Question about Cable_and_wireless CWD4901 Cordless Expansion Handset
Phone locked, please help!
I have locked the both handsets, and therefore can't dial out ot press any other buttons. Currently, the message on the screen says: Key Locked. I did this while in the Menu (trying to increase the volume) and where it said Keypad, I clicked ok (in error) and the phone got locked. Can you please help me? Many thanks Sanja
  • 2 more comments
  • andy35 Feb 11, 2008
    i have locked my c&w phone therefor i cant dial out and i need my phone can anybody help
    i have locked my phone trying to set a code for my children and now i cant dial out and i need my phone and i dont want to buy an new one, please can some one help
  • DEMANIROBINS Oct 08, 2008
    i ahen locked myself out of my new envy 2 how do i get back in i dont know the code my brother does and he moved
  • Anonymous Mar 14, 2014
    Siemens cordless phone is locked and has key showing on screen
Press the * key then the OK key within 3 seconds.
User manual at http://www.telephones4u.co.uk/userguides/CWD4901SE.pdf
Hope this is of help.
Posted on Apr 28, 2008
I have loked mi dail code of my panasonic phone KX-TG2620BX nad i for get my pass word and now i ma not in a position to dail phone my instruments now i want to decode my lock what to do please suggest
Posted on Jan 20, 2008
How do i program your 20200-1 hand set telephone. it has 13 number memory. that i wold like to program?
To program one of the three emergency buttons:
1) lift the handset and wait for dialtone
2) press the STORE button
3) dial the phone number
4) press the STORE button
5) press one of the three emergency buttons
6) replace the handset in the cradle
To use; lift handset and press an emergency button, the phone dials the number stored for that button
To program one of the ten memory locations:
5) dial a one digit number(0-9) to store the number in that location
To use: lift the handset, press the MEMORY button, dial the memory location digit(0-9), the phone dials the number stored in that memory location
Here is a link to download the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 11, 2011 | Lands Phones
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
My Sonim XP3 Quest Pro write sometimes fileerror.return when I have an incoming call up and it is not ringing
Hi Riisbjerg, you could try to reset/clear flash the phone. That should take care of the problem, but it also erases ALL settings and phone book entries from the phone, so it is best to make a backup of the phone bookwith the PC tools software.
The software can be downloaded from http://www.sonimtech.com/support/downloads.php
Reset: Please try to reset the handset memory as below:
a. After Powering ON the phone
b. press #20070114# from phone idle screen and press dial key.
c. Message comes up as " Do you really want to clear flash? "
d. Select OK. After reset is finished, you can see the message "Switch off the mobile by any keys".
e. Switch the phone off, then remove and reinsert the battery and Power ON the phone.
Once done, please restore the handset to factory settings:
a. Power the handset on
b. Using the menu buttons, go to Settings (General Tab) -> Default Settings.
c. Press the OK button to confirm
d. Power the handset on again
If this does not help, please send an email to the Sonim support team: support@sonimtech.com
Thanks!
Andreas Sonim Customer Service
Jan 15, 2011 | Cell Phones
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
Instruction manual for older style corded GE speaker phone
Here are the quick instructions on how to program the phone numbers.
You can also download a copy of the User's Guide from: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=c96e9c823d0df43989039e5385bef04a&q=GE+29322GE1
Just enter the 4 digit captcha code and you will be able to download the User's Guide.
Please let me know if yo have any questions.
Good Luck!
STORING A NUMBER IN MEMORY
To program priority keys:
1. Make sure the telephone is properly installed. Pick up the
handset and listen for the dial tone. If you don’t hear the
dial tone, recheck or repeat the installation steps.
2. Press the SPEAKER button or pick up the handset.
3. Press the store button.
4. Dial the number to be stored.
5. Press the store button again.
6. Press the A, B or C button.
7. Press the SPEAKER button or hang up the handset.
To program frequently called numbers:
1. Press the SPEAKER button or pick up the handset.
2. Press the store button.
3. Dial the number to be stored.
4. Press the store button again.
5. Press one of the 10 memory location buttons 0-9.
6. Press the SPEAKER button or hang up the handset.
Aug 11, 2008 | GE 29322GE1 Corded Phone
6.0 GE cordless phone
For GE 6.0: There is a button on the base lower right corner  (NOT the phone), you need to press it once again to turn off Do Not Disturb
For GE 5.8 GHz:
1. Pick up the phone handset and dial *98.
2. Press 2 to disable Do Not Disturb.
3. Once you hear the confirmation that Do Not Disturb has been disabled, you may hang up the phone handset.
Hope this helps!
Mar 24, 2008 | GE 28112EE2 Cordless Phone
Empty Message
Follow these steps and this should fix the problem.
on the phone that shows this msg.
Without picking up the handset .
press the transfer btn
dial 115
dial 00
press transfer.
Mar 18, 2008 | Samsung Phone PDCSLCD12B
How to disable dial lock without password
I am using panasonic PANASONIC KX-TG2620BX and was locked by my daughter. We had it unlocked by:
press MENU
select Dial lock
Enter password 1234
Press save
Turn off Dial lock? press yes
Jan 08, 2008 | Panasonic 5.8GHz Cordless Telephone
Phone handset display continuously showing
Buy a new phone but not a VTECH piece of crap. Thier support sucks and you never talk to a person. It is all automatted.
Dec 13, 2007 | Lands Phones
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Cable_and_wireless CWD4901 Cordless Expansion Handset Logo
545 people viewed this question
Top Cable_and_wireless Lands Phones Experts
Marvin
Marvin
k24674
Are you a Cable_and_wireless Lands Phone Expert? Answer questions, earn points and help others
