Question about Xerox DocuColor 3535 Copier
Red toner streak on prints
Red lines on print out
    President:
  • 2,072 Answers
Most likely you need to replace the red drum. If that doesnt work the developer housing is bad. Most likely though the red drum is bad,
Posted on Jan 15, 2009
Bizhub c200 printing with streaks of red and blue lines what to do
If that lines are consistent with the red and blue and it does not appear during black and white print that means the cleaning blade in the affected color units need to be replaced
May 16, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
When the paper prints, the color is missing in areas. It looks like a streak mark down the page. The black ink is full color, they yellow and cyan have a white, non-printed streak down the center, and...
Inspect the rollers for dirty or damaged surfaces. Clean up any loose toner or other debris in the machine. Note: avoid touching any roller with bare skin; especially in the fuser section or the photosensitive drum in the toner section. Skin oil can cause poor print quality or premature degradation of the roller surface.
Jul 06, 2017 | OKI C3200n Led Printer
There are streaks on the side of the printed page
Are the Streak lines vertical or horizontal ? Most likely it could be due to Toner issue, Try to remove the toner and clean it and re-install it
Regards,
Suhail
May 15, 2012 | Ricoh Aficio SP C820DN Laser Printer
Color streaks on page
Had a similar problem. Tried lost of things. In my case, the streaks cleared up after I cleaned the toner drum.
Aug 25, 2009 | Brother MFC-9420CN All-In-One Laser...
My LaserJet printer prints lines or streaks on every page
Can't read the entire heading for your post, but it sounds like a defective toner cartridge. Replace it.
Apr 25, 2009 | HP LaserJet 1320 Printer
Blue streak printing on page
Chances are you have a bad toner. The lines a spaced about the same width as the diameter of the drum on your blue toner. Shack the toner and try again. The toner may also be spilling toner into your printer.
Mar 03, 2009 | HP LaserJet 3600n Printer
It prints vertical lines where the text is.
check your drum unit. The toner cartridge mounts into the drum which can be permanently charged causing a constant streak to occur.
Solution:
Remove the toner and drum unit. Clean them off with a non-fuzzy non-rough cloth or paper towel. Pay particular attention to where the streaks are in relation to the toner cartridge and drum. If you clean it off and you still get streaks check whether they transfer from the toner or just from the drum.
There may be a way to discharge the drum, otherwise you need a new drum.
Feb 27, 2009 | Dell 946 All-In-One InkJet Printer
Print page on SCX4100- streaking lines
Clearly bad toner cartridge. After long periods of time, the cleaning blade dries out. This cleaning blade works just as the wiper blades of your car. When they wear or dry out, you get streaking water lines in the windshield. Most manufacturers print an expiration date on the consumables wichi you can check before purchasing. Also try not to stock more consumables than those you plan to use within 6 months.
Nov 03, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
Samsung CLP 510 light grey vertical streaks
you have 2 problem.
1). toner is bad
2). toner is low
change the toner should fix both porblem.
try to clean the roller while you have the toner out. (just in case).
Mar 27, 2008 | HP LaserJet 5p Printer
333 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
