Question about Whirlpool GEW9250 Electric Dryer
Elec. Whirlpool dryer shuts off before clothes are dry, unplug to
Dryer shuts off before clothes are dry, then on ocassion, need to unplug and plug in again to get it to start. Dryer vent is clean, lint vacuumed from rear of dryer frequently....no obstructions.
    Novelist:
  • 101 Answers
I doubt it is your motor that is causing the problem. It's always nice when someone says that it is the most expensive part to fix and that is the only solution. It's an electric dryer and there are tons of things that could be causing the issue for you. It sounds like the problem is probably the thermostat. What this does is shuts off the dryer if the heat is getting to high in the dryer. It is a safety feature to prevent it from catching on fire. It is a easy and cheap fix. The thermostat is located usually somewhere near the heating element housing and only costs around 20 dollars at any appliance repair shop. There is a wire diagram located behind the backing of your control panel. Just remove the few screws and take off the housing. It will help you locate the thermostat. If the motor was the problem your dryer wouldn't shut off the way it is. The thermostat is just shutting it down for safety and that is why you need to keep unplugging it to reset it. Change it out and it should work just fine for you. If you have any other questions let me know and good luck to you.
Posted on Jan 22, 2009
Motor
Posted on Jan 15, 2009
Just dried a load of clothes and every thing worked fine. Put in another load to dry and says it is sensing. Nothing else happens
Here's a quick thing to try. Unplug the dryer, wait a minute and plug it back in. Try drying the clothes again. If this doesn't work, you will require troubleshooting from one of the category experts for dryers. Good luck.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
Automatic Dry Function Has Stopped Working
There is a humidity sensor which acts as an auto cutoff switch in most driers, as your load auto dries , it senses the change in humidty and kicks the power off. It is often shaped like a flying saucer with wire terminals on the wings. That is likely your culprit, generally located close to the element. Based on your description, I would start there. Also test a load on timed dry, but it sounds like that's your problem. Remember to unplug before looking under the hood. Post back if you need further info
Sep 20, 2009 | Dryers
Whirlpool dryer - is not drying clothes
Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jun 19, 2009 | Whirlpool LER4634J Electric Dryer
I have a maytag elec. dryer mdet446ayw and the sensoe dry will not shut off when the cloths are dry.
Reach inside the dryer and clean up the sensors, the goop won't allow for the wetness to be detected on the clothes.21b9f8b.jpg
May 14, 2009 | Dryers
Whirlpool ultimate care II dryer: dry clothes sensor
Make sure that the vents are cleaned to include outside. Where it hook on to the dryer make sure that the housing is cleaned also. That should take care of the problem. Thankyou and if you need more help let us know.
Mar 16, 2009 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
874 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
