Question about General Electric GE Profile CounterTop Microwave - Model Number: PSHF6VGXBB Side by Side Commercial Refrigerator
When I press Start - Runs for 5 seconds and stops.
Model #JES2251SJ01 - GE Profile Countertop Microwave - Clock, Timer, and light are working perfectly. This problem happened very suddenly.
I tried the "side dish" option with a glass of water in the microwave. The turntable continued to turn - it didn't turn off in 5 seconds- but then smoke started coming out of every vent. I think that killed it. I decided to go buy a new one.
Posted on Jan 15, 2009
My ge microwave spacemaker profile model # JVM1860BF001 stopped while in use. Interior light, clock and timer work. Door vent opens. turntable doesn't work. Won't heat.
check the breaker, or check if the wall socket works. If there is power, then you need to take it for service. There are no user service options for microwaves as they are so dangerous for both super high voltage and also microwave emission. Some models do have a pull fuse on the rear, so check for that first.
Oct 04, 2016 | GE Microwave Ovens
How do I set the clock on my Samsung microwave
Your model number refers to refridgerator.....see this link
www.manualslib.com > Brands > GE Manuals > Refrigerator
Jan 17, 2015 | General Electric GE Profile CounterTop...
How do I add
What is it you want to add ?
Dec 02, 2014 | GE JE740DRBB Countertop Microwave Oven...
How do you stop, reset or change the remaining time on the Timer on the GE JES1142 microwave? Pressing Clear/Off does nothing. Do you just have to wait for the timer to run out? Manuel is wrong even on how...
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Oct 27, 2013 | GE JES1142SPSS 1.1 cu. ft. Countertop...
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Round soft key OXO Timer I need to change the clock time their model # is 1061978
    Operating functions:
    To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
    To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
    When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
    This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
    Sep 18, 2010 | Microwave Ovens
    Microwave only runs for about 3 seconds.After
    Chances are you have a failing magnetron.
    But to allow us to help you effectively (at no charge), please post a
    NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, "Microwave only runs for about 3 seconds then stops and the timer goes back to the clock mode.After several attempts then it will work.Problem is intermitten"
    Dec 04, 2009 | Panasonic NN-S252WF Microwave Oven
    Power cuts out after about 5 seconds
    Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
    Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Open Questions:
    General Electric GE Profile CounterTop Microwave - Model Number: PSHF6VGXBB Side by Side Commercial Refrigerator Logo
    179 people viewed this question
    Top General Refrigerators Experts
    John Tripp
    John Tripp
    Craig Butler
    Craig Butler
    Charles T Nevin
    Charles T Nevin
    Are you a General Refrigerator Expert? Answer questions, earn points and help others
