Question about Lexmark P4350 All-In-One InkJet Printer
Error message What does error message 1203 mean
  • jmalvern Jan 16, 2009
    I have the same problem - just installed new printer cartridges. It's telling me to consult the user guide but I can't find it.
  • mustangbull Jan 18, 2009
    I cleaned the contacts did not work changed the cartridge it worked
    Thanks Ray
    President:
  • 2,692 Answers
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would request you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesnt work just call up their support number and check for replacement..
Note: Refilling carts may damage the contacts of the carts as well as the printer.
Posted on Jan 18, 2009
  • Thomas F. Schneider Jan 18, 2009
    Your welcome . Thanks for the vote.
What mean "error#1203"
The 1203 error indicates a problem with your cartridges. This article will help you determine what's causing the problem and resolve the issue: Troubleshooting a 1203 Error Message on the Lexmark X5400 Series.
Apr 29, 2011 | Lexmark X5450 All-In-One InkJet Printer
Printer says cartridge error: error 1203
Remove both ink cartridges and check the bottoms to be sure all of the tap is removed. Small pieces of tape frequently are stuck to the cartridge bottom causing errors. Confirm you have the correct cartridges (# 34 for Black(HIGHYIELD) and #33 for color). Reseat the cartridges and try again.
Sep 06, 2010 | Lexmark X7170 All-In-One InkJet Printer
Error 1203
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Andrea
Sep 04, 2010 | Lexmark X4270 All-In-One InkJet Printer
Error #1203
The error indicates either a communication failure between the cartridges and the printer or by a short in one of the cartridges. Here's an article on Troubleshooting a 1203 Error Message on the Lexmark X5400 Series. Just click on this link: http://bit.ly/aDUAjM. Follow the instructions on the page. However, if the problem continues, I strongly suggest you contact Lexmark technical support for assistance. Thanks.
Aug 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Error #1203
There´s is cleaning issue try to use alcohol to clean the electronic contacts in the head printing slots
Aug 11, 2010 | Lexmark X4270 All-In-One InkJet Printer
Error 1203
Error 1203 means that there is no cartridge attached to the printer head. However, there are some cases when this error message appears because the cartridge is not attached properly to the printer. If this happens, the printer will not be able to identify the presence of the cartridge and thus encounter an error.
http://www.fixya.com/support/t5901483-printer_says_cartridge_error_error
Aug 10, 2010 | Lexmark X4270 All-In-One InkJet Printer
Can't find my manual encountering an error 1203, do you know what this means?
The error indicates there is a communication failure between the cartridges/one of the cartridges and the printer or a short in one of the printheads. Here's an article on Troubleshooting a 1203 Error Message on the Lexmark X5400 Series. Just click on this link: http://bit.ly/8YrwYY. This should guide you on what to do. Thanks.
Jul 30, 2010 | Lexmark X5495 Printer
Printer does not work. is Lexmark x4270 . I replaced cartridge and it shows on panel this message: Error #1203
There are 3 step to repair lexmark 1203 error
If you got lexmark 1203 error then there is a 94% chance that your computer has registry problems. To repair lexmark 1203 error you need to follow the steps below:
* Step 1 - Download a lexmark 1203 error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair lexmark 1203 error.
Here are the url of lexmark 1203 error repair tool:http://www.fixerrorquick.com/ttfix-lexma… http://www.fixerrorquick.com/ttfix-lexma…
Jun 29, 2010 | Computers & Internet
Try to print but i get a messege that reads error 1203
Hi!
Error 1203 means that the cartridges have a bad circuit. Try another set and see if the error message is still there.
If the error message is still there then it means your cartridges overflow even if they are brand new or after a several prints. Check to see if ink is smeared on the holder where the panel contacts with the cartridges. Use the Kleenex with a few drops of water to dampen and clean off those contacts on the holder. Make sure that you don’t left any debris of Kleenex on holder contact panel. If the cartridges are refilled then it works very well if you let it sit for more than 2 hrs. Then before you print anything, you should run align and clean the cartridges a couple of times. Now print a test page to check whether the error message is gone.
Thanks for using FixYa and revert for further assistance.
Thanks
Rylee
Jul 20, 2009 | Dell Office Equipment & Supplies
I am getting a message error 1203
Try this first see if it will help.
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Aug 02, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark P4350 All-In-One InkJet Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
