Question about HP iPAQ HX4700 Pocket PC
Can I used Windows Mobil 5 instead of 2003 Second Edition?
If so, how do I go about doing that?
Thank you!
    Problem Solver:
  • 6 Answers
Http://wm6.winmobile.us/hp_wm5_4700_install.zip
then update after with:
http://wm6.winmobile.us/hp_wm5_4700_rom_updates.zip
Posted on Aug 31, 2009
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
What is Series
full version o ms office 2003 professional Edition 2003. Used Os for windows XP service pack 2,3, windows 2000, windows vista, windows 7. support for OS this serial Key & cd key - gj4cy - fdg49 - fv6bg - 6y9km - pbt7m.
Thank You.
Regards,
Karan
Feb 21, 2011 | Microsoft Office Professional Edition 2003...
I can not uninstall ms office professional edition 2003 how will i uninstall this/
  • Click the Windows "Start" button and select "Control Panel."
  • 2 Double-click the "Add or Remove Programs" icon. This icon is labeled "Programs and Features" in Windows Vista and Windows 7.
  • 3 Single-click the "Microsoft Office Professional Edition 2003" item in the list of installed programs.
  • 4 Click the "Remove" button. If you use Windows Vista or Windows 7, click the "Uninstall" button near the top of the window instead.
  • 5 Click "Yes" when prompted to confirm your choice by Windows. The uninstallation process starts immediately.
  • or try some uninstaller tool .
    Sep 16, 2010 | Microsoft Computers & Internet
    Hi , We are having 2 windows servers with identical configuration, and also we are using the windows 2003 with vendor application, We installed 8 GB of RAM in both server , But I could only 4 GB amount...
    Hi
    To reply your query in short. If you have any of the following versions of server it would support the maximum RAM upto 4 GB.
    Windows Server 2003 R2 Standard Edition
    Windows Server 2003, Standard Edition SP1
    Windows Server 2003, Standard Edition SP2
    Windows Storage Server 2003
    Windows Small Business Server 2003
    If you are using : Windows Server 2003, Web Edition
    It will support only 2 GB of RAM
    For your information to get a complete information about Memory Limits for Windows Releases. Please visit the following site:
    (msdn.microsoft.com/en-gb/library/aa366778.aspx)
    If you find it useful please do not forget to rate this solution.
    Jul 14, 2010 | Microsoft Windows Server 2003 Enterprise...
    I have windows vista sp1 and couldn't intalled Office 2003. Now I have got Office 2007 up and running but I want Office 2003 instead of Office 2007 because I'm used to its toolbars etc. Is there any...
    its should be install on your computer using windows vista but still persisting and you want to have the office 2003 instead of 2007 better to reformat it again and use WINDOWS XP instead. After the installation is should work with no sweat. hope that helps
    thank you for using fixya
    CHARCOIS
    Nov 07, 2008 | Computers & Internet
    MFC-8440 PRINTER DRIVER
    Go to:
    http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_top.html?reg=us&c=us&lang=en&prod=mfc8440_all
    Follow steps below :
    Step 1: Select Type
    Drivers Utilities (ALL) common_012.gif Step 2: Select OS Windows98 WindowsMe Windows NT4.0 Windows2000 WindowsXP Home/Professional WindowsXP Professional x64 Edition Windows Vista Windows Vista x64 Edition Windows Server 2003 Windows Server 2003 x64 Edition Windows Server 2008 Windows Server 2008 x64 Edition Mac OS 8.x-9.x Mac OS X (10.1) Mac OS X (10.2) Mac OS X (10.3) Mac OS X (10.4) Mac OS X (10.5) Step 3: Select Language Good luck!
    Jul 21, 2008 | Brother MFC-8440 All-In-One Laser Printer
    Ipaq windows mobile 2003 upgrade
    This is a VERY general question. There are many many software upgrades for the ipaq rx3715.
    If you mean upgrading the OS, then nothing short of Linux is available.
    Otherwise, please ask a more specific question.
    Jul 12, 2006 | HP iPAQ RX3715 Pocket PC
    Toshiba e400, Windows Mobile Second Edition
    We´ve successfully reverted back to the original windows mobile 2003. Was no problem. This English Version is Worldwide... Also for your Canada PDA
    Sep 11, 2005 | Toshiba e400 Pocket PC
    HP iPAQ HX4700 Pocket PC Logo
    321 people viewed this question
    Top HP Computers & Internet Experts
    Brian Sullivan
    Brian Sullivan
    Tony
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
