Question about Plumbing
Grohe ladylux cafe faucet removal
How do I remove the ''odd'' retention ring underneath the sink? All the water supply lines prevent it from turning and I'm not sure how to dissamble the faucet from the top.
You will need a Grohe Fitting Key to insert into the fixing tube (which is the area after you have removed the Handspray and the Fit spout) and turn counter clock wise. If you don't have Fitting Key, call Grohe at 630-582-7711
Posted on Feb 24, 2009
  • 4 Answers
Simple answer is that it was probably fitted before the water lines were connected! so they will need to be moved before you can go any further!
Posted on Jan 27, 2009
How do you remove the supply line from the spray head?
The hose should simply unscrew from the back of the head.
Here is the page on the Grohe site:
http://www.grohe.com/us/15219/kitchen/kitchen-faucets/ladylux/product-details/?product=33755-G077&color=SDE&material=33755SD0&~[ajax]=33063
Jun 03, 2014 | Grohe Plumbing
How do you remove the spray head from the supply line on a Grohe Ladylux?
Ok not sure what you are asking , but here it goes. If you are wanting to take off the sprayhead simply pull the sprayer out and unscrew. If you want to remove the spray hose from the bottom of the faucet simply grab the red spring loaded connector near the TOP, and pull down spring to release (kind of works like an air hose quick connect). If you want to remove the arch the hose must be removed from the faucet first, then simply jerk up on the arch to remove. When the arch is removed, there is a specialty tool that came with the faucet (which most plumbers keep) to tighten or loosen the faucet. Hope this helps. Luckydog
Jun 03, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
When replacing the hose on a Grohe ladylux, which end needs the gasket?
Need to replace Ladylux cafe 33755 hose, can't reach water line. How can they be removed?
Oct 25, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
Removal from kitchen sink do you unscrew from top ? because horseshoe shaped nut on bottom captures tubes
Tubes should have a some kind of clip or clasp holding them to the faucet hardware, unless they just have a standard supply line with a nut that loosens. Remove the supply lines first & then attempt to remove the main fixture nut. Unfortunately that is always a bit of a hassle, regardless if you have the proper tools. Workspace is tight & tool workspace even tighter. Good luck
Jul 21, 2012 | Grohe Ladylux Cafe Faucet with PullOut...
Hot Water pressure is nearly non-existent. Cold is fine. This is not a problem of turning on the water below the sink. Water faucets coming from the house are both fully open,, both hot and cold. Nor...
It sounds like you may have an obstruction in the supply valve under the sink. Turn off water to house. Remove supply tube from valve. Unscrew the packing nut. This is the nut where the stem of the valve enters the body of the valve. Remove it and flush the line by having someone turn on the main while you hold a cup or small bucket over the valve to prevent water from going everywhere. Also check to make sure the washer has not come loose. If the washer shot out when you flushed the line, replace it. Be sure to check flow before reinstalling supply line.
Jul 08, 2017 | Grohe Ladylux Cafe Faucet with PullOut...
Water flow from grohe ladylux kitchen faucet has slowed down with time. What can or should I do to increase water flow?
If it has a removable aerator screen, remove it and clean it out. If it can't be removed, try soaking the entire head in white vinegar for a couple of hours. You should see a big improvement.
Jun 28, 2011 | Grohe Ladylux Cafe Faucet with PullOut...
Grohe ladylux cafe faucet has low flow eventhough supply valves are wide open. This is true for both hot and cold. When supply is disconected from faucet and valve turned on there is ample pressure. Is...
I have the same problem and have the fix. There is a water pressure regulator on the bottom of the faucet( under the sink) this part is bad. Grohe will replace it for free. Call Grohe at630=582=7722 tell them the model # of the faucet and the color of the regulator, they will send you a new one for FREE.
Jun 09, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
How to tighten to sink after install?
the faucet comes with two plastic nuts once you set the faucet into the sink you have the 2 supply male lines use the plastic nuts to attach the faucet to the sink and tighten by hand
Jun 08, 2010 | Grohe Ladylux Cafe Faucet with PullOut...
Plumbing Logo
1,192 people viewed this question
Top Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
