Question about Linksys Wireless-G WRT54GS Router (e125894)
Linksys WRT54GS shows that it connects, but doesn't really
Our school district recently purchased 10 of these routers to use in our grade school to provide wireless access for laptop use. Upon installing them, the laptops showed that a wireless network was available, but when we connect to it we are unable to receive the Internet or network access of any kind.
I had an online chat session with a linksys technician. He told me that these will not work with our school setup, but wasn't sure why. Can anyone verify this? I'm not sure how to explain our setup, but we have a server room. Our T3 connection comes into this room and connects to a modem which then connects to a router which then connects to hubs and switches. From those, ethernet cables are strung throughout our building to drop boxes. From these drop boxes, ethernet cables are placed into the computers. Our Internet works beautifully with our wired Internet. So...I hook up one of these ethernet cables from the classroom into the WRT54GS, set it up via the IP address online. It acts as if it connects, but when I go to get on the Internet it will not let me.
For some reason, I think there is an IP conflict because since setting one router up, I have received several IP conflict messages on the computers in my lab. When I change the IP address of the router, it freezes up the web page I'm on and I end up having to reset the router.
So many questions...I know. I really just need to know how to set these up on our existing network--or if it can even be done.
  • 2,460 Answers
How could I possibly be smarter than the Linksys tech?
Do your computers have fixed IP addresses or obtain DHCP from the main router? You need to know this because you also need to let one or the other serve DHCP. If it were my system, I'd let the main router serve and the access points just exist.
For that to happen, you need to pick a fixed IP address outside of the IP addresses that can be assigned by your equipment, or pick one that is unused by your network devices.
Unplug the WAN cord from the Linksys and set your computer to 192.168.0.5 or 1.5, depending on what the Linksys does by default. Log into the Linksys and make it use a fixed IP address on the WAN side to whatever you need. Now, as I said above, I'd trun OFF LAN DHCP so it gets DHCP from your network router.
Now reset your laptop to use DHCP, power down the Linksys and plug it into the netrwork and power it up. From any computer on your network, you should be able to go to the router's fixed IP address and be looking at the login screen. Log in, change your password, and you should be up and running :-)
Note that there are a TON of variations on this theme, so don't despair if it fails to work. The key is knowing what your network requires.
Carl
Posted on Jan 14, 2009
Do i a modem to use with my Linksys Wireless WRT54GS
You dont require a modem as there is a built in modem in linksys router.
May 28, 2012 | Linksys WRT54GS Wireless Broadband Router...
I have been running a Linksys BEFSR41 version 2 wired router for over 5 years without any problems. My wife is a teacher and her school p[urchased new laptops recently so I decided to go wireless. Got on...
I think the most likely problem is that both routers are using different IP address ranges and won't allow data to pass between them.
I suggest you use only the Linksys wireless router.
Nov 17, 2010 | Linksys Wireless-G WRT54GS Router...
Set ssid for wrt54gs
You do that in the router setup an SSID is simply a "Name" that You give it. You log into the router, 192.168.1.1 use admin/blank and admin as login & password..once in the router you set it up with the wizard.
here is a manual to help you.
http://www.retrevo.com/support/Linksys-WRT54GS-Wireless-Routers-manual/id/421ci076/t/2/
Feb 23, 2010 | Linksys WRT54GS Wireless Broadband Router...
Wireless router is not working
Go to Here for Linksys EasyLink Advisor (LELA). With this software you can monitor the routers status and troubleshoot.
Most trouble shooting involves disconnecting the power to the cable modem and the wrt54 router for about 10-20 seconds. Then plug in the modem until it lights, then plug in the router. The Advisor will then get a new address.
It also shows a graphic picture of your whole system.
I have a wrt54 and use this whenever I have a problem. I fix it then turn it off.
Hope this helps.
Good Luck
Feb 19, 2010 | Linksys Wireless-G WRT54GS Router...
Im trying to set up internet for my ipod touch and it wont let me access internet without the linksys password and the model in wrt54gs... how do i find my password
Yes, you really need a password for that (either WEP or WPA). You can ask for the password to the one who configured the router. They placed a password for security reasons. In order not all people can access net, only those who knew the password.
Jan 03, 2010 | Linksys WRT54GS Wireless Broadband Router...
I have an Linksys Wireless G WRT54GS router. I
This is strange... Never heard of it in all my years. Call Linksys www.linksys.com and then ask them becuase this is rare. If they can't find a solution just steal the internet :)
Oct 13, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys router does't really work...
unplug for 10 seconds then replug back in.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys WRT54GS
No, you should however, log into your Linksys's admin page and copy your settings down. Put those back into your Netgear and you should be good to go.
Feb 15, 2009 | Linksys Wireless-G WRT54GS Router...
The port of Linksys Wireless-G WRT54GS Router Linksys Wireless-G WRT54GS Router
What do you want to know about the ports? The one separated from the other ports is the Internet port. that is where you're going to connect the cable from your modem. The other four are the ethernet port where you will connect the computers.
Jan 22, 2009 | Linksys Wireless-G WRT54GS Router...
Going wireless with Lexmark X5470
NO you cannot go wireless with the the Linksys wireless-G broadband Router WRT54GS for this printer, to check the wireless print sever you need to click on this link and then click hide/show additional results and it will cost you $149,
http://search.lexmark.com/printer/US/en/22N0000
instead you can buy a wireless printer from Lexmark X6570 which is also $149.
May 18, 2008 | Lexmark X5470 All-In-One InkJet Printer
Linksys Wireless-G WRT54GS Router (e125894) Logo
83 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
