Tv/vcr combo i hooked up a dvd player and cannot get sound
Not sure what i did wrong or if the hook ups work in the back
    Sergeant:
  • 227 Answers
Usually you have to select video on the tv/vcr then play your dvd.
Posted on Jan 14, 2009
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
I hooked up a DVD player to my RCA Tv/ VCR Combo. I get sound, but no picture. All connections are tight. Cables are hooked up in the order they should be. I get cable from TWC. There are red yellow &...
The red and white are the audio, and the yellow is the video, check the back of the tv to make sure the yellow jack states input, if yes make sure the tv is set to aux/or video.
Dec 22, 2010 | RCA T20TF667 20 in. TV/VCR Combo
How do I hook up this vcr/dvd combo? Tv has two
Yes you need a modulator. The one I used to hook up my Mother's VCR/DVD Combo only cost $15 at Walmart. It was a RCA brand.
Jan 19, 2010 | Philips Magnavox DVD/VCR Dual Player
Would like to record from my tv to my magnavox dvd/vcr combo box
If I understand your request right, You do not have cable or satellite box.
You can not record from your TV. You use the TV as a monitor from the dvd/vcr combo box. What the box receives is what shows on the TV. So you will have to have a digital convertor hooked to the (antenna in) dvd/vcr combo box, (antenna out to the tv antenna in) Depending on the antenna you are using that is on the other end of your cable-in coax connection this will hook to your antenna in on the digital convertor box. If your cable is hooked up and operating correctly and directly to the tv that is digital ready you probabbly have a good picture. When the vhf/uhf signal was transmitted you could go from the dvd/vcr to the tv with no problem. But now that the signal is digital and the tv is set for digital the dvd/vcr will not pass a digital signal to the tv. Best suggestion, you have to get a digital dvd/vcr receiver. If you have more question please contact me.
Mike
Jul 25, 2009 | Philips Magnavox DVD/VCR Dual Player
Cannot connect a VCR/DVD player to Zenith SY1959Y
you don't need a code for the vcr/dvd combo to work on your tv. You need to make sure you have hooked up the cables correctly. remember that the dvd can be hooked up with the component cabels and the vhs may need to be hooked up thru the tv cable hookup.
Jan 08, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
I need help with my tv and dvd/vcr combo
Hmmmm...I dont understand exactly what you are saying, but it sounds like your TV doesnt have RCA ports and you want to hook up a newer DVD player that uses RCA ports. If you have only a cable port (silver threads with a hole sticking out of back) on TV and RCA ports on DVD player, you have to buy a converter. You can get one at Wal-Mart for 20-30 dollars. Or you can just update your TV which it sounds like you badly need to do! :)
Dec 24, 2007 | Sanyo DVW-7200 DVD/VCR
I can't hook it back up
Is your DVD player a DVD/VCR combo? If so, hook the "tv out" (sometimes called "ant out" ) to the "ant in" on the DVD/VCR, then hook the "ant out" of the DVD/VCR to the "ant in" on the tv. Then make sure the DVD/VCR and TV are on the appropriate channel (3 or 4).
If it's NOT a combo, or these instructions don't work for you, i will need pictures of the inputs/outputs of the devices.
Nov 08, 2007 | DISH Network DVR-625 DTV Receiver /...
Can I connect a dvd player to a dvd\vcr combo
I am not sure I understand why you would hook a dvd player to your combo.You should just hook your magnavox directly to your tv.
Sep 24, 2007 | Televison & Video
Connecting VCR/DVD combo
Put the Tv on Channel 3
Jul 11, 2007 | Sanyo DS25390 TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
