Question about Clarke Power Products Clarke 130EN Mig 110 Volt
Welder not welding
My MIG has stopped welding It feeds wire ok Gas comes thro ok I have tried my torch on another welder and it works fine I notice slight spark when touch metal at start after that nothing
  • 92 Answers
The contact tip is the main source of power, if the tip is bigger than the wire then you will not get a proper conection, the earth clamp is a essential part of the system make sure you have a good earth and all the conections are tight
Posted on Jan 23, 2009
  • Ron Jones
    Ron Jones Jan 23, 2009
    Just to add........ a 400amp Mig set will not be single phase ! if you have it pluged into a single phase then yes you might get the wire to feed and yes you will get a spark but thats all you will get. check that it is three phase by looking at your manual or on the duty cycle plate.
  • 4 Answers
SOunds like your ground is not connected solidly either inside the machine or at the ground clamp. Check to make sure the ground wire at the clamp is not broken then make sure the ground wire is connected solidly inside the machine.
Posted on May 25, 2009
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Lincoln 135 PRO MIG Welder feed stops after a few minutes
1/4" plate with a 135 amp machine is probably beyond it's duty cycle abilites. If you are using a mixed gas, and pushing the max on the settings, it will be cutting out because it is designed to.
You might want to get a higher amperage welder for consistent welding of 1/4"
The 140 Pro maxes out at 5/16" using inner shield wire. and 1/8", or 10 guage with gas.
Mar 19, 2010 | Welding Tools
Welder running but wont feed wire etc
Try to short the trigger wire back closer to the unit or better still inside the panel somewhere. There is often a relay that is operated that allows gas to flow and power to the wire feed motor. Check where the trigger wire goes it may give you some idea. If you can identify the part you can source one and see if it worthwile repairing. Cheers
Nov 18, 2009 | Welding Tools
The wire feed on my welder will not work.
Maybe you can get lucky like I did . Some times the acr volt selector switch gets corrosion in it and wont let the circuit board know to send power to the wire feed motor. You can cycle this arc volt. switch in my case it is the a,b,c,d,e, switch back and fourth a few times and this will brake the corrosion and your wire might feed again as mine did . This corrosion build up happens from not using and or sollecting the switch much usually on a welder at hm that gets very little use. it is common good luck .
Jul 24, 2009 | Lincoln Electric LINK2400-+2 CV-305 MIG...
Wire feed stopped after tack welding on set-up jig
i had the same problem. its probably a bad solder on the wire feed pot. not hard to fix ,but you need a solering iron .BE CAREFULL 1 unplug welder.
2 remove pot and the nut underneath.
3 remove case from welder and remove controll box.
4 run the soldering iron over the joins , then put it all back together, should work fine.
Jul 22, 2009 | Hobart Handler 140 Mig Welder
Toolex 140 mig welder, wont feed wire.
You may have the scew settint your wire tension set to tight. Try loosening the tension and if that doesnt work check the eletrical wire that supplies the power to the roller and make sure it hasnt become disconected.
Jun 26, 2009 | Welding Tools
SIP 195 MIG welder doesnt work
sounds like your welder has over heated and the Thermostat has come on
wait for 10 minutes and then try again
If that does not work fit a new PCB
Gilmore
Jan 01, 2009 | Computers & Internet
Clarke Power Products Clarke 130EN Mig 110 Volt Logo
672 people viewed this question
Top Clarke Power Products Welding Tools Experts
 Kenneth
Kenneth
Wade Mobley
Wade Mobley
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
