Question about Apple Cinema HD 30" LCD Monitor
Hi,  i need to download drivers for installing the apple cinema 30inch display on my mac pro (leopard). Could you tell me please where i can get them, i can't find the cd and i don't see it on apple's site. thanks.
  • 40 Answers
The drivers are included with Leopard.
Check your video card to ensure support for this display.
Posted on Mar 02, 2009
Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Apr 23, 2011 | Apple Computers & Internet
My problem i install win xp on mabook pro model a1278 vga and sound and nework card not installed and i want driver for win xp
you need to insert the leopard or snow leopard dvd into your macbook while you are bootcamp to win xp.
run the bootcamp and it will install the drivers for sound, nic, wifi etc.
also download the latest bootcamp drivers from apple.com
Mar 28, 2011 | Apple Refurbished MacBook Pro 2.6GHz Intel...
Need OSX Snow Leopard Driver for Laserjet 1018. Have MacBook Pro 13".
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
Feb 09, 2010 | Apple MacBook Pro MB991LL/A 13.3-Inch...
I am using an Apple 30inch Cinema Display with a MacPro Desktop. Occasionally, Lines would appear on the screen and I would have to restart my computer, but not the screen, upon start-up, has a number of...
This sounds like a video card issue with the Mac Pro, have you tried testing the display with a different computer?
Next, check for any software/firmware updates from Apple and install if necessary.
Next, I suggest resetting the SMC to flush out any legacy niggles, this can be accomplished by following these instructions as provided by Apple.
To reset the SMC on a Mac Pro:
  1. From the Apple menu, choose Shut Down (or if the computer is not responding, hold the power button until it turns off).
  2. Unplug all cables from the computer, including the power cord and any display cables.
  3. Wait at least fifteen seconds.
  4. Plug the power cord back in, making sure the power button is not being pressed at the time. Then reconnect your keyboard and mouse to the computer.
  5. Press the power button to start up your computer.
Another way to reset the SMC on a Mac Pro computer is:
  2. Open and remove the metallic outer door.
  3. Press the SMC_RST switch that is located slightly below and to the right of the row of diagnostic LEDs. Use a non-metallic, non-conductive object, such as a wooden pencil. Note: Mac Pro (Early 2008) does not have an SMC_RST switch, refer to the reset procedure steps in the previous section.
  4. Replace the metallic outer door.
If the problem persists and you have identified that the problem is definitely with the display then any further information you can provide would be most helpful in diagnosing the problem - otherwise, if it is the video card then (assuming it's still warrantied) get in touch with Apple. If out of warranty then I'm sure we can guide you through the replacement process if needed!
Oct 28, 2009 | Apple Computers & Internet
Sound problem
Actually, what you have to get is the Vista version of the High Definition Audio Codecs fom Realtek .... http://www.realtek.com.tw/downloads/downloadsCheck.aspx?Langid=1&PFid=24&Level=4&Conn=3&DownTypeID=3
Insert Leopard DVD for Boot Camp Drivers [if you know how to use torrents then download from here http://thepiratebay.org/torrent/3860505/BootCamp_2.0_(Leopard)_Windows_drivers] . Don't auto-run the installer. Navigate to the drivers folder and there you find the individual .exe files files for each driver.
Right click on the RealTek driver and select 'troubleshoot installation'. Windows will ask you several questions, but basically the gist of it is to tell Windows that 'This driver used to work OK in Vista'.
or
You need drivers of boot camp on mac osx 10.5.4 dvd.then open Drivers folder, you will see RealTekSetup.exe right click then click to troubleshoot compability. A window will apper.You'll se Program Compability click next below. Select "the program worked earlier versions of windows but won't install or run nom." and click next. Realtek Setup will start and install drivers. solution is just this.
Lemme know if this solved the problem...
Aug 22, 2009 | Apple MacBook Pro Laptop Computer with...
Audio driver for Macbook pro
The drivers for XP are on the official OS X Leopard DVD. Install this when running XP and then run the Apple Drivers Set up on the disk.
Jan 20, 2009 | Apple MacBook Pro Laptop Computer with...
Where to download drivers for the apple cinema 30inch display
The drivers are included in Leopard.
If the display is not working please ensure the video card you are using is compatible with the 30" display.
Jan 14, 2009 | Apple Cinema HD 30" LCD Monitor
My Mac won't run Call of Duty 4
Run Software Update and update your Mac OS X.
Apple releases updates for Mac, like Vista and Service Packs, but Mac uses Mac OS X 10.5.X and X is the patch.
Usually you wont see any changes because they are security fixes
Jan 01, 2009 | Activision Call of Duty 4 Modern Warfare...
Cannot print from my Intel based MAcBook Pro on my Epson Stylus Photo R1800
mac book pro has a usb cable right? you can actually use it to connect to the r2400 and then dont use a guten driver use the downloadable driver for r2400 for leopard instead
Macintosh OS X 10.5 drivers for your product are available for download from the Epson support site.
1. Go to the Epson support website (www.epson.com/support).
2. Select your product model and download the driver for OS X 10.5 Leopard operating system.
Note: Be sure to select the appropriate driver compatible with your system: PowerPC or Intel Intel based.
May 15, 2008 | Epson Stylus Photo R1800 InkJet Printer
Installed hp laserjet 3380 on apple desktop pro - message printer stopped
See if it is the right driver. Intel Mac is not the same driver set as regular Mac.
Also, Apple + HP or Okidata often = issues.
Jan 12, 2008 | HP LaserJet 3380 All-In-One Printer
Apple Cinema HD 30" LCD Monitor Logo
400 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
