Question about Indesit 24 in. D63 Free-standing Dishwasher
Indesit D63 Diashwasher Trips Electrics
Had the dishwasher for 3 - 4 years, never any problems.
Last night during a cycle all the plug socket electrics went off in the house - investigated & isolated it to the dishwasher.
changed the fuse & turned on - exactly the same happened - all plug socket electrics went off.
before the dishwasher blew it was making a funny noise (never made it before) possible a straining pump or motor noise? definitely sounded like it was coming from the bottom/back.
which bit is broken? will i be better off jst buying a new one?
  • Robmonster Jan 17, 2009
    I have the exact same issue. It was making a weird rumbling/throbbing sound and wasn't moving on through the cycle properly.
    After manually notching it on a few times it cut out, and now does so whenever we turn it on.
  • 294 Answers
Noise may be coming from faulty parts, but it also may be caused by improperly loaded dishes. heck your owner's manual for proper loading methods. Next, when the dishwasher is completely cool, look in the openings around the pump at the bottom of the dishwasher's interior be sure no implements or hard debris such as bones, fruit pits, or silverware are stuck in them.
Be sure your dishwasher is sitting level. Adjust the feet beneath the unit by screwing them up or down. If there are lock nuts on the feet, make sure they are tight.
A thumping or chattering sound during the filling cycle usually indicates that the inlet valve needs to be replaced. Unless you're handy with this sort of repair, this is a job for a repairperson.
Hardness (Grains) Tbsp. of Detergent
0 to 3 1 4 to 6 2 7 to 9 3 10 to 12 4
cheers!!!
Posted on Aug 02, 2009
My Indesit D63 dishwasher won't close. There is still power to the machine and when you hold the door shut the cycle starts but the door doesn't click shut.
Make sure that the top shelf slides back fully into position. If the flow nozzle does not fully engage onto the water supply jet at the rear of the shelf this prevents the door from closing fully. Sometimes this can be caused by the gasket wearing and preventing engagement this rubber ring is easily replaced and can be fitted by a novice
Dec 06, 2010 | Indesit 24 in. D63 Free-standing...
Detergent and rinse aid dispenter does not open on my indesit d63 dishwasher
the spring is broke in the door to trip it open have to take the door apart or the spring came off that trips it good luck
Dec 03, 2009 | Dishwashers
Tripping of electrics
Check the heater has not shorted out.....feel the heating element it should be smooth ...... if there's a rough spot it has blown and will have to be replaced.
feel the heater
Dec 16, 2017 | Indesit 24 in. D61 Free-standing...
Too hot
replace bad control board
Jun 05, 2008 | Indesit 24 in. D63 Free-standing...
Indesit D61D Sticks In Its Cycle
The repair can be done yourself you need to first purchas a can of liquid wrench with extention. and first shut off power or disconnect power. there is a acess panal that you need to remove to get at gears to grease once it is greased you will need to turn the dial a couple of times (powerless) and replace the panel and plug or turn on power (when you are turning the knob besure to return to the start cycle ) if you need more info please email me kcord44@yahoo.com thank you and good luck
May 29, 2008 | Indesit 24 in. D61 Free-standing...
Leaking Indesit D63 dishwasher
Bad designed and filled with mistakes, I cant lie to you and even reccomend a cure /fix for this.Sorry.
Nov 01, 2006 | Indesit 24 in. D63 Free-standing...
Indesit 24 in. D63 Free-standing Dishwasher Logo
294 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
