Question about Fisher and Paykel DGGX1 Electric Dryer
Parts Where to go for instock parts for Fisher paykel dryer , need outlet bearing group and lint filter and scraper.
  • 3 Answers
You can download parts diagrams and order parts here.
http://fisherpaykelparts.net/
Posted on Feb 03, 2009
My Fisher Paykel DEGX1 US dryer has no power after I reset the manual thermostat and vacuumed lint from inside the dryer and outlet pipe. It beeps when I plug it in so power is coming to the unit.
if the unit got backed up with lint and over heated then its a good chance that the Non resettable safety temperature switch has gone , you'll find it just by where the pipe exits the dryer , should have two wires on it and should be about the size of a nickel id bet its open .
Dec 16, 2016 | Fisher Dryers
Fisher and paykel aquasmart fault 235
Try cleaning the INLET and the outlet valves, it is possible that the filters are blocked. If not check the wiring harness from the panel, check for moisture within the panel, if so use a dryer to warm off and test. Please estimate before any parts are replaced.
Jan 20, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
A repair "tech" came to
I would think that it would be the lint filter or filter screen... Either way, unfortunately, most manufacturers regard this as a consumable ( non warrantable) part as its life depends on how often you use the machine and how often you clean the filter.. Im not really conversant with US sold F and P product but perhaps on the internet , there may be further info on the model you have. I beleive that F and P ( Fisher and Paykel) New Zealand, joined Whirlpool in USA ??? Perhaps, the machine you have may actually be a Whirlpool...
Aug 04, 2011 | Fisher and Paykel Dryers
The dryer is squeaking/squealing during operation. It is a high-pitched noise that is rather loud. It is also getting very hot. We vacuumed the lint bucket area behind the cover, which fixed the...
I am having a similar issue. I had a tech out to look at it and he recommended replacing the drum bearing and idler jockey pulley. ($419.95) Ouch. I am going to do this on my own. I ordered the part from paykelfisherparts.net. Part # 479332 Drum Bearing Kit $79.91.
Check here for more info. This was exactly what I found on my machine (DGGX1) http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/731-fisher-paykel-dggx1-top-load-dryer.html
I did not totally trust the repair dude. He was wierd and not very thorough. I can tell the bearing is bad, if there are still noises I will order up the jockey pully thing and see if I can figure that out.
Here is a link to the service manual. (https://docs.google.com/fileview?id=0B5If-wTgYWH5OGNkY2RmZDEtMWU4OS00MjgwLTg3OWEtMmRlZjY0N2I5MzYy&hl=en)
Good luck
Jan 17, 2011 | Fisher and Paykel DGGX1 Electric Dryer
Fisher paykel degx1 lint trap won t release
Probably the holder/bearing for is out of place... it is really hard to get it out if this is the case but you can try putting a putty knife in between the top of the lint trap and the bearing and pressing down on the knife. If you get it out the lint scraper will have to be reset, F/P may be able to walk you through this.
Apr 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
The mount assy on right side across from lint catch completly fell off. I was able to rig it but how do i fix it?
If I am understanding your description correctly, the bearing cover on the opposite side of the drum from the lint bucket and filter has come apart on you. The part is sold as a kit with the cover, bearing, retainer and all the screws included, as well as an instruction sheet. It is a part number 479332 and you can get them here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=267
Mar 15, 2009 | Fisher and Paykel DGGX1 Electric Dryer
Lint assembly-Fisher and Paykel DEGX1
Pretty easy on the lint assy;
Remove the lint cup;
Find screw (5) in a recess at the bottom of the lint cup area;
This will allow removal of the perforated lint surround, and the 'lint scraper'; Also will expose the moisture sensor (3) hanging off wires at the bottom of the assy;
At the bottom of the surround there is another recessed phillips screw; remove this, then twist the surround (14) counter-clockwise about 1/2" and remove to expose the filter (13).
<img src="http://img50.imageshack.us/img50/9130/outlectductsh4.jpg" alt="FP Dryer Lint parts"/><br/>
Not sure on the reset- I do know the top swivels up after removing the two screw caps and screws at the front of the unit on either side. This exposes the underside of the control panel; there are screws at the back of the control panel also.
Jan 02, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DGGX1 Electric Dryer Logo
294 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
