Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Leaks under left hand side of door; I've installed 2 new gaskets in last 2 weeks & new float switch; doesn't leak underneath
  • sandmn75 Apr 03, 2009
    My 2 month old Kenmore Elite leaks out the right front side. Sears repairman says the doors aren't watertight (can that be? On a dishwasher?!), says it could be because I loaded a larger bowl so water from the sprayers was directed toward the side or something. Didn't leak when he ran the machine, didn't leak the next time I did, but it sure did again last night. Dishes appear to be loaded properly. He's coming again next week but I'd like to be able to direct him since he apparently has no clue as to the problem or solution. Thanks.
    Scholar:
  • 39 Answers
Check for cracks in the inside liner of the door itself. Seal anything that looks like a potential leak with silicone sealer. I'm providing this advice because you have already eliminated the other possibilities I can think of. If it has a soap dispenser on the door check for leaks around that especially.
Posted on Jan 14, 2009
Rear Door seal water leak
If silicon is working,I would go with it,silicone last a long time and it's working.
Dec 25, 2012 | 2001 Toyota Sienna
I've had to fill my coolant 3 times this week.. I've put about 500ml in on monday, wednesday and friday. If i do not do this then my truck will overheat. I took it in on monday and the mechanics...
Sounds to me like the head gasket could be leaking not to the ground, but to the cylinder. Is there white smoke at any time indicating water/coolant is making its way to the cylinder? If so, then the head gasket does have a leak. Maybe try some head gasket repair for $30 from Bar's Leaks at Advance Auto or Autozone to try to seal it without removing the head. If that doesn't work, then a new head gasket may be the solution for this case.
Another possible site of leakage is a radiator cap that has a weak spring and doesn't hold 15 psi or so pressure. When the technician pressure tested the system, it's likely they took the cap off for the leakdown test and replaced it with the pressure tester gauge and pump. Also, check the overflow tank to see if it has a pinhole leak in it. If there is a small leak there, then that could explain the loss of coolant.
Is there a smell of antifreeze/coolant after the car is shut off? If there is, there is likely a leak somewhere.
Nov 04, 2011 | 2004 Lincoln Aviator
Water Pouring out of door, appliance stuck on wash
dishwasher leaking from the door or from the bottom of the door is common problem and yes its advisable to get it fixed.but if its having any other problem other then leaking then it has to be checked first.but leaking problem is common it can be solved.first from which part of the door area the leak is occuring that has to be checked.
Some common leaking trouble makers....
Leaks at the door:
Door gasket loose/torn
Corner gaskets or door baffle/vent gasket
Door lock/latch loose/broken
Split spray arm
Over filling with water...usually the level is just under the heating element is normal
Something leaking through the door...like the soap or rinse agent dispenser gasket, silverware basket button.
Door hinge(s) bent
Wrong soap was used...dish sink soap instead of dishwasher soap
Rinse aid being used with mechanically softened water ( makes foam or suds inside the dishwasher )
Leaks from under the unit:
Look for whiting or calcium stain on the motor and pump assembly = motor and pump assembly seal leak...access panel removal help
Hose for upper spray arm split
Fill hose split or fill hose spout air inlet is calcium covered
Drain hose is split
Rusted liner...metal liners only
Fill valve leaking or allowing water to fill all the time
Heating element ends....where they come out through the dishwasher liner
Float or float gasket
for parts you can get it from
www.repairclinic.com
Nov 21, 2009 | Candy Dishwashers
The door leaks at the bottom of the left side.i replaced the seal with a new one and now it leaks worst what the heck???
check your overflow float. it looks like a small cone or hat. it should move up and down freely. if it is stuck down, the machine will fill up too far. the gasket is designed to stop splashing water, not be underwater. good luck
Nov 07, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
At some point the dishwasher leaks onto the floor. what could be the possible problem?
this are the possibilities for the leak :-----
Split spray arm
Door hinge(s) bent
Drain hose is split
Float or float gasket.
Sep 23, 2009 | Whirlpool 24 in. GU980SCG Built-in...
Water leaking out of front door
Leaks coming from the front door are commonly caused by a worn tub gasket. The gasket is located around the perimeter of the tub opening when you opening the door. It can be easily replaced and is not that expensive. The part number is 8269110 and can be purchased at appliancepartspros.com for about $22.
Installation is easy. Just remove the old gasket by pulling it out of the groove in the tub opening. Clean the area to ensure it is free of any debris or build up from detergent or food. The new gasket should have a mark indicating the middle of the gasket. The mark should be on the side of the gasket that is to be inserted in the groove. Starting at the top of the tub opening, insert the center of the gasket first and carefully work the remaining gasket along the left and right sides, seating it in the groove. Make sure you do not twist it. The door may be a little more difficult to shut for a while until the gasket compresses and seats over time.
For future reference, here are some things that can wear these gaskets out.
1. The silverware tray rubbing against it as you roll the lower wash rack in and out of the tub. Knives and forks can catch on the gasket and tear it. Make sure you keep all utensils from the tub edge as much as possible to prevent them from scraping the gasket, or getting closed in the door.
2. Not cleaning the gasket periodicially. The gasket is the part of the dishwasher that water never reaches. If food gets on it and is allowed to dry, it can create irregular wear of the gasket facing, causing it not to seat properly against the door.
If you have any questions, please let me know. I hope you find this information helpful.
Aug 26, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Leaking dishwasher
If your dishwasher leaks, check these:Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Feb 05, 2009 | Frigidaire 24 in. PLD2850 Built-in...
Maytag quiet series 300 leaks from front
check the float switch on the righthand side on the bottom in the corner it should click and move freely
Dec 16, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kenmore Elite Dishwasher - leaks from Overfill Protection Float
I had the same problem, but mine leaked every time. I have a kenmore ultra wash dishwasher no. 665.15762. I took the bottom rotating sprayer off and found that the plastic piece under the sprayer had a few loose screws and the rubber gasket, under that piece, had blown out at the corner facing the overfill protection float. I took out all the screws and re-mounted the gasket in place and put all the screws back and tightened them. It solved the problem. I hope that this helps others.
Nov 11, 2008 | Asko 24 in. D3250 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
187 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
