Question about Whirlpool Calypso GVW9959K Top Load Washer
Calypso - ob that's really off balance
I've had all the usual Calypso problems, mostly associated with draining. Its been running for a while, but now it really does start thumping and jumping around and shutting down w/ an ob code. I took everything apart, made sure the pump was clear and working and ran a rinse and spin cyle with nothing in it. It still went off balance. What to try next?
  • 2 more comments
  • TomFish Jan 16, 2009
    That suggestion really doesn't help and only suggests what my queston already said I tried. It goes off balance when run empty, and I've already completely taken the pump and plumbing apart and subsequently confirmed that its properly emptying.
    I had previously confirmed that there was no clog, including blowing air back through the system, since this had in fact been a problem in the past. Also, when I ran a cycle with no cloths, the system pumped out water quickly and I believe, completely, but it still started thumping around and shut itself off even without a single item in the drum.
  • TomFish Jan 17, 2009
    Can anyone tell me if the top plastic ring, around the top of the drum, is supposed to float or is it supposed to fixed solid to the drum? Also, I'm assuming the agitator must be spring loaded to want to return to center. I'm trying to figure out how to troubleshoot that and determine if that's working properly or if it might be the cause of the off balance problem.
  • Whirlpool Master
  • 19,396 Answers
You need to banace the appliance, it is returning drain error because the vibrations cause the problem.
Check struts and shock absorbers.
find parts and diagrams by entering model number here.
Posted on Jan 23, 2009
    Sergeant:
    Champion:
  • 239 Answers
Did you remove the security shipping pin that comes w machine when you first got it?sometimes there are 4 bolts on the back that you have to remove>>
Posted on Jan 17, 2009
  • 818 Answers
    Master:
  • 416 Answers
Follow this link http://appliancejunk.com/forums/index.php?page=142 Explanation of Ob code: If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
Press STOP/CANCEL to clear the display. And this is service and repair manual http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=58 Hope that helps Good Luck
Posted on Jan 16, 2009
    Sergeant:
    Scholar:
  • 199 Answers
The code which comes up on your screen means:-----------
ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance
for more details check out this link
http://www.applianceaid.com/calypso-codes.html
  • 66 Answers
• California Class Action Settlement. For anyone looking to replace this product? I is this product? I had initially been intermittent Ohio is nearing the front bottom panel to access is 13 months old is nearing the “Ld” (”long drain”) problem on Whirlpool Calypso washer because it has been intermittent Whirlpool faulty Calypso Washing Machine: Whirlpool Calypso? GVW9959KT 27 Whirlpool Calypso gvw9959k. Whirpools site code book has no code OB Unplug for a hour. so it will reset.
  • 1,031 Answers
If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an "ob" for Off Balance
The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow you to view and redistribute the load.
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Jan 16, 2009
    hope this helps
    Washer must be level front-to-back and
    side-to-side. Each of the washer leveling legs must set solidly on the
    floor at all four corners. Check by rocking the washer from opposite
    corners. Adjust the appropriate leveling leg(s) until no movement is
    noticed. some washer has self-leveling rear legs which are
    adjusted by tipping the washer forward (the rear of washer should be
    off the floor about an inch) and setting it back down. For tumble
    action washers, remove the front access panel, loosen the lock nuts,
    turn legs in or out slightly until the washer sets solidly on the
    floor, then tighten the lock nuts. For maximum stability, leveling legs
    should not extend more than 1/2 inch below the washer bottom.
    Refer to the installation instructions that came with your washer for more information on the installation which may effect the washer balance
    Novelist:
  • 115 Answers
I couldn't find a diagram of your washer to save my life, but it seems to me, (if the drain and everything else checks out ok), that the 'tub' itself may be allowed to far from center because of a worn part (bushing and/or bearing) underneath. This would cause it to rotate too far from the 'center of balance' causing the ob code.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, even if the error message indicates ob (out of balance) and not an Ld (long drain) error, address the issue like it was a drain problem. Check, clean, clear drain system. Additionally, you may want to use an air compressor or garden hose and spray water or air back into the black drain hose on the washer. The idea is to break any clog or blockage.
Pls post back result(s). Good luck and Thank you for using FixYa.
  • 679 Answers
Please see on the link>>
http://www.hometips.com/repair-fix/washing-machine-troubleshooting-problems.html
hope helps.
let me know for further assistance.
  • rockfixya
    rockfixya Jan 16, 2009
    please checkout the link.
    Thanks for using FixYa.
  • rockfixya
    rockfixya Jan 20, 2009
    please let me know if problem solved.
Calypso Washer stopped working
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@#$&
Jul 18, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does error code ob mean on a Whirlpool Calypso washer? The washer stops in mid cycle with the error code ob. I restart it and after a few minutes it shows the same error code again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*@^%
May 29, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore calypso washer will not spin the clothes ld or ob signal continue to show even after i have evenly distributed the clothes
May 15, 2010 | Kenmore 24032\24036 Top Load Washer
I have a calypso washer, it makes a grinding sound and the water will not drain out. it also keep boping up ob code, i have trye to balance it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%@
Dec 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso waher ld and ob error codes...what is it?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^$#@
Oct 13, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My calypso washer keeps giving teh OB error, but it's completely leved and I've even tried removing all the cloths from it and it still keeps doing it.
Sep 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso Washer troubleshooting
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^#@#$%
Jan 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
"OB" Code error
Nov 15, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Calypso ''ob'' problem
ob Off Balance If the motor controller detects an unrecoverable off-balance condition, the machine controller will shut down and display an ob for Off Balance The lid switch must be opened at least once before restarting the cycle, if this condition occurs. Opening the lid will allow the customer to view and redistribute the load.
if this does not fix the issue it is most likely the strut and shock system that is falty on the machine. you could replace them yourself but they are fairly expensive
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Calypso GVW9959K Top Load Washer Logo
298 people viewed this question
Dan Webster
Dan Webster
Sal De
