Question about Panasonic PV-GS39 Mini DV Digital Camcorder
Camcorder panasonic displays dew detect in red
How can i fix it
dew detect on display
    Problem Solver:
  • 15 Answers
Eject the tape. Leave the tape carriage open. Power the unit off and tent it with a light linen cloth for about 20 minutes in a warm but obviously low humidity area. Emergency/ short time approach: Clean hair blow-dryer. Set for warm/low heat. Turn on and "wave" the warm air into the tape mechanism section about 18 to 12 inches away from the camera's open gate/door. Bake for 3-5 minutes..
Posted on Jan 14, 2009
Dew detected DISPLAYS ON SCREEN
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Sep 17, 2010 | Panasonic NV-GS27 Mini DV Digital...
Dew detected show on lcd
The camera is telling you that there is moisture inside the unit, place the camera in a warm dry space for 24 - 48 hours to dry out, it should be fine after that.
Regards
Aug 01, 2009 | Panasonic PV-GS300 Mini DV Digital...
Dew detected eject tape
como puedo solucionar el problema (how can I solve the problem)
Dec 19, 2008 | Panasonic PV-DV103 Mini DV Digital...
DEW DETECTED / EJECT TAPE
I know that this sounds odd but the fix is to remove the battery and hit the camcorder on the back (where the battery was) with the palm or your hand. Put the batter back and it will work. I found this soluation a a CNET web site solution. I don't know why it works.
Jun 05, 2008 | Panasonic Palmcorder PV-DV203 Mini DV...
Fix Dew Detect for Panasonic 700X
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
May 15, 2008 | Panasonic PV-GS300 Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
Panasonic NV-GS50 - Display indicates "To Service"
This means you need to get it serviced, because it has detected a fault or error.
Sep 06, 2017 | Panasonic NV-GS50 Mini DV Digital...
Dew detected
This may sound stupid, but it worked for me.
Turn your camera on. When you get the dew detected warning, take your battery off and just hit the spot where your battery was a few times with your palm, not too hard, but not really soft. Put the battery back on and it should be fixed unless you actually do have a dew problem!
If that doesn't work, try drying it out with a hair dryer.
Dec 28, 2007 | Panasonic PV-L680 VHS-C Analog Camcorder
Panasonic DV-PV203
Read the solutions here
http://www.fixya.com/support/t196433-dew_detected_dv_203
Jun 12, 2007 | Panasonic Palmcorder PV-DV203 Mini DV...
Panasonic camcorder (NV-DS65) - Dew Indicator Problem
I found this on another site, but it WORKED great for me, and was a VERY easy fix, so I suggest everyone to try it before you go disassembling your camera. I know this sounds very stupid, but it actually somehow fixed my problem, so everyone should give it a go:
1) Turn the camera on.
2) When the dew icon is displayed, take off the battery and then hit/smack the spot on the camera where the battery goes a couple of times (not overly hard, but with some force).
3) Put the battery back and see if it's fixed. If it isn't, repeat the whole procedure. It took me about four tries but now miraculously my camera seems to be working, for the first time in about 3-4 years!!!
NOTE: I don't know what the exact "fixing" spot is, so I just hitted different places of the battery spot (both the upper and lower region). Take it easy first and don't hit too hard, see if it works and try again putting more force if necessary. I still can't believe this solved the problem, wish I'd tried it back when the problem first occured!
NOTE #2: I think this fix will probably also work on some other Panasonic cameras with the same dew problem - in fact, I think the guy who originally came up with this solution actually had a different camera model than I do.. I know it's a late reply, but hopefully this helps at least someone!
Sep 06, 2005 | Panasonic AG-185 Camcorder
Panasonic PV-GS39 Mini DV Digital Camcorder Logo
167 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
