i think you have to set the ide hd primary to disabled then reboot and reenter the bios. refer to this link. the bios settings may be a little different as it is a diff mobo. http://www.mysuperpc.com/build/pc_sata_second_boot.shtml
good luck
Comments:
Mar 24, 2009
- try this as well from msi site:
Installing Windows 200/XP on a single S-ATA Hard Drive
Right after booting off of the Windows cd, you need to push the F6 key when prompted (Fig-a)
Next when prompted (Fig-b) install the correct driver from the floppy disk provided with the motherboard, press the S key to specify the driver, and select the correct driver depending on which controller you are using, then press enter key to continue.
After this Windows 2000/XP will continue the installation, and will detect the S-ATA hard drive to be installed onto.
(Fig-a)
(Fig-b)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS...
(More)
Ive just looked at the specs for two motherboards 1,Asus P6T Deluxe V2 2,Asus M4A785TD-V EVO. WHATS your views on these boards as to building your own computer etc?
tengo una tarjeta INTEL D945GCZ SE DESCOMPUSO LA FUENTE Y LA CAMBIE POR OTRA NUEVA , PERO NO...
(More)
tengo una tarjeta INTEL D945GCZ SE DESCOMPUSO LA FUENTE Y LA CAMBIE POR OTRA NUEVA , PERO NO ENCIENDE LA COMPUTADORA SOLO ENCIENTE UN PEQUEñO LED QUE TIENE LA TARJETA DE COLOR VERDE
