Question about Bosch Axxis WFL 2060 Front Load Washer
Bosch WLF 2260
My WFL 2260 stops mid cycle and the end light flicks on which then flashes, the water won't drain out and the door is stays locked. This happens on any cycle I try including drain, rinse and spin. Pls can you give me and idea of what the problem might be and how to fix it. Yours Mandi x
  • paali Dec 13, 2008
    i have cleaned all the pipes,pump and removed every bit of built up scale in every pipe possible as well as cleaned the large ball that sits under the drum. the machine intermiittantly keeps stopping again and the machine does not let the ater drain ..red light flashees to show scycle incomplete. please help as my wife nagging me to get it fixed asap. thank you
    paul in london
  • pinky1947 May 11, 2010
    Reckon the first answer (blockage) is correct. We have same issue and have drained machine, pump is clear so it must be before pump. Any ideas how to get there? Tip machine over or remove front panel?
  • 909 Answers
I SUSPECT THE TIMER BECAUSE IT SHOULD STOP EXACTLY WHERE THE PROBLEM AREA IS AND NOT INDICATE END OF CYCLE INDICATORS,.
Posted on Jul 11, 2007
    President:
  • 1,462 Answers
Suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Posted on Jun 14, 2007
SOURCE:
WFL 2260 Fills hot, fills cold, no wash action, move control to drain, empties, move control to spin, no spin but goes thro. cycle ends program door unlatches, any suggestions?
Motor brushes, worse case scenario motor complete. Run the following motor test.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 60 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
6. Motor should rotate in both directions, pump runs, motor kicks up to full spin.
7. No motor action and two lights flashing on progress lights (separated by a light that's not on) indicates a motor fault.
As suggested brushes or complete motor.
Hope this helps
Mar 27, 2013 | Bosch WFL 2063 Front Load Washer
Bosch classix water won't drain
check for blockages in the outlet pipes, filter and pump.
Dec 30, 2012 | Bosch Classixx WFL 2066 Front Load Washer
Bosch washing machine does not do the complete cycle
Here is a tip that I wrote that will help you with your dishwasher2_bing.gif not draining problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Jun 05, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Jan 25, 2009 | Washing Machines
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wlf2260
clean the detergent tray especially the part for the conditioner. on some bosch the rinse water valve is seperate uie different valve for water for main wsash. check valve is not open circuit resistance should be about 3.8k. could also be due to low water pressure
Mar 11, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wlf2260
I had a similar problem and found that the holes above the softner section were blocked by black mold. All I had to do was push a small wire into the holes to clear the blockage
Bosch Axxis WFL 2060 Front Load Washer Logo
1,024 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
