Question about LG 24 in. LDS 5811 Built-in Dishwasher
Lds5811 pumps motor cycles
Replaced motor after getting a motor failure code and also found a broken gray wire in the door. Now pump motor will cycle when in the rinse and wash cycle, It has run up to ten minutes at a time and sometime only for a few seconds, it usaully will run after it cycles 4 to 5 time. What controls the pump motor that would cause it to cycle, flow sensor, overload? There are also other discolored wires, but they don't show any cracking or stress.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
The pump is supposed to cycle 4-5 times at the beginning to prime the pump motor. This should last only for about a minute.
If your unit has a serial number that starts with 712 or lower then there may be an issue with the wiring in the door. This sounds like your case if you had a broken wire and discolored wires. The issue has to do with black, tarry residue getting on the wires and causing them to deteriorate from the inside out.
If this is your case, call LG customer service at 800-243-0000 and have them refer to service bulletin IDSW20070060. If your unit is out of warranty they may extend it to cover the repairs (the door liner and wire harness will need replaced).
Posted on Jan 18, 2009
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
F28 continues to show on display.
Comunication error between motor control unit and Central control unit. Broken wire in the harness.
F01 power glitch: disconnect power for 2 mins verify correct CCU operation
F11 Motor control unit internal failure MCU board failure or broken wire.
F20 No water detected entering machine, pressure switch hose clogged
F21 Long drain Possible cause: Clogged filter, clogged/failed pump
F22 Door lock error Failed lock. corrosion,or broken wires.
F23 Heater Failure Bad heater
F24 Water temp sensor error Failed sensor or heater
F25 Motor Tach error Bad MCU (motor control unit) or broken wire
F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
F27 Overflow condition Clogged drain, pump, kinked hose.
F28 Com error between MCU and CCU (central control unit) Broken wire
F29 Door unlock error bad switch,broken wire,corrosion
F30 Dispenser system error Bad or jammed motor, broken wire
F31 MCU failure due to motor overheating.
F33 Pump drive system error, broken wire, corrosion
rL (prewash)Clothes detect. Remove clothes and retry.
5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
For diagnostics and further info refer to this handy dandy:
DUET SERVICE MANUAL My tip:
http://www.fixya.com/support/r4232744-duet_sport_washer_error_codes
Mar 21, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
LE error message
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Good Luck!!
Dec 11, 2009 | LG Dishwashers
Pump motor cycles LDS5811
Jan 12, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Pump motor cycles
If you are still having problems, providing the serial number is actually important because of a retrofit to several items in the door panel. Which could actually be related to your symptom.
Please provide the serial number or report back what you did to resolve the problem. Thanks!
Jan 12, 2009 | LG LDF6810 Built-in Dishwasher
LG modèele LDF78105T error code LE
(Just copy and past the above link in your web browser)
Good Luck!!
Aug 15, 2008 | LG Dishwashers
There is an error code that says LE
Thanks for using FixYa!!
Jul 27, 2008 | Dishwashers
Error LE on display of a LG dishwasher model LDF 6180WW Leaves water in the bottom of unit
Thanks
Jun 27, 2008 | Dishwashers
Error F 04
im not up to speed with the codes. BUT if you are able to open the door this suggests the bulk of the water has pumped away, so I suspect motor or belt problems. Can you hear the motor spinning when it should be? ie on spin cycle. If not suspect carbon brushes in motor, or even a broken/burned out wire to motor. Replace belt if broken
Oct 15, 2007 | Hotpoint Aquarius WD640 Front Load...
Error code E1 on LG dishwasher
I have this sometimes where E1 is reported and the pump remains on. The following voodoo has worked for me.
1) Make sure there is not a real drain problem.
2) Cancel any cycle or turn the power button off then on.
3) Run a rinse cycle (15 minutes).
4) If pump continues to run, turn off the power to the dishwasher, let stand for a minute, then repeat steps 2-3. If still not working, leave power off over night and leave the door open then try again.
In each iteration, it is important to curse your LG product and/or threaten it with replacement.
Sep 04, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LDS 5811 Built-in Dishwasher Logo
138 people viewed this question
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
