Question about Motorola Mobility RAZR V3
Phone will not stay on
Short length of time and had to charge often...then switched off and would not stay on charge made no difference then dead put another battery in charged again only only one bar came up still off wont work could be bad battery or is it the charger or something else phone is 2 years old thanks annie
  • 3 Answers
Maybe your mobile battery is defected ,
Posted on Jan 14, 2009
We purchased a Samsung Galaxy 6 cell phone on Jan. 22, 2016...which has a completely dead battery only after using it for 2.5 months. We would like to know where to send it for a replacement.
Possibly the charger isn't working?
Regardless of what might or might not be wrong, you paid for a phone that would give service for a reasonable length of time - a similar length of time other owners of similar phones enjoy. Often this amounts to years rather than months.
Your phone should be under warranty so check your paperwork. If the manufacturer doesn't accept responsibility for a free of charge repair or replacement then you should return it to the place you bought it from with whom you have a contract to be supplied with a phone of merchantable quality. A premium quality phone that stops working after such a short time is obviously not of merchantable quality.
Whether it is manufacturer's warranty, statutary rights or consumer protection legislation, you should not have to pay, but read the paperwork first...
May 02, 2016 | Samsung Cell Phones
Uniden cordless phone not working
Yr battery is probably Shot. With these type of batteries they can fall over if they go below 25% charge for a length of time. The charger is not charging even though it says it is. If the phone is not to old then get a new battery and try again. cheers
Sep 06, 2012 | Uniden Cordless Phone
Samsung c140 dead
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Jul 18, 2011 | Samsung C140 Cell Phone
Nokia n73 phone dead
1. Water damage
2. Fall down
May 24, 2011 | Nokia N73 Cellular Phone
I need to find an 1998 oldsmobile regency wiring diagram for free online the battery does not stay charged i have tried switching batteries and still does the same thing its only staying charged for the...
if the battery cable end have corosion on them the current is not able to charge battery. If you put a multimeter on volts dc 20volts and the car is running and charging properly, the meter should read approx. 14.73 volts. Clean the inside of the cable ends, and the posts on the battery with a wire brush, then coat all of them with some vaseline. Hook them up and tighten. If that doesn't work you will probably need the diagram, to trace a dead short.
Aug 29, 2010 | 1998 Oldsmobile Regency
Nokia 6500 wont charge
Where you connect your charger there is a loose connection there,what i can tell you for your phone to stay alive is just buy an universal charger it is not expensive,you put your battery in then after charging replace it in your phone and the problem is solve .
Feb 09, 2010 | Nokia 6500 Classic Cellular Phone
Samsung sgh-e635 phone
The phone may have an internal short, either due to bad weather or water / humidity damage. If its under warranty take it for exchange. a new board will cost upwards of $100
Jan 25, 2008 | Samsung SGH-E635 Cellular Phone
Can't recharge 2nd phone
put the second handset in the base of handset 1 for a short while,,,,this should solve your problem Brian
Sep 09, 2007 | Uniden Cordless Phone
Motorola PEBL U6 Cellular Phone
There could be corrosion on the actualy board or something could have been shorted out. Get a new one.
Jul 01, 2007 | Motorola Mobility PEBL U6 Cellular Phone
Motorola Mobility RAZR V3 Logo
96 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
