Replaced a HDD ? Sounds like a Graphics Adapter problem, if you connect it to a External Monitor, is it the same? How about booting to Safe Mode, still same? When does the dots/squares appear? At Boot? Does the Laptop overheat? Does it need cleaning? Fan, vents, heatsink? Does the Thermal Paste need replacing? I had a similar issue with the Graphics Adapter in a Sony Vaio, dots, lines, squares, frozen, I informed the owner it's basicly dead, unless you replace the Motherboard. If you Post the Make, Model of Laptop and the OS you are using it would be helpful.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
back up everithing in your hard drive (image file if u can) and recovery CD so u reset it to factory defaults. if it's still getting worse. go to a repair store, monitor or video bus is malfuncioning.
I have a laptop that has been doing exactly the same. It started off with a fine pink line. After almost a year it now has gotten wider and has white lines and all other colours. It could work like that for quite a long period. It is a conection in the bottom of the screen but is so delicate... Only way to REALLY fix it is to have the screen replaced which could be quite an expensive thing to do
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
