Question about Relisys RHTP200 DLP Projector
Relisys projector will not show presentation from laptop
I have tried the F5 key and also have switched display to presentation the projector doesn't recognise the signal it seems as the laptop does change to the other monitor output. I have used the computer/s-video/video/dvi/ycpbr settings. The cable I am using is a hdmi one into the projector with red green and blue plugs and it is plugged into the monitor port on my laptop..
  • 2,236 Answers
The signal resolution may not match on the projector.
Posted on Aug 19, 2009
How to connect wonderwall projector to computer?
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Sep 23, 2012 | Discovery Channel Discovery Expedition...
My hp compaq model 510 is not working with projector.projector is not working on this laptop plz provide a proper solution.
You are not providing enough information to help you.
Have you set the display to use an external monitor or dual monitor? That is how laptops work with projectors. You normally can set the system for dual display and either mirror the displays or use the second display (projector) for power point or other presentation.
If this does not fix the problem, post more information on why it is not working for you.
Jun 23, 2011 | HP 510 Notebook
I want to presentation a power point but, when i display it on the projector, my lcd laptop be black and show nothing. what i am ding? thanks
There is a key on the keyboard that is designed for external display. You need to press the Fn key and either F5 or F10 (depends on what key is it) simultaneously to toggle between displays.
If you've already pressed the combination but unsuccessful to get it work, try to adjust the resolution of the projector, you need to lower it down to get it work with the laptop. You can also try to lower the resolution of both displays.
Hope this helps.
Jun 06, 2011 | Computers & Internet
I can't connect my data projector to Aspire One Pro Netbook. Why doesn't it show my powerpoint presentation?
just connect the vga cable to vga port of laptop and to the projector and in projector choose the source of display vga or pc mode and in laptop press f5 button or right click on desktop and choose the display mode lcd +monitor it will show you the display on projector.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | Acer Aspire One PC Notebook
I cannot get my lap top to show on the all with my projector
Laptop will often have a function key (usually F5) for cycling between built-in display, external monitor, and both. Try pressing F5. If that doesn't work and you have a "Fn" key (usually near the left Shift key) hold down Fn and press F5.
Oct 11, 2009 | Compaq Presario Notebook
Need to connect my dell laptop to a large screen projector using a computer video interface for vga and compatible computers I have a delllatitude d610 the interface is an inline2080
I assume you know how to connect the VGA cable and which function key is used to activate the second display. You will have problems if the laptop display size is not supported by the projector. Many older projectors will not work with wide screen laptops.
when you connect the projector, Just press the presentation mode on your keyboard, Fn + (Presentation Key), Sometimes F5 or F8!
Then you will see your desktop on the projector screen.hope this helps
Aug 13, 2009 | Dell Computers & Internet
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Acer Aspire 1642 WLM not showing with projector
Try other F keys..other wise try Ctrl+alt+function key
Dec 08, 2008 | Computers & Internet
Acer extensa 5620Z laptop running XP. function/F5 key does not work to switch from monitor to projector display. Any suggestions gratefully received.
Plug in the Projector before pressing FN+F5
(Just in case your not sure, you have to Press and hold the "Fn" button near the "Ctrl" button and then press "F5")
Try again
Oct 07, 2008 | Acer Computers & Internet
Connecting cinego projector to hp laptop
don't know much about the cinego ( resolution ect)
but on most laptops you will have a "F" button or function key near the top row.. mine is F5 that has 2 square icons to show 2 monitors, 1 black, 1 white, when your projector is hooked to your laptop, hold down the FN key probably lower left or right, and tap the F5 or f7 which ever has the 2 montiors on it, it should be a 3 position switch, 1..laptop only, 2 laptop and projector, 3rd position projector only.
that cingo is pretty low-end so you may have to goto display properties on your laptop and reduce the resolution to 800 x 600 or 1024 x 768.
if you can't get a setting that works, try the 3rd position with just the projector display on, and laptop display off, since your laptop screen is higher resolution it corrects a lot of issues.
Jul 14, 2008 | Radio Shack Cinego D-1000 Multimedia...
Relisys RHTP200 DLP Projector Logo
107 people viewed this question
Top Relisys Office Equipment & Supplies Experts
k24674
Are you a Relisys Office Equipment and Supply Expert? Answer questions, earn points and help others
