Question about Technics SA-DX750 Receiver
Sa-gx550 technics reciever
I have a sa-gx550 reciever that the overload protaction light keeps coming on and shuts down the system. you can turn the reciever off and re-set it but in five minuets it shuts down again
  • robert estes Jan 22, 2009
    i have tried unhooking and rehooking the speakers and checking if they are matched properly. it seems that it will work about five minuets and shut down again. with or without speakers
    i have no pets and this problem happens with or without speakers
    Genius:
  • 1,239 Answers
Hi
i think the circuit breaker is the problem....due to voltage problem
Posted on Jan 23, 2009
  • Technics Master
  • 19,396 Answers
Your system is going on protection, because had detected an internal fault.
This typically happens when you have a short, or an internal component had blown.
The unit must be taken apart and tested using a multimeter to fix the problem.
  • 4,234 Answers
This particular model contains and amplifier pac for the final stage. This is lilely to be either overheating which can occur when the heatsink compound ages and dries up, or it is a defective amp-pac. One other thing to check with these are the connections on the voltage regulators. These look like transistors and are marked 7812 and 7912. They will hav 3 pins each. The amp pac is an SVI-3206 which is still available but will cost upwards of $65-$75 for the part. If you can solder, try resoldering the pins of the regulators first.
Let us know your results.
Dan
  • 11,896 Answers
If you remove the cover you will see a wire harness with 3 wires on it plugged into the main board and attached to the board with the speaker connections. Once you pull this wire you deactivate the overload protection and it will work fine. I do this to all my stereos and suggest everyone else to do the same
  • Nate Stansfield
    Nate Stansfield Jan 23, 2009
    here is a link to your service manual (copy and paste in your browser)
    http://www.eserviceinfo.com/downloadsm/3...
    President:
  • 1,990 Answers
Welcome to Fixya! Have you checked the Cooling Fan?????? If there is not a Cooling fan on this Model, You will need to Replace the Power Supply In the Reciever. I Believe that you can get these at Radio Shack or Technics.com. Let me know what you find out!
    Brigadier General:
  • 5,158 Answers
You are experiencing thermal shutdown... basically the unit is getting too hot. if the reason is not poor ventilation then you have a component failing. before i give you more advice on fixing it how comfortable are you opening the unit up ?..
Robert
Posted on Jan 22, 2009
    Scholar:
  • 91 Answers
Do you have any pets you have to check the wiring make sure there aint no breaks in the wire also make sure there aint no wires that you have going to speakers taped or anything like that ive had this happen to my car amp and thats what kept happening the wire was split and grounding to metal i know its differnt for a house but the same concept i dont know what you all have hooked up through the system for example if its tied in with a surround sound for entertainment check the bass box connection because that carrys the bigggest load make sure its all connected right...Last but not least check if it has opticial connection if it does hook it up through that its ten bucks for a cord and that would even solve the problem if it has it... let me know some more info and we can go from there ill check for your reply every hr...
Thanks,
Steve
Posted on Jan 14, 2009
  • 10,594 Answers
Overload protection activates when output amplifier detects any DC voltage in output or sense any impedance mismatch with speakers (causing more current consumption)
I would suggest following tests / checks.
Please check each speaker wires properly connected in terminals.
Remove all speaker and connect one speaker at a time to test unit overload activation. This will narrow down bad speaker, if any.
Let me know about results to proceed further.
Thank you.
  • Shahid Electronics
    Shahid Electronics Jan 22, 2009
    OK, Unit goes to over load protection mode with and without speakers.
    Protection section needs to be checked on component level and its job of qualified technician.
    If you have experience and knowledge od electronics then get related service manual to test / check the unit on component level.
    Sergeant:
    Novelist:
  • 326 Answers
Its the problem of internal cable or internal circuit getting short somewher needs to be checked and replaced.
    Top Expert:
  • Technics Master
  • 77,169 Answers
In the main amp (not preamp) section there are large output transistors, when these fail many times they become shorted, this causes excessive current draw and either blows the output fuse or in your case turns the light on, they can replaced, they ae on a large heat sink
My technics av control stereo receiver sa-g76 keeps shutting off(overload). can you please advise on how to avoid this situation?
Is there anything on top of the av receiver? Try and run the reciever so that it has enough cooling. B) Allthough overload, there is a possibillity it is causes by speakercables who are shortcircuiting once in a while. Usually somewhere at the back of the reciever or speakers.
Apr 24, 2014 | Audio Players & Recorders
Overload sa-tx50
Most overloads are caused by the main output devices. They will go short circuit if for example speaker wires have come into touch. Another cause is high volume or a faulty speaker. Or poor ventilation around the amp causing excess heat.
The only cure is to replace the device(s) generally located on the heat sink.
Dec 01, 2013 | Technics SA-TX50 Receiver
No tv sound through reciever's speakers. How do I hook up?
TV is not customarily a sound source. It is a video destination. Get your TV-related audio to the receiver from the same places the TV gets it - each source device's audio outputs.
Feb 06, 2010 | Technics SA-DX750 Receiver
I have a technics sug91 amp the over load light comes on what can i do to remove it
you cant remove the overload light. it does that as a safty so you dont burn up the amp when its not being used properly. do u have a capacitor? are the speakers ohms and watts the same as the amp?
Oct 18, 2009 | Technics SA-AX540 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Overload protection
Doe this always go into overload independent of the volume level? Try disconnecting the speakers completely and running the set. Does the set shutdown then too?
Thanks,
Dan
Jan 16, 2009 | Technics Audio Players & Recorders
Technics SA-DA10 jumps into overload after 10 minutes
Have you tried connecting speakers? What was the result?
Yes, when you turn the volume up on these amps (or when the output gets past a certain level) the cooling fan should automatically come on.
Oct 14, 2008 | Technics SA-DA10 Receiver
No, its my Technics SA-GX550 amplifier - have a problem - HELP!!
Im having the same problem with mine. The problem seems to have started after I placed a vcr on top of the unit. I am thinking that It may be getting too hot. But don't really know.
May 05, 2008 | Technics SA-DX750 Receiver
Technics SA-DX750 Receiver Logo
295 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
