Question about Frigidaire GLER341A Electric Dryer
Back of dryer gets hot
Frigadare elec dryer. back panel too hot in center to hold your hand on metal. Panel has burned appearance to it
  • Anonymous Feb 05, 2009
    i have the same problem. i can't even put my hand on the back of my dryer, and it is brown from being so hot .it has been this way form day one.
  • michelle wium Feb 05, 2009
    I have the exact same problem with my kenmore electric dryer. It's way too hot to touch on top, near the back and also too hot to touch on the back, and there is a burned brown spot on the back of the dryer. Our venting is good (metal ducting) and clean.
    Are you guys going to get your dryer fixed? I'm not sure if it's worth it since it could be a number of things... such as thermostat, cycler, etc. I don't know what to do!
    Genius:
  • 2,920 Answers
Id say your limit switches arent working correctly
Posted on Jan 14, 2009
The belt attached to the blower wheel on my Whirlpool Cabrio dryer has come off. How do I reattach it?
Unplug the power cord of the Whirlpool dryer from the electrical outlet before installing a new belt. Remove the lint filter from underneath the lint filter cover. 2 Unfasten the screws underneath the lint filter cover with a screwdriver, setting the screws in a safe place. Slide a putty knife between the dryer top and the cabinet near the front, lifting up on the knife to detach the top from the plastic clips on the cabinet.3 Flip the dryer top back against the wall so it is resting on the rear hinges. Locate the screws on the inside of the upper front panel near the top.4 Unfasten the screws on the inside of the upper front panel with a screwdriver. Lift the panel up off the metal clips on the front of the dryer cabinet. 5 Unplug the door switch connector from the back of the upper front panel by hand, setting the panel out of the way. Slide the putty knife between the lower front panel and the dryer cabinet, pulling the knife away from the cabinet to detach the panel from the plastic clips on the cabinet.6 Place a couple of wood blocks under the lip of the dryer drum to hold it in place. Locate the idler arm near the motor at the base of the dryer.7 Move the idler arm forward to relieve the tension on the belt. Take the belt off the motor and idler arm pulleys, lifting the drum up and sliding the belt off the drum.8 Install a new belt around the dryer drum, looping it over the idler arm and around the motor pulley. Move the idler arm back into position to add tension to the new belt.9 Remove the wood blocks from underneath the lip of the dryer drum. Plug the door switch connector into the back of the upper front panel by hand.10 Slide the upper front panel over the metal clips on the front of the dryer cabinet, securing the top of the panel with screws. Fasten the lower front panel to the front of the dryer cabinet, pressing the panel onto the plastic clips by hand.11 Flip the dryer top back down onto the top of the cabinet, pressing down to secure the top to the plastic clips on the cabinet. Fasten the screws underneath the lint filter cover with a screwdriver.12 Slide the lint filter back under the lint filter cover by hand. Plug the power cord of the Whirlpool dryer into the electrical outlet.
  • Oct 11, 2011 | Whirlpool Dryers
    Clothes dryer working but not getting hot air
    Make sure unit is getting 220 from home with a voltage meter. If that is correct, unplug dryer. If lint door is on top then the next few steps are quite easy. If you lint screen is in dryer door then you will need to find a diagram of you dryer. You can do this online at Ny of the appliance repair parts websites. If your lint screen is on top, unplug the dryer and take the back panel off. There is a "one time--non-resettable" thermal fuse near the blower (usually bottom left side). Your volt meter should show this as closed by checking continuity. If not, this may be 1 of your problems. Change it out--always clean all lint out of the unit anytime you have it open. On the right is a long metal tube/shaft area. At the top is another thermal limit fuse(non-resettable) which nerds to be tested for continuity. It should also be closed. Next check the hi-limit thermostat near the bottom of this cylinder. I take them off, hold the metal flange with needle nose pliers and hold lighter under it--be careful not to touch it with flame. Initally, you should be able to test this item as closed on your meter. Using the light will confirm that it will open correctly upon it's heat limit. You should always chevy ALL of these things ANY time you open the dryer. It is a good idea to also check the heater coil. This is usually in the bottomof that metal tube and has 2 screws holding it. Be very careful with this when removing and replacing. The oils from your hands can crate a potential weak spot which will fail sooner than it should. Check this for continuity as well. Replace what you found bad and close it back up. Turn the breaker off to the unit before pluging back in. If you wired something back incorrectly, this will save you a possible electrical burn. Plug the unit in and flip the breaker. Turn it on and you should have heat.
    Nov 19, 2010 | Whirlpool LER5636P Electric Dryer
    I cannot get into Kenmore Elite dryer to install propane conversion
    To remove the top, you will need a medium size flat screw driver and a flashlight. Some of this procedure is a lot easier with a 2nd person, so have someone else with you to help, if possible. First unplug the dryer and turn off the gas valve behind the dryer. You are going to want to use the screw driver to push 2 metal tabs to release the top panel from the front panel. Apply some lifting pressure to the top panel while looking into the gap (with the flashlight) between the top and front panel. Look for 2 metal tabs, which are usually painted black. When you find them, push them (one-at-a-time) forward horizontally with the screw driver until you hear it pop and release. Once you get both metal tabs released, you can lift the top panel. NOTE: This is where you need a 2nd person to help. Before you lift the top panel, have someone else hold the front panel. The drum rests on the front panel and will fall down without it's support. You will also need to disconnect a few wires to remove the front panel. Take note where they hook-up for reassembly. Grab hold of the drum and have the 2nd person pull up on the front panel to remove it from the grooves at the bottom. Find something or someone to hold up the drum, so you can work hands free on the dryer conversion. If you need more assistance to do the conversion, just let us know!~Good luck!
    Douglas
    Jun 02, 2010 | Dryers
    Will not heat does not get hot
    unplu the dryer, take the vent off the vent tube, take out the metal tubes holding the back cover and tae off,inside you will see an oval shaped tube with two wires coming out,there is a bracket with one metal screw holding it,take ot,loosen the two wires,take out the tube ,another metal screw holds in the heat element,take out the element check the coil it may be burned out if so replce i do hope this has helped you then reverse the procedure , thank you.
    Dec 24, 2009 | Crosley CDE6000 Electric Dryer
    TRY TO START DYER AND IT JUST HUMS I HAVE A FRIGADARE ELEC FRONT LOADING DYER
    The belt may have broken, otherwise you have to use a multimeter to troubleshoot the problem.
    Aug 17, 2009 | Frigidaire Dryers
    I'm getting burn marks on clothes. Think it's the seal on the back of dryer? Must hang to dry all white clothes, so what's the point o fhaving a dryer?
    The gasket between the drum and the back panel may be worn or missing.  I had a similar problem with a 34 year old dryer when the felt gasket wore out and allowed metal-to-metal contact between the drum and the back panel.  The clothes would get pinched between them and make a black "kiss" mark.
    May 18, 2009 | Dryers
    Trying to wire a 3 wire dryer from panel box to dryer plug
    Sounds like you have a 10-2 NM wire. One black, one white, one bare copper. At panel box, black to one hot terminal of breaker or fuse holder (L1). White to other breaker terminal or other fuse holder (L2). Bare copper to the grounded neutral buss bar.
    At the dryer the bare neutral goes to the center terminal, the other two go one each on either side, it won't matter which way. Hot Neutral Hot. The neutral terminal of the dryer should have a wire or metal strap connecting it to the dryer frame if you are not using a four wire supply.
    Oct 22, 2008 | Dryers
    Kenmore Laundry Center #417.90802990
    unplug it drop the panel between easher dryer remove the metal panel behind it remove 2 screws each side controls panel reomve control panel unplug the switch going to dryer door let panel hang down remove 2 screws bottom door panel one each side remove 4 screws on the top front panel with door will fall in your hands oyt seals on it let dry
    Feb 28, 2008 | Dryers
    Frigidaire dryer model #FDE336RES1
    The Thermistor is defective, you could get it online.
    Feb 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
    My kenmore 417.94812301 staked washer / dryer problem
    Your dryer was made by Frigidaire and needs what is called a rear bearing kit (#5303281153 costs about $30) from frigidaire.
    there is also a good chance that your bearing failed because the dryer overheated (overheating is mostly caused by the venting being restricted)
    Oct 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
    Frigidaire GLER341A Electric Dryer Logo
    386 people viewed this question
    Top Frigidaire Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
