Question about Neff W5340X0 Washer
Neff 5644 - how does it work!??
I've inherited a NEFF 5644 integrated washer dryer (I presume) and have no idea how to work it. it has three buttons on the front. An E in a bucket? A spin 1000? a half load and an on/off. Then it has two dials one is the programs (with some weird and wonderful symbols!) the other is a temperature dial (no idea what it's for!). It seems to work okay ish, if i set it at a 30/40 degree cycle the water doesn?t get hot, if I set it at a 95/60 cycle it gets absolutely boiling. I can't get the thing to dry at all not sure if that?s just because its broken or because it is not a washer dryer just a dryer. I've phoned Neff and they say it's such an old model they no longer have the manuals for it. Does anyone out there know how to make it go, or should i just go buy a nice new Hotpoint......
    President:
  • 1,462 Answers
"e" is economy - ignore this there is a selection of spin speed - most people use the fastest half load is what it says - most people wash a full load so ignore the temp dial just selects wash temp. for normal washes set to 40deg can't remember the symbols on program dial but think they are fairly self-explanatory this machine is just a washer remember to check the filter regularly
Posted on Jun 14, 2007
V4380X0GB/13
Try Googling (Neff)(V4380X0GB/13)(manual) without parens or contact Neff directly to request the manual.
Jun 07, 2017 | Neff Washing Machines
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
NEFF V4380 WASHER MANUAL
You should be able to find one on line or call the makers customer services and they may send you one
Jun 02, 2014 | Neff V4380X0 Front Load Washer / Dryer
I have a Neff integrated washer/dryer. The machine seems to turn on and take in water but doesn't start to spin. It sit's for half an hour making clicking noises then will start spinning and finish the...
Assuming that it pumps out okay then could be the motor.....Check belt is okay not fallen off , next motor brushes, they wear out after around 6 yrs ,
Apr 01, 2011 | Neff W4380X1 Front Load Washer
My neff 4380 integreated washer dryer's drum only
Hi I have exactly the same problem. Did you get your fixed and if so what was the problem?Many thanksCarole
Apr 04, 2010 | Neff W5340X0 Washer
Neff washer dryer V5360XOGB red led light keeps going round
THIS IS A POWER MODULE FAULT IT WILL NEED REPLACING IT SITS AT THE FRONT LOWER RIGHT HAND SIDE THEY ARE NOT CHEAP.... SORRY
Aug 09, 2009 | Neff W5340X0 Washer
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
Neff washing machine with error code 6
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
Jan 18, 2009 | Neff W5340X0 Washer
Neff W5340X0 Washer Logo
245 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
