get to BIOS...if not most likely you have a MOBO issue.
Aug 26, 2009 | Gateway MT3705 Notebook
Gateway boot problem
This mostly happens when your motherboard is bad or one of the memory modules is bad.
The led light comming on indicates your power pack is ok but a component is failing to start especially when the laptop stops at the first screen stage where the manufacturer names appears.
The steps needed to solve this kind of problem would require technical skills and physical inspection.
If you still have a waranty period then seek a free service repair from an authorized or certified gateway service centre at the nearest centre closest to you.
If your warranty has expired, i still advise taking your Laptop to the closest Gateway service centre.
May 21, 2009 | Gateway MT3705 Notebook
Bootmgr is missing
Run a Chkdsk:
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
OR:
Perform an XP repair:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 07, 2009 | Gateway MT3705 Notebook
DST Error (1000-0146) Ok, i tuned my laptop off on friday night, came back saturday morning turned it on, and it displayed the DELL screen (F2, and F12 button displayed) then a black screen comes with a...
Glad to know you can use DOS. Ok, you need to run these three commands in DOS (Recovery console, in XP verbose):
1) fixmbr, this will repair the boot sector on your HD
2) fixboot, this will repair your Windows boot, and
3) CHKDSK /F (the F parameter stands for "fix").
The system should now be able to start normally, or at least in SAFE MODE.
Apr 19, 2009 | Dell Inspiron XPS Gen 2 Notebook
Gateway notbook is not booting
yes this is what this means you will need a whole new hd nothing will be on it
Sep 10, 2008 | Gateway MT3705 Notebook
GATEWAY MT3705
maybe i would try to replace the harddrive first with a old one you have laying around or buy one from a computer-recycleing place first then if that does not work i would replace the motherboard
Jul 14, 2008 | Gateway MT3705 Notebook
Gateway MT3705 Notebook Logo
66 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
