Question about ASUS Z83V Notebook
Wireless network disappeared...!
So, my wireless / bluetooth console is still there, and when I flick the switch on the side of the computer to 'on', the little window comes up saying wireless 'on'. Same goes for the F2 key, or by selecting the console throught the task bar etc. Basically, the computer tells me that the wireless console is on and applied, and good to go. The only thing is, there's no wireless network in Network Connections. Nothing. No option to search for availble wireless networks, no subtitle in the window for WAN or WLAN. It's like the whole wireless internet thing has been erased from the computer. I can get online no problem with a hardline (obviously, otherwise I wouldn't be writing this...), but the wireless thing just seems to have got bored and gone away. Do I need to actually re-install something - what? Or is it an internal thing that I can reconnect or rediscover? It's befuddling, to say the least. Has anybody had this problem, or does anyone have any ideas? I'd really love a speedy solution on this one, as I'm going travelling pretty soon, and having to be tied to hardlines only is going to be a real pain in the ass... Same thing's happened on my friend's laptop (not an ASUS), and all we get are confused looks from people when we ask. Someone - help...!
  • 1 more comment
  • Jamie Parker Jun 14, 2007
    Thanks, sandrew - gave it a go, this is what I found:
    Went into device manager, and under network adapters I could only find 2 - '1394 network adapter #2' and 'Realtek RTL8139/810x Family Fast Ethernet NIC' - couldn't find anything to do with wireless, and no yellow exclamation marks or anything saying 'unknown device'.
    Went into the bios menu. Wasn't sure exactly what I was looking at, so I didn't alter anything - this is what I found that I thought might be relevant:
    In the Advanced menu there were no wireless adapters mentioned, not even greyed out or disabled, so nothing doing there.
    Under Advanced>>Super IO configuration there was an 'OnBoard IR Port [enabled]'
    Under I/O Interface security there was Wireless Network Interface which was [Unlocked]
    And in the Boot Menu there was an Onboard LAN Boot ROM set to [disabled].
    I don't know anything about this, but that didn't look too hopeful from were I was sitting. I should maybe have mentioned before that I have used the wireless network on this computer before - I was away last year and used it for months in cyber cafes etc. Since coming back though, I didn't really need it, and just used the hard line. But now it's gone.
    Call me thick, but it's not possible to go into a shop and buy the driver that I need and install it myself is it, or am I going to have to send the computer away to someone expensive to open it up and deal with this?
    Thanks again - hope there's something else we can try...
  • Anonymous Feb 02, 2009
    I'm having the same problem on my hp dv9000. I use the wireless connection all the time as my campus is one big wi-fi connection. I was using it this morning, in fact, but when I returned from class and turned my computer on, suddenly the wlan had completely disappeared as if it never existed.
  • mandykemp24 Feb 03, 2009
    My son has the acer one notebook and we were online through wireless connection we shut it down went out came back in put it back on and there was no wireless at all the little screen at the foot of page had completely disappeard my son just got this for xmas and hope there is a solution for this nothing there is there anyway to get it back again xx
    Please help!
  • 2,961 Answers
If this has happened since new, as it did to two of my clients, the problem stemed from the fact that the wireless adapter was not enabled in the bios, the notebooks had to be returned, as their technical team could not get the bios to see the adapter. When you boot up your laptop press F2 or DEl depending on the instruction at boot up to enter the bios setup screen. You will need to look in all the menus normally the advanced menu under and peripherals, look to see if the wireless adapter is not greyed out, if so you will need a bios upgrade from asus, but if it's not greyed out select enable, save settings and exit for a restart. Also you may need to go to my computer, right click>properties>hardware tab>device manager and look down the list for any yellow exclamation marks saying unknown device, if this is the case you will need the driver for your wireless adapter. If you see a line saying network adapter, click the '+' sign and see if your adapter is listed, but has a red cross on it if so right click and select install.
Posted on Jun 14, 2007
  • andrew pester
    andrew pester Jun 14, 2007
    if you have no exclamation marks then, there something not right, it must be there as you know you have used it, the drivers are on the laptop manufacturer web site, free, but they need to find hardware, but maybe that will cure it, i would like to know.
Turn on notebook, go to boot menu (F2), go to advanced settings, go to Onboard Devices Configuration, make sure that the WLAN is enabled. Voila fixed!
Posted on Jan 22, 2010
Ok I think ive solved this, I had the same problem ages ago and then again just. when you boot up press F12 to select boot up device and select HDD (sounds obvious but...) you should get the screen you get if your laptop crashes or something where it says start windows normally or start windows repair (or safely... i wasn't really reading it) it will check for errors for a couple of min then restart itself.
When it restarted i could see the wireless device and the little orange light was back on (yay) but still not working when i disconnected the hardline. If you right click and diagnose and repair it will say turn on wireless ability click that and poof it was working again :)
I'm on a Toshiba Satalite something or another and I know its not HP or Compaq but after looking around it seems there are plenty of people getting this problem and end up sending their laptops off for repair, so hope this helps :)
Posted on Apr 09, 2009
I had the same problem on my new asus and eventually i got it running again. make sure you still have the driver disk that came with your laptop and see if installing some things works. i actually got it working another way after that but i have forgotten the process (it happens when you press Fn + F2 before your OS has started and the computer thinks it doesn't exist) dont worry, just take it to an electronics shop and ask for some help they will get it up again.
Posted on Jan 17, 2009
How to activate bluetooth using wireless switch
Step 1 Find the wireless switch, located on the front of the E5400, to the left of the touchpad.
Step 2
Slide the wireless switch into the "On" position to enable wireless radio communication on the Latitude.
Related Reading: How to Turn on Wireless on a Dell Latitude Laptop
Step 3
Click "Start ' Control Panel ' System and Maintenance ' Device Manager." Double-click "Bluetooth Adapters."
Step 4
Right-click the Bluetooth driver and then select "Enable" from the context menu, if available.
Step 5
Navigate to the Dell Support website in a Web browser if the Bluetooth Adapters category is not listed in Device Manager.
Step 6
Click "Start Here," then "Drivers Home." Click "Choose From a List of All Dell Products," then "Continue."
Step 7
Click "Laptops," "Latitude," then "Latitude E5400." Choose your operating system from the associated drop-down menu.
Step 8
Expand "Network." Click "Download File" next to the Bluetooth driver, then "Download Now."
Step 9
Launch the EXE file when the download completes. Follow the on-screen instructions to install the Bluetooth drivers to the computer.
Step 10
Restart the Latitude following setup to begin using Bluetooth on the E5400.
Jun 16, 2014 | Dell Latitude E5500 Laptop
Bluetooth peripheral device driver
Sai Ch Krishna,
Depending on the system. The bluetooth would have to have been purchased at point of sale. The wireless and the bluetooth are turned on by a wireless switch on the side of the computer. If needed you can reinstall the drivers. Also, make sure bluetooth is turned on in the bios. Below is more information.
Wireless Switch
Wireless Technology The Latitude D630, D631, and D630c system ships with a wireless feature called the wireless switch. It is located on the left side of the system next to the IEEE 1394 connector. When used in combination with the Dell 38482; Quickset utilities, this switch enables or disables the wireless LAN, wireless WAN, and Bluetooth cards in the system or searches for all wireless networks in range.
To scan for a Wi-Fi wireless LAN, slide and hold the switch in the momentary position for a few seconds. The Wi-Fi Catcher network locator works whether the computer is turned on or off, in Hibernate mode, or in Standby mode, as long as the switch is configured through QuickSet or the BIOS to control Wi-Fi network connections.
Because the Wi-Fi Catcher network locator is disabled and not configured for use when the computer is shipped, it must be enabled and configured through the Dell QuickSet utilities to control Wi-Fi network connections.
Wireless Switch LED Settings
The LED on the wireless switch works even if the system is off. A user can activate the switch and have it scan for networks without going through a complete boot process. The switch can be set to detect for only certain wireless signals, such as WLAN only, WWAN only, Bluetooth only, or any combination of these. This is set in the BIOS under the Wireless section.
The LED indicates the presence of a network as follows:
  • Flashing green - The system is searching for a signal.
  • Green - The system has detected a wireless signal and has good strength.
  • Yellow - The system has detected a wireless signal, but it is moderate to weak in strength.
  • Red - The system failed to detect a wireless signal, or the wireless signal is extremely weak.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Aug 27, 2013 | Dell Computers & Internet
Can't find a switch to enable wireless on new Lenovo T410
I had this same problem. The slider switch on the right side if the laptop enables both the wifi connection and the Bluetooth control. My laptop was only turning on the Bluetooth. If this is happening to you, true booting the computer and going in the BIOS settings, Network, wireless adapter. There you will have the option to turn it on or off. Mine was set to off. I clicked on and rebooted to Windows and it works now. Hope this helps.
Oct 31, 2012 | Lenovo Computers & Internet
Ap dropout
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Oct 07, 2012 | Buffalo Technology WLS N150 RTR AP BRG
Lifebook P Series Fijitsu, Model Nuber PH520. Even though there are wireless internet connections available shown on other computers, the Fijitsu cannot find any wireless networks. There are not wireless...
Did you turn off your wireless antenna by accident? The on-off switch for Wireless LAN is located on your computer's right hand side - if that's turned off, both wireless and bluetooth will cease to detect any signals or connections.
Sep 13, 2011 | Fujitsu LIFEBOOK PH520 Ultra Portable...
I can't access any wifi network any time i scan in a wireless hot spot
on the front of your laptop is a switch. This switch is for turning wireless on and off for areas like airports or just for security. Frequently, your thumb or whatever clips it and suddenly you have no wireless. Flick the switch to the one where there is computer with brackets on each side. good luck!
Jun 13, 2011 | Computers & Internet
Dear sir, i can not see the wireless icon on my laptop
do you have the drivers for your wifi card installed properly. if not then go to manufactures website and download driver software for your wifi unit, are you using xp or vista? find device manager and see interfering hardware.
Dec 02, 2010 | Dell Vostro 1500 Notebook
Getting on internet
By connecting wirelessly. Go to your network configuration menu within the main menu of the PSP (start it up without a UMD game in) and search for connection points with it. Make sure that your Wifi switch is in the on position (it'll light up a blue light when it's searching for a point, otherwise, flick that little switch at the bottom). If you have wireless or are at least close enough to a connection that's not encrypted, then you can connect instantly and it'll remember that connection setting.
Jun 05, 2010 | Sony PlayStation Portable (PSP) Console
I can't get my Network Adapter to connect to my Local Area Connection on my laptop. It tells me to turn my wireless capability but every time i flick the swith for it to be on it doesn't say it's on.
check the bios of the laptop to make sure the network card is enabled (at the BIOS hardware level)
check the FN + (F#) switch to activate the network adapter. for example, IBM\Lenovo is FN + F5 to activate the bluetooth and network adapter cards. In many cases, these settings are separate from the driver and software settings on the computer itself.
Nov 17, 2008 | Computers & Internet
ASUS Z83V Notebook Logo
4,009 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
