Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Ge side by side warm on both sides
I have a 5yr old ge side by side that was unplugged for six months. Upon
turning unit back on it now wont get cool in the fridge or the freezer wont work. The unit sounds to be operating fine.
  • 979 Answers
Check the thermostat settings and then check to see if the fan is turning. It probably is not the compressor since it is only 5 years old. Does the compressor get warm? Let it run for several hours to give it a chance to get started back up well.
Posted on Jan 14, 2009
    Genius:
  • 2,920 Answers
You could have lost some of your freon
Our refrigerator is only about six years old. The problem began after the refrigerator was unplugged for about six weeks and then plugged back in. The freezer side works just fine. The refrigerator side...
Maybe corrosion in the cold control. Could be a fan shutting down. When fresh food side is warming up , is fan running in freezer? My guess with the information given. A simple repair.
Mar 28, 2011 | Refrigerators
I have a GE GSS25XSRSS Side By Side refrigerator
no defrost taking place
a clock
b heater element/hot gas valve
defrost terminator or safety fuse
Mar 17, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
Turbo cool will not turn off in GE side-by-side refrigerator. Replaced circuit board...still stays on
There are three temp sensors in my GE side-by-side model GSS20IEMDWW (two in the freezer and one in the fresh food side). Replacing the temp sensor in the fresh food side was enough to allow the compressor to finally turn off.
For me, the problem manifested with an iced-over evaporator coil inside the freezer compartment. Since the compressor never cycled off (presumably because the temp sensor was providing faulty data about the temp inside the fresh food side, thus causing it to continually attempt to cool), the coils were constantly chilled. Eventually the ice on the coils would block the air flow and the freezer side could no longer freeze
I purchased a pair of inexpensive thermometers from a kitchen store and put one in the freeze and one in the fresh food side so I could occasionally look at the temps to see if it made sense for the compressor to be running - ie, was it really a warm-enough temp for cooling to be required, or was the computer reading faulty sensor data.
Six months later I also needed to replace both temp sensors in the freezer compartment. My refrigerator is about seven years old. I would recommend replacing all of the temp sensors just to rule that out.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS20IEMDWW&mfgModelNum=&fkMfgID=2
Your model may be different, but this will give you an idea of part numbers and relative locations of the parts.
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Monogram side by side not cooling
I had the same problem. GE Man said that since the unit had been allowed to warm so much, we needed to empty it, unplug it, and totally leave it alone for 24 hours for any excess water to drain out. Then, we needed to plug it in and let it run with NO ITEMS INSIDE AND NO OPENING OF THE DOORS AT ALL for 48 hours. After that, we started using it again and it was Perfect!! I thought it was a lost cause, so this worked and didn't cost me a dime!!
Jun 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by Side - dead, again
check defrost timer . plug in and turn timer manualy and see if unit starts running. This means it was in a defrost mode which occurs twice daily.
Feb 21, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge side by side 5yr old Refrigerator
you will most likely have to replace the main controller board.. I have had the problem come up before and the GE boards are known for going out..The board is located on the back right side of the refrigerator has a cover plate about 6" across and 8" high The most likely failure is the relay to turn on the compresser (it is a small bk box on the board) you can unplug it and open this panel plug it back in and tap the relay with the back side of a screwdriver and see if you hear the compressor running.. Let me know
Jan 26, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Left freezer door open-not cooling
Steph,
Your defrost timer may be stuck! This device turns the compressor off and turns on a heater to defrost everything. The timer is located in the back of the refrigerator section on most units...usually near a vent. You may see a small shaft with a 'one way' end that looks like the business end of a drill bit about 1/4 inch in diameter. If possible, turn it (probably) clockwise about half a turn. That may fix it. Wait and see what happens. If the compressor starts...you're on the right track. If not, you'll need to replace it. There are usually a few screws that you'll need to take out to access the timer.
About the ice maker...are you sure you've taken all the packing material out of the unit? Have you plugged in the motor unit? Use care when going near these items. They are mechanical, sharp and you can get injured. See if your manual is available...or online.
Nov 28, 2007 | GE GSH25JSTSS Stainless Steel Side by Side...
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
139 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Brad Goodale
